Jacking up the coach
06-23-2006, 10:30
I am quite familair with how to raise a vehicle for servicing. We have
Class 4 and 5 trucks that are jacked up all the time. But a bus type
coach with air ride and especially a Bird is a whole other thing. If
you jack the rear up by the rear axle and place jack stands under the
axle that is no better than leaving it on the tires. You will have more
room but is just as unsafe. If an air bag blows or a line/valve leaks
the coach will drop. Same applies to the front axle. So my question is:
Where do you place the jack stands or blocking when you raise your
coach?
Bruce 1988 FC35
06-23-2006, 11:20
Bruce,
Depending on what I have to do and how far under I'm going, I made
ramps out of 2"x12" boards and drive it on. Then I block the wheels
and still add jack stands under the frame rails and one or two 20 ton
jacks on an axle or frame rail, just in case. OK,... so I'm chicken,
but I'm not getting squashed under there. It only takes an extra
minute or two to be safer.
1991 WB40 "Texas Minivan"
> coach?
> Bruce 1988 FC35
06-23-2006, 13:29
The air suspension is a 4 link/panard bar type.
The vertical frame member that the horizontal tubular link bars bolt to and
pivot on is the best hard point to use for the jack stands. Front and rear.
Look carefully with a good light and it should be obvious.
MH
Sent: Friday, June 23, 2006 5:30 PM
Subject: [WanderlodgeForum] Jacking up the coach
coach?
Bruce 1988 FC35
06-23-2006, 13:43
> Bruce,
ton
chicken,
> Mike Bulriss
> San Antonio, TX
Wouldn't it be better to set up your jacks and then purge the air?
That way everything is in a static condition and a failure wouldn't
result in a change of the stability of the setup.
Gardner
We have
type
thing. If
under the
have more
leaks
question is:
your
> > coach?
> > Bruce 1988 FC35
06-24-2006, 02:44
Gardner,
Go to the archive and read the thread in message # 11892. Then you'll
know why not to just trust the leveler jacks. Hohnstein got his Bird
from the widow of a guy that trusted them. Miller's had two Birds
come off the jacks. I got my first Bird from a gentleman who lost his
next door neighbor under the neighbor's Bird after relying on the
jacks. All that first hand knowledge seems like ample evidence to me
not to trust just the leveler jacks. FWIW.....
--- In WanderlodgeForum@yahoogroups.com, "gcyeaw" wrote:
> --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@>
> > Bruce,
> ton
> chicken,
> > Mike Bulriss
> > San Antonio, TX
> Gardner
> We have
> type
> thing. If
> under the
> have more
> leaks
> question is:
> your
> > > coach?
> > > Bruce 1988 FC35
06-24-2006, 03:16
Who ever thought the obituaries would be a source to find a lodge?
' Mr Rundover was a non smoker with no pets. family gathering and
testdrives after burial services, '
Greg
> Gardner,
you'll
Bird
his
me
> Mike Bulriss
> San Antonio, TX
06-24-2006, 03:26
Greg you are a card. Sue says she wants us to go to another rally with you.
Maybe one year there will be one in Southern California in early Nov or late
Apr. These are the times we could attend.
> Greg
> > Gardner,
> you'll
> Bird
> his
> me
> > Mike Bulriss
> > San Antonio, TX
Rob, Sue & Merlin Robinson
94 WLWB
06-24-2006, 12:24
Mike,
I was not referring to the leveler jacks, I meant jack stands that
are properly rated for the load and placed on a surface that is also
capable of supporting the stand. I would never trust leveler jacks or
any other system without a positive lock. I had only suggested
blowing the air to insure the stands were stable and the sudden
weight shift wouldn't cause unstability. To be honest, I don't think
you will find me under a bus unless it is at a repair facility.
Gardner
> Gardner,
you'll
Bird
his
me
> Mike Bulriss
> San Antonio, TX
> > wrote:
> > > Bruce,
made
wheels
20
> > ton
> > chicken,
extra
> > > Mike Bulriss
> > > San Antonio, TX
air?
wouldn't
> > Gardner
servicing.
> > We have
bus
> > type
> > thing. If
> > under the
> > have more
line/valve
> > leaks
> > question is:
> > your
> > > > coach?
> > > > Bruce 1988 FC35
06-24-2006, 12:32
Rob, Sue, there is a Rally planned for October 22 in Central
California. If that is too early for your winterizing campaign, we
will have to meet up on your trip. I built a 60 X 20 foot cover and
By Nov. My bus pit will be done.
Greg and Tim
Romoland California
--- In WanderlodgeForum@yahoogroups.com, "Rob Robinson"
with you.
Nov or late
lodge?
> > Greg
> > --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> > wrote:
> > > Gardner,
> > you'll
> > Bird
Birds
lost
> > his
to
> > me
> > > Mike Bulriss
> > > San Antonio, TX
> 94 WLWB
06-26-2006, 13:28
Thanks Greg. We'd love to stop along our way to say hello and maybe see that
puppy.
> Greg and Tim
> Romoland California
> "Rob Robinson"
> with you.
> Nov or late
> lodge?
> > > Greg
> > > --- In
> > 40yahoogroups.com>,
> > > wrote:
> > > > Gardner,
> > > you'll
> > > Bird
> Birds
> lost
> > > his
> the
> to
> > > me
> > > > Mike Bulriss
> > > > San Antonio, TX
> > 94 WLWB
94 WLWB
