cruiseair a/c
06-25-2006, 14:39
cruiseair a/c
hi all, may name is bill davison an i was a wanabe...i,am now the
proud owner of a 1982 35ft fc sb..this group has help me out on a lot of things ...but this problem i can.t solve..i can,t get any of the a/c,s to come on..i know they worked because i may sure at the time i got the bus...its a no go with the gen.(gen works great) or shore power (50AMP)is there a fuse or relay somewhere it i,am missing ..thanks for any help..bill 1982 35fcsb |
06-25-2006, 15:08
cruiseair a/c
First place to look is on your dash. There should be a switch for
each of your a/c units. They will not run till these switches are on. If that don't do it, let us know. R.E. (Ron) Marabito, Dallas, TX 92WB40 Forum Moderator --- In WanderlodgeForum@yahoogroups.com, "teamster38man" <64tbird@...> wrote: > > hi all, may name is bill davison an i was a wanabe...i,am now the > proud owner of a 1982 35ft fc sb..this group has help me out on a lot > of things ...but this problem i can.t solve..i can,t get any of the > a/c,s to come on..i know they worked because i may sure at the time i > got the bus...its a no go with the gen.(gen works great) or shore power > (50AMP)is there a fuse or relay somewhere it i,am missing ..thanks for > any help..bill 1982 35fcsb > |
06-25-2006, 15:24
cruiseair a/c
Look to see if the three light switches beside the drivers seat are
toggled on, if they are on check breakers in the closet across the aisle from the pantry door Hope this helps Charlie 81FC35 St Albans, WV --- In WanderlodgeForum@yahoogroups.com, "teamster38man" <64tbird@...> wrote: > > hi all, may name is bill davison an i was a wanabe...i,am now the > proud owner of a 1982 35ft fc sb..this group has help me out on a lot > of things ...but this problem i can.t solve..i can,t get any of the > a/c,s to come on..i know they worked because i may sure at the time i > got the bus...its a no go with the gen.(gen works great) or shore power > (50AMP)is there a fuse or relay somewhere it i,am missing ..thanks for > any help..bill 1982 35fcsb > |
06-25-2006, 15:25
cruiseair a/c
Hi Bill,
Welcome aboard and congrats going from a "wanna be a" to a "now I am a", you sound as happy as a proud papa. On my '77 those two switches were just below seat level from the drivers seat, on the '87 they were overhead on a panel above say your left shoulder up high. Somewhere within arms reach of the drivers seat you'll find them. Bob Janes, '87 FC35, Greenville, SC --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > First place to look is on your dash. There should be a switch for > each of your a/c units. They will not run till these switches are on. > If that don't do it, let us know. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > Forum Moderator > > --- In WanderlodgeForum@yahoogroups.com, "teamster38man" <64tbird@> > wrote: > > > > hi all, may name is bill davison an i was a wanabe...i,am now the > > proud owner of a 1982 35ft fc sb..this group has help me out on a lot > > of things ...but this problem i can.t solve..i can,t get any of the > > a/c,s to come on..i know they worked because i may sure at the time i > > got the bus...its a no go with the gen.(gen works great) or shore power > > (50AMP)is there a fuse or relay somewhere it i,am missing ..thanks for > > any help..bill 1982 35fcsb > > > |
06-25-2006, 15:28
cruiseair a/c
Bill,
My A/C switches are located to the left of the driver seat on the wall.. go figure.. They look just like the regular wall switches.. I couldn't get my A/C's to come on at first... just had to learn Blue Bird's logic.. Stephen Hare Getting new CARPET and Vinyl next weekend!!!! Yea! 81 FC33SB Plant City, FL _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of teamster38man Sent: Sunday, June 25, 2006 10:39 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] cruiseair a/c hi all, may name is bill davison an i was a wanabe...i,am now the proud owner of a 1982 35ft fc sb..this group has help me out on a lot of things ...but this problem i can.t solve..i can,t get any of the a/c,s to come on..i know they worked because i may sure at the time i got the bus...its a no go with the gen.(gen works great) or shore power (50AMP)is there a fuse or relay somewhere it i,am missing ..thanks for any help..bill 1982 35fcsb [Non-text portions of this message have been removed] |
06-25-2006, 19:24
cruiseair a/c
wrote: > Hi Bill I did the same thing today, starting coach, genny etc today to make sure everything still worked for our trip this week. Breaker was on, gen on, even plugged into shore 50 couldn't get the air condtioners to come on.... duh finally got out the book and refreshed my memory and found the 3 buttons on the wall by the driver seat. They all worked great once the switches were on..... Rose Mary 82FC 35 SB Oregon > hi all, may name is bill davison an i was a wanabe...i,am now the > proud owner of a 1982 35ft fc sb..this group has help me out on a lot > of things ...but this problem i can.t solve..i can,t get any of the > a/c,s to come on..i know they worked because i may sure at the time i > got the bus...its a no go with the gen.(gen works great) or shore power > (50AMP)is there a fuse or relay somewhere it i,am missing ..thanks for > any help..bill 1982 35fcsb > |
