water leak suggestions?
06-18-2006, 06:26
Post: #21
Kerry, give me a call and we can talk about what you are seeing.
Bruce Morris (919)872-7635 Raleigh, NC Webmaster - Wanderlodge Owners Online 1983 WL FC35RB FMCA: 7142s Ham Radio: KI4ME Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv ----- Original Message ----- From: davidkerryedwards To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, June 14, 2006 7:53 AM Subject: [WanderlodgeForum] Re: water leak suggestions? I think I still must be missing something. I can only see three lines coming from the tank/hw heater area going forward. One is from the tank going to the pump under the sink. I had assumed the other two were hot/cold that operated either on city pressure or were pressurized from the pump somewhere under the sink. But if one is a return pump pressure line then it seems another line is necessary for hot. Kerry --- In WanderlodgeForum@yahoogroups.com, "Stephen" <share@...> wrote: > > Through the regular hot water lines coming direct from the heater.. I guess > I should have worded the last one more clearly.. > > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards > Sent: Tuesday, June 13, 2006 7:13 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: water leak suggestions? > > > > How does the hot water get from the tank to the front? > > Kerry > > --- In WanderlodgeForum@ > yahoogroups.com, "Stephen" <share@> wrote: > > > > The pipes are as follows: > > > > > > > > 1 is pressurized city water > > > > 2 is fresh water from the tank > > > > 3 is return from WP to pressurize Hot water tank > > > > > > > > Stephen Hare > > > > 81 FC-33SB > > > > Plant City, Fl > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
06-19-2006, 08:46
Post: #22
Thanks. I'm on the road right now. I'll call when I get home in a
month or so. I've got the cold water working fine but I don't seem to have hot water yet. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Bruce Morris" <bamnc@...> wrote: > > Kerry, give me a call and we can talk about what you are seeing. > > Bruce Morris (919)872-7635 Raleigh, NC > Webmaster - Wanderlodge Owners Online > 1983 WL FC35RB > > FMCA: 7142s Ham Radio: KI4ME > Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv > ----- Original Message ----- > From: davidkerryedwards > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, June 14, 2006 7:53 AM > Subject: [WanderlodgeForum] Re: water leak suggestions? > > > I think I still must be missing something. I can only see three lines > coming from the tank/hw heater area going forward. One is from the > tank going to the pump under the sink. I had assumed the other two > were hot/cold that operated either on city pressure or were > pressurized from the pump somewhere under the sink. But if one is a > return pump pressure line then it seems another line is necessary for hot. > > Kerry > > --- In WanderlodgeForum@yahoogroups.com, "Stephen" <share@> wrote: > > > > Through the regular hot water lines coming direct from the heater.. > I guess > > I should have worded the last one more clearly.. > > > > > > > > _____ > > > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards > > Sent: Tuesday, June 13, 2006 7:13 PM > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Re: water leak suggestions? > > > > > > > > How does the hot water get from the tank to the front? > > > > Kerry > > > > --- In WanderlodgeForum@ > > yahoogroups.com, "Stephen" <share@> wrote: > > > > > > The pipes are as follows: > > > > > > > > > > > > 1 is pressurized city water > > > > > > 2 is fresh water from the tank > > > > > > 3 is return from WP to pressurize Hot water tank > > > > > > > > > > > > Stephen Hare > > > > > > 81 FC-33SB > > > > > > Plant City, Fl > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > |
