Generator Won't Start?
06-24-2006, 06:34
Post: #31
Mike,
You gotta a cell phone?
I am 'bout the bottom of my tech support bucket, but
who knows?, may be a scrap left?
ate,sicks,fore-for,three,oh!-one,too,zero,1
Got it?. call me,Bob
--- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot"
> Still waiting....Mike, did you go to lunch?
> long ways from the coach?
> Washing the Black goo off you hands before using
> the computer?
> Ah heck!...Just funning you.
> Here's a couple other goodies I'll thow your way.
> Hey Mike, let's get this motor popping and snorting!
> Generally,...generally I say!, a motor will spin faster
> if there is no fuel verses when there is fuel in the combustion
> chamber.
> This is a good seat-of-the-pants determination if you are
> getting fuel to the injectors or if you are not. Reason?:
> Atomized fuel in the combustion chamber doesn't compress
> causing a greater load on the starter.
> In comparison to now and before would you say the starter
> turns the motor, slower, faster,or, about the same?
> 1.)To some, starting is the process of the engine turning over.
> 2.)To, some, starting is the process of an engine turning over
> till it starts running.
> 3.)To some, starting is the process of an engine running on its
> own after being started.
> What is your thinking, 1, 2, or, 3? It's Ok on either of these
> as long as we both understand the communication.
> Can you hear the engine fire at all, or, any pops,combustion
> attempts?
> Bob
> > Mike,
> > So you kil the engine by shutting of the 12 VDC at your
> > newly installed disconnect switch? Hummmm....another piece
> > of meat on the platter.
> > Let me see,,,,(stroking my chin)
> > Don't know what the alternator would do in a case where
> > the alternator needed the battery reference for to
> > operate a regulator. No output control?
> > This is a diesel motor, right?
> > You can bypass circuits with a length of wire.
> > Do you have a 12 V test light, or Meter?
> > You have a start/stop station at the genset?
> > Press the stop and at the same time check the voltage
> > at either on of the glow plugs.
> > Got voltage? Good!
> > No voltage, gotta do it a different way.
> > Starter spin fast? or have you worn it down?
> > Need a good battery, motor needs to spin fast.
> > Fuel at the injector pump?
> > Good!
> > Remember, bleed the system of all air. Air compressses
> > in the fuel line and the injectors won't open.
> > If the starter spins fast,and
> > There is voltage at the glow pugs,and
> > There is fuel going into the injectors, and
> > There is no air in the fuel lines, and
> > The engine still won't start
> > There is a possibility that one of your injectors
> > is stuck open not allowing a pressure build in
> > the fuel. It may start and run rough as a cob but
> > if it doesn't settle down and run smoothly then one
> > or more of the injector lines will need to be bled.
> > Before getting into doing anything else, lets hear
> > from you.
> > Bob
> > --- In WanderlodgeForum@yahoogroups.com, "Mike Meister"
> > <mike.meister@> wrote:
> > > the only thing that I can think of is that I might have turned
> the
> > > gen off the last time it was running by using the disconnect
> switch
> > > (which is to the ground)
> > > It sat a week and then would not start.
> > > I have three on/off stations dash,kitchen,gen control box but I
> > will
> > > check to see if one is stuck
> > > the ceramic fuse may not have actually blown but I replaced it
> > > anyway with a like rated fuse and I just checked it and it is
ok
> > > wrote:
> > > > Mike,
> > > > While you are checking for fuel there are a couple clues
> > > > you gave that may need to be explored.
> > > > It was running, started 10 times, tried won't start.
> > > > Did you so ANYTHING to the genset between the time you
> > > > stopped the generator till the time you tried again?
> > > > Do you remember what station you depressed the switch
> > > > to stop?
> > > > Sometimes these rocker switches will stick (mine has) in
> > > > the OFF position. Should any station be stuck in the off
> > > > position and you are trying another it won't start. Just
> > > > to be sure rock them all back and forth stopping on the
> > > > center.
> > > > You said in an earlier post the the fuse blew a "couple"
> > > > months ago and you replaced it.
> > > > Fused circuits are sized for normal load plus momentary
> > > > overload protection. If say, you replaced this fuse with
> > > > a much larger size the circuit may have given up the ghost,
> > > > even if you placed a known good fuse in the holder. Just
> > > > the blown fuse alone suggests that SOMETHING??is not quite
> > > > right.
> > > > Bob
> > > > not quite right in that circuit.
> > > > > the fuel solenoid arm is moving and if I pull it it
actually
> > > > > chokes/restricts the start effort.
> > > > > will check fuel now and report back
> > > > > thanks
> > > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss"
> <mbulriss@>
> > > > > wrote:
> > > > > > Mike,
> > > > > > Outside the voltage issue Curt mentioned, manually
pulling
> > the
> > > > fuel
> > > > > > solenoid arm should have started it - if you are getting
> > > fuel.
> > > > > Have
> > > > > > you checked to see if you are getting fuel pressure at
> > > output
> > > > > side
> > > > > > of the lift pump? Also check all the fuel line fittings
to
> > > make
> > > > > sure
> > > > > > you don't have an air leak. Doesn't take much of a leak
on
> a
> > > > older
> > > > > > weaker lift pump to not get fuel to the injector pump.
> Spent
> > > > hours
> > > > > > chasing the problem on my 83 PT40 before I checked the
fuel
> > > > > pressure
> > > > > > and changed out the lift pump.
> > > > > > Mike Bulriss
> > > > > > 1991 WB40 "Texas Minivan"
> > > > > > San Antonio, TX
> > > > > > > Tom-
> > > > > > > It turns over great just won't catch. I pulled the fuel
> > > > solenoid
> > > > > > > lever as I tried to start but no go. doesn't appear the
> > fuel
> > > > > > > solenoid/arm is moving when I hit the start button? I
> don't
> > > see
> > > > > a
> > > > > > > circuit breaker on the control box but the fuse is good
> > > inside
> > > > > the
> > > > > > > box....
> > > > > > > thoughts?
> > > > > > > Mike
> > > > > > > 80fc33
> > > > > > > Taylor Mill, Ky
> > > > > > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner
> > > > > > > wrote:
> > > > > > > > Its not clear what you mean by "it wont start". Does
it
> > > try
> > > > to
> > > > > > > start
> > > > > > > > and then shut off or just never catch on? f the
engine
> > > turns
> > > > > over
> > > > > > > at
> > > > > > > > a normal speed but wont start then hold in the fuel
> > > solenoid
> > > > > lever
> > > > > > > > and see if it starts. If it does then that eliminates
> the
> > > > fuel
> > > > > > > > problems. I would next look if the fuel solenoid is
> > > pulling
> > > > > in.
> > > > > > > If
> > > > > > > > its not then check on the front of the control box
> > see
> > > if
> > > > > the
> > > > > > > > circuit breaker is off.
> > > > > > > > tom warner
> > > > > > > > Vernon center,NY
> > > > > > > > 1985 PT 40
> > > > > > > > At 10:50 PM 6/20/2006, you wrote:
> > > > > > > > >I am no expert on gensets either. However, I know
this
> > for
> > > > > > > > >certain. If I could place wheels on the crankshaft
of
> a
> > > > diesel
> > > > > > > > >engine, could feed it fuel without battery power and
> > > could
> > > > > push it
> > > > > > > > >down a hill to start it, the engine will run until
> > > > > coolant
> > > > > > > runs
> > > > > > > > >out, the fuel runs out or it blows itself up. That
> being
> > > > > said,
> > > > > > > there
> > > > > > > > >is an external electrical issue to this problem. I
> think
> > > we
> > > > > need
> > > > > > > > >more feedback and think simple.
> > > > > > > > >Thanks,
> > > > > > > > >Leroy Eckert
> > > > > > > > >1990 WB-40
> > > > > > > > >Niceville, FL
> > > > > > > > >- In
> > > > > > > > > > > > > > > > 40yahoogroups.com>WanderlodgeForum@yahoogroups.com,
> > > > > > > > >Curt Sprenger
> > > > > > > > > wrote:
> > > > > > > > > > Mike,
> > > > > > > > > > From my experience. I'm no expert.
> > > > > > > > > > Some gen. sets alternators create component
voltage
> > > > > (voltage to
> > > > > > > > > > components) at start time in order for the gen.
> > engine
> > > to
> > > > > > > start. No
> > > > > > > > > > voltage could be the problem you are
experiencing.
> I
> > > > > suggest
> > > > > > > taking
> > > > > > > > >your
> > > > > > > > > > bus to a good generator shop and have the gen.
set
> > > > tested.
> > > > > > > Maybe
> > > > > > > > >the
> > > > > > > > > > voltage regulator is bad.
> > > > > > > > > > One day our gen. set would start right up. The
next
> > > time
> > > > > it
> > > > > > > would
> > > > > > > > >turn
> > > > > > > > > > over but it would not start. I had to replace the
> > > > > alternator
> > > > > > > > >because on
> > > > > > > > > > initial start it would not create the voltage
> > > necessary
> > > > > for the
> > > > > > > > >unit to
> > > > > > > > > > start up. The large windings were bad due to
> sitting
> > > > (lack
> > > > > of
> > > > > > > use).
> > > > > > > > >Our
> > > > > > > > > > gen. set was the Yanmar engine and Kohler
> alternator.
> > > The
> > > > > > > Kohler
> > > > > > > > > > alternator was the problem and it was replaced
with
> a
> > > > > Newage
> > > > > > > unit.
> > > > > > > > >I
> > > > > > > > > > hope your problem is not the same.
> > > > > > > > > > Good luck.
> > > > > > > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif.
06-24-2006, 06:45
Post: #32
513-382-9979
> Mike,
> > the computer?
> > chamber.
> > attempts?
> > Bob
> > wrote:
> > > Mike,
> > > Got voltage? Good!
> > > Good!
> > > from you.
> > > Bob
turned
> > the
> > switch
but I
> > > will
it
is
> ok
> > > > wrote:
> > > > > Mike,
> > > > > to stop?
> > > > > center.
> > > > > right.
> > > > > Bob
> actually
> > > > > > thanks
> > <mbulriss@>
> > > > > > wrote:
> > > > > > > Mike,
> pulling
> > > the
> > > > > fuel
getting
> > > > fuel.
> > > > > > Have
> the
> > > > output
> > > > > > side
fittings
> to
> > > > make
> > > > > > sure
leak
> on
> > a
> > > > > older
pump.
> > Spent
> > > > > hours
> fuel
> > > > > > pressure
> > > > > > > Mike Bulriss
> > > > > > > San Antonio, TX
> > > > > > > > Tom-
fuel
> > > > > solenoid
> > > fuel
I
> > don't
> > > > see
> > > > > > a
good
> > > > inside
> > > > > > the
> > > > > > > > box....
> > > > > > > > thoughts?
> > > > > > > > Mike
> > > > > > > > 80fc33
> > > > > > > > Taylor Mill, Ky
Does
> it
> > > > try
> > > > > to
> > > > > > > > start
> engine
> > > > turns
> > > > > > over
> > > > > > > > at
fuel
> > > > solenoid
> > > > > > lever
eliminates
> > the
> > > > > fuel
is
> > > > pulling
> > > > > > in.
> > > > > > > > If
> and
> > > see
> > > > if
> > > > > > the
> > > > > > > > > tom warner
> > > > > > > > > Vernon center,NY
> > > > > > > > > 1985 PT 40
> this
> > > for
crankshaft
> of
> > a
> > > > > diesel
> > > > could
> > > > > > push it
until
> the
> > > > > > coolant
> > > > > > > > runs
That
> > being
> > > > > > said,
> > > > > > > > there
I
> > think
> > > > we
> > > > > > need
> > > > > > > > > >Thanks,
> > > > > > > > > >Leroy Eckert
> > > > > > > > > >1990 WB-40
> > > > > > > > > >Niceville, FL
> > > > > > > > > >- In
> > > > > > > > > >Curt Sprenger
> > > > > > > > > > wrote:
> > > > > > > > > > > Mike,
> voltage
> > > > > > (voltage to
gen.
> > > engine
> > > > to
> > > > > > > > start. No
> experiencing.
> > I
> > > > > > suggest
> > > > > > > > taking
> > > > > > > > > >your
> set
> > > > > tested.
> > > > > > > > Maybe
> > > > > > > > > >the
> next
> > > > time
> > > > > > it
> > > > > > > > would
> > > > > > > > > >turn
> > > > > > alternator
> > > > > > > > > >because on
> > > > necessary
> > > > > > for the
> > > > > > > > > >unit to
> > sitting
> > > > > (lack
> > > > > > of
> > > > > > > > use).
> > > > > > > > > >Our
> > alternator.
> > > > The
> > > > > > > > Kohler
> with
> > a
> > > > > > Newage
> > > > > > > > unit.
> > > > > > > > > >I
> > > > > > > > > > > Good luck.
06-24-2006, 06:47
Post: #33
turns over the same as is always has
#2
Mike
> the computer?
> chamber.
> attempts?
> Bob
> > Mike,
> > Got voltage? Good!
> > Good!
> > from you.
> > Bob
> the
> switch
I
> > will
ok
> > > wrote:
> > > > Mike,
> > > > to stop?
> > > > center.
> > > > right.
> > > > Bob
actually
> > > > > thanks
> <mbulriss@>
> > > > > wrote:
> > > > > > Mike,
pulling
> > the
> > > > fuel
> > > fuel.
> > > > > Have
> > > output
> > > > > side
to
> > > make
> > > > > sure
on
> a
> > > > older
> Spent
> > > > hours
fuel
> > > > > pressure
> > > > > > Mike Bulriss
> > > > > > San Antonio, TX
> > > > > > > Tom-
fuel
> > > > solenoid
> > fuel
> don't
> > > see
> > > > > a
good
> > > inside
> > > > > the
> > > > > > > box....
> > > > > > > thoughts?
> > > > > > > Mike
> > > > > > > 80fc33
> > > > > > > Taylor Mill, Ky
it
> > > try
> > > > to
> > > > > > > start
engine
> > > turns
> > > > > over
> > > > > > > at
> > > solenoid
> > > > > lever
eliminates
> the
> > > > fuel
> > > pulling
> > > > > in.
> > > > > > > If
> > see
> > > if
> > > > > the
> > > > > > > > tom warner
> > > > > > > > Vernon center,NY
> > > > > > > > 1985 PT 40
this
> > for
of
> a
> > > > diesel
> > > could
> > > > > push it
> > > > > coolant
> > > > > > > runs
> being
> > > > > said,
> > > > > > > there
> think
> > > we
> > > > > need
> > > > > > > > >Thanks,
> > > > > > > > >Leroy Eckert
> > > > > > > > >1990 WB-40
> > > > > > > > >Niceville, FL
> > > > > > > > >- In
> > > > > > > > >Curt Sprenger
> > > > > > > > > wrote:
> > > > > > > > > > Mike,
voltage
> > > > > (voltage to
> > engine
> > > to
> > > > > > > start. No
experiencing.
> I
> > > > > suggest
> > > > > > > taking
> > > > > > > > >your
set
> > > > tested.
> > > > > > > Maybe
> > > > > > > > >the
next
> > > time
> > > > > it
> > > > > > > would
> > > > > > > > >turn
> > > > > alternator
> > > > > > > > >because on
> > > necessary
> > > > > for the
> > > > > > > > >unit to
> sitting
> > > > (lack
> > > > > of
> > > > > > > use).
> > > > > > > > >Our
> alternator.
> > > The
> > > > > > > Kohler
with
> a
> > > > > Newage
> > > > > > > unit.
> > > > > > > > >I
> > > > > > > > > > Good luck.
06-24-2006, 07:44
Post: #34
No red button. I smell gas but I will crack one of the lines and
see if anything coming out.
hold...
> Isnt there a red button on the front or the generator control box
> that can be pushed in to reset? If not and you have actually
pulled
> back on the lever in front of the fuel solenoid that connects
> directly tothe injection pump and it wont start then I have to
> believe it is a fuel problem. Is it getting fuel when it is
turning
> over? Verify this by cracking one of the injector lines at the
fuel
> injector and see if fuel weeps out of it. If not then you are not
> getting fuel to the injector pump. Have you replaced the fuel
filter
> by any chance?
> tom
> At 10:37 AM 6/24/2006, you wrote:
> >Tom-
> >It turns over great just won't catch. I pulled the fuel solenoid
> >lever as I tried to start but no go. doesn't appear the fuel
> >solenoid/arm is moving when I hit the start button? I don't see a
> >circuit breaker on the control box but the fuse is good inside the
> >box....
> >thoughts?
> >Mike
> >80fc33
> >Taylor Mill, Ky
> >--- In
> >Tom Warner
> >wrote:
> > > Its not clear what you mean by "it wont start". Does it try to
> >start
> > > and then shut off or just never catch on? f the engine turns
over
> >at
> > > a normal speed but wont start then hold in the fuel solenoid
lever
> > > and see if it starts. If it does then that eliminates the fuel
> > > problems. I would next look if the fuel solenoid is pulling in.
> >If
> > > its not then check on the front of the control box and see if
> > > tom warner
> > > Vernon center,NY
> > > 1985 PT 40
> > > >I am no expert on gensets either. However, I know this for
> > > >certain. If I could place wheels on the crankshaft of a diesel
> > > >engine, could feed it fuel without battery power and could
push it
> > > >down a hill to start it, the engine will run until the coolant
> >runs
> > > >out, the fuel runs out or it blows itself up. That being said,
> >there
> > > >is an external electrical issue to this problem. I think we
need
> > > >Thanks,
> > > >Leroy Eckert
> > > >1990 WB-40
> > > >Niceville, FL
> > > >- In
> > > > > >40yahoogroups.com> 40yahoogroups.com>WanderlodgeForum@yahoogroups.com,
> > > >Curt Sprenger
> > > > wrote:
> > > > > Mike,
> > > > > Some gen. sets alternators create component voltage
(voltage to
> > > > > components) at start time in order for the gen. engine to
> >start. No
> > > > > voltage could be the problem you are experiencing. I
suggest
> >taking
> > > >your
> > > > > bus to a good generator shop and have the gen. set tested.
> >Maybe
> > > >the
> > > > > One day our gen. set would start right up. The next time it
> >would
> > > >turn
alternator
> > > >because on
> > > > > initial start it would not create the voltage necessary
for the
> > > >unit to
> > > > > start up. The large windings were bad due to sitting (lack
of
> >use).
> > > >Our
> > > > > gen. set was the Yanmar engine and Kohler alternator. The
> >Kohler
> > > > > alternator was the problem and it was replaced with a
Newage
> >unit.
> > > >I
> > > > > Good luck.
06-24-2006, 08:27
Post: #35
OK-
FYI- I have a 4cyl gas Kohler.
good spark to each cylinder and good fuel flow through the filter
(pass the electric cutoff valve) to the carb.
tried a little starter fluid and still no go.
Mike
80fc33
Taylor Mill, Ky
> hold...
box
> pulled
> turning
> fuel
not
> filter
> > by any chance?
> > tom
> > >Tom-
a
> > >box....
> > >thoughts?
> > >Mike
> > >80fc33
> > >Taylor Mill, Ky
> > >--- In
> > >Tom Warner
to
> > >start
> over
> > >at
> lever
fuel
in.
> > >If
if
> the
> > > > tom warner
> > > > Vernon center,NY
> > > > 1985 PT 40
diesel
> push it
coolant
> > >runs
said,
> > >there
> need
> > > > >Thanks,
> > > > >Leroy Eckert
> > > > >1990 WB-40
> > > > >Niceville, FL
> > > > >- In
> > > > > > > >40yahoogroups.com> > 40yahoogroups.com>WanderlodgeForum@yahoogroups.com,
> > > > >Curt Sprenger
> > > > > wrote:
> > > > > > Mike,
> (voltage to
> > >start. No
> suggest
> > >taking
> > > > >your
tested.
> > >Maybe
> > > > >the
it
> > >would
> > > > >turn
> alternator
> > > > >because on
> for the
> > > > >unit to
(lack
> of
> > >use).
> > > > >Our
> > >Kohler
> Newage
> > >unit.
> > > > >I
> > > > > > Good luck.
06-24-2006, 09:22
Post: #36
Gas???? a gas is shut down by removing spark not fuel. cutting off
fuel may cause a backfire. sounds like a timing advance issue now.
Greg
Gas is for farting
> OK-
> Mike
> 80fc33
> Taylor Mill, Ky
> > hold...
> box
> > pulled
> > turning
> > fuel
> not
> > filter
> > > by any chance?
> > > tom
> > > >Tom-
solenoid
see
> a
> the
> > > >box....
> > > >thoughts?
> > > >Mike
> > > >80fc33
> > > >Taylor Mill, Ky
> > > >--- In
> > > >Tom Warner
> to
> > > >start
turns
> > over
> > > >at
solenoid
> > lever
> fuel
> in.
> > > >If
> if
> > the
> > > > > tom warner
> > > > > Vernon center,NY
> > > > > 1985 PT 40
> diesel
> > push it
> coolant
> > > >runs
> said,
> > > >there
we
> > need
> > > > > >Thanks,
> > > > > >Leroy Eckert
> > > > > >1990 WB-40
> > > > > >Niceville, FL
> > > > > >- In
> > > > > > > > > >40yahoogroups.com> > > 40yahoogroups.com>WanderlodgeForum@yahoogroups.com,
> > > > > >Curt Sprenger
> > > > > > wrote:
> > > > > > > Mike,
> > (voltage to
to
> > > >start. No
> > suggest
> > > >taking
> > > > > >your
> tested.
> > > >Maybe
> > > > > >the
time
> it
> > > >would
> > > > > >turn
> > alternator
> > > > > >because on
> > for the
> > > > > >unit to
> (lack
> > of
> > > >use).
> > > > > >Our
The
> > > >Kohler
> > Newage
> > > >unit.
> > > > > >I
> > > > > > > Good luck.
06-24-2006, 10:04
Post: #37
I called Mike to find out he had a 4 cyl gas genset.
Told him about the checking the spark and using some
starter fluid. He has since tried that without results.
Any ideas?, Timing issue?
Maybe flooded, he said he smelled gas, pull the plugs and
clean them, try again?
Bob, chewing up and swallowing my diesel check list.
> Greg
> Gas is for farting
> > OK-
> > Mike
> > 80fc33
> > Taylor Mill, Ky
> > > hold...
> > box
actually
> > > pulled
to
> > > turning
> > > fuel
are
> > not
> > > filter
> > > > by any chance?
> > > > tom
> > > > >Tom-
> solenoid
> see
> > a
inside
> > the
> > > > >box....
> > > > >thoughts?
> > > > >Mike
> > > > >80fc33
> > > > >Taylor Mill, Ky
> > > > >--- In
> > > > >Tom Warner
try
> > to
> > > > >start
> turns
> > > over
> > > > >at
> solenoid
> > > lever
> > fuel
pulling
> > in.
> > > > >If
see
> > if
> > > the
> > > > > > tom warner
> > > > > > Vernon center,NY
> > > > > > 1985 PT 40
for
> > diesel
could
> > > push it
> > coolant
> > > > >runs
> > said,
> > > > >there
> we
> > > need
> > > > > > >Thanks,
> > > > > > >Leroy Eckert
> > > > > > >1990 WB-40
> > > > > > >Niceville, FL
> > > > > > >- In
> > > > > > > > > > > >40yahoogroups.com> > > > 40yahoogroups.com>WanderlodgeForum@yahoogroups.com,
> > > > > > >Curt Sprenger
> > > > > > > wrote:
> > > > > > > > Mike,
> > > (voltage to
engine
> to
> > > > >start. No
> > > suggest
> > > > >taking
> > > > > > >your
> > tested.
> > > > >Maybe
> > > > > > >the
> time
> > it
> > > > >would
> > > > > > >turn
> > > alternator
> > > > > > >because on
necessary
> > > for the
> > > > > > >unit to
> > (lack
> > > of
> > > > >use).
> > > > > > >Our
> The
> > > > >Kohler
> > > Newage
> > > > >unit.
> > > > > > >I
> > > > > > > > Good luck.
06-25-2006, 03:25
Post: #38
Mike, things like a loose cap or too much gooey grease on the point
cam or distributor weight springs will make it hard to start. Like
plug wires (that fail with age even without use), ignition coil is
also a replaceable maintenance item often overlooked. After-market
coils and wires have disappointed me in the past.
If your bus was ever owned by a 'pressurewasher engindegreeser clean
freak,' chances are the grease in the distributor lost its oil and
turned to wax, the coil lost its seal and went bad plug wires are
cracked and all the sealed bearing in your bus are dry. Spraying wd40
and other things at the points will wash the oil out of the grease
also.
I soak gunky things in light oil (diesel fuel) to thin out the bond,
agitate it with a parts brush and wash it off with hot water and
laundry soap.
94pt Romoland Ca
"pressurewashers are for decks and patios"
off
> > Greg
> > Gas is for farting
> > > OK-
filter
> > > Mike
> > > 80fc33
> > > Taylor Mill, Ky
> and
> > > > hold...
control
> > > box
> actually
> > > > pulled
connects
> to
> > > > turning
> the
> > > > fuel
> are
> > > not
fuel
> > > > filter
> > > > > by any chance?
> > > > > tom
> > > > > >Tom-
> > solenoid
fuel
don't
> > see
> > > a
> inside
> > > the
> > > > > >box....
> > > > > >thoughts?
> > > > > >Mike
> > > > > >80fc33
> > > > > >Taylor Mill, Ky
> > > > > >--- In
> > > > > >Tom Warner
> try
> > > to
> > > > > >start
> > turns
> > > > over
> > > > > >at
> > solenoid
> > > > lever
> > > fuel
> pulling
> > > in.
> > > > > >If
> see
> > > if
> > > > the
> > > > > > > tom warner
> > > > > > > Vernon center,NY
> > > > > > > 1985 PT 40
> for
a
> > > diesel
> could
> > > > push it
> > > coolant
> > > > > >runs
being
> > > said,
> > > > > >there
think
> > we
> > > > need
> > > > > > > >Thanks,
> > > > > > > >Leroy Eckert
> > > > > > > >1990 WB-40
> > > > > > > >Niceville, FL
> > > > > > > >- In
> > > > > > > > > > > > > >40yahoogroups.com> > > > > 40yahoogroups.com>WanderlodgeForum@yahoogroups.com,
> > > > > > > >Curt Sprenger
> > > > > > > > wrote:
> > > > > > > > > Mike,
> > > > (voltage to
> engine
> > to
> > > > > >start. No
I
> > > > suggest
> > > > > >taking
> > > > > > > >your
> > > tested.
> > > > > >Maybe
> > > > > > > >the
> > time
> > > it
> > > > > >would
> > > > > > > >turn
> > > > alternator
> > > > > > > >because on
> necessary
> > > > for the
> > > > > > > >unit to
sitting
> > > (lack
> > > > of
> > > > > >use).
> > > > > > > >Our
alternator.
> > The
> > > > > >Kohler
a
> > > > Newage
> > > > > >unit.
> > > > > > > >I
> > > > > > > > > Good luck.
User(s) browsing this thread: 16 Guest(s)
