Paint
07-24-2006, 14:14
Paint
Leroy, are you doing touchup or a repaint? I love the looks of the 88
to 90 wbpts. Some of the stripe colors they introduced in the 90's got less classic and more personal. I often wondered if BB just allowed customers to make these design crimes in special order coaches. A fun thing to do is manipulate the color of your coach in a paint program. Doesn't sound like it will hurt to get creative with the colors if you are thinking of a repaint. while looking for a coach when I read "custom paint" it had the same effect as "she's got a pretty face" Gregory O'Connor 94pt gray silver pink and green missing a chandelier and piano --- In WanderlodgeForum@yahoogroups.com, "jwasnewski" > > Curt: > I talked to Steve Birtles today about my paint codes. He says you may > be able to decifer the numbers. I have not had success. Numbers > follow: > > 92329----No clue what this number means. > 73773----Base--Light silver--Frito-Lay Fleet I believe. > 81573----Stripe--there are two different colored stripes. > 79780----Light > 81735----Dark > > Colors are---Light silver, dark silver, turquoise stripe, salmon? > mauve? stripe. > > Thanks: > > Leroy Eckert > 1990-WB-40 > Niceville, FL > |
07-24-2006, 14:24
Paint
Lets try this again
Leroy will probably chime in on this the second code I believe is 79773 The first I have no idea Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > leroy will probaly ship in but the second code i beilve should be > 79773 ithink thats what he said it was and the first I have no idea > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com, "lcondosta" > wrote: > > > > 81573 med lagoon met ford motor co 79780cumulus gray met ford motor > > co 81735 rose met ford motor co other two must be wrong codes Lee > > A Condosta BASF Jobber Holden Beach N.C 85PT40--- In > > WanderlodgeForum@yahoogroups.com, "jwasnewski" > > wrote: > > > > > > Curt: > > > I talked to Steve Birtles today about my paint codes. He says you > > may > > > be able to decifer the numbers. I have not had success. Numbers > > > follow: > > > > > > 92329----No clue what this number means. > > > 73773----Base--Light silver--Frito-Lay Fleet I believe. > > > 81573----Stripe--there are two different colored stripes. > > > 79780----Light > > > 81735----Dark > > > > > > Colors are---Light silver, dark silver, turquoise stripe, salmon? > > > mauve? stripe. > > > > > > Thanks: > > > > > > Leroy Eckert > > > 1990-WB-40 > > > Niceville, FL > > > > > > |
07-24-2006, 15:35
Paint
Gregory: Not thinking about a repainting. The paint is in fabulous shape, not
a scratch anyplace except a couple of recent chips that I did while changing the broken end of the main Zip Dee awning brace. I dropped the main awning on the side of the coach. Ouch! Dumb! It could have been worse. I don't know about the paint or design on our girlie bus---turquoise and rose over two tone gray---but our interior was altered by the original owner during construction. Our interior is top notch. I have been told that Royal did the interior, haven't been able to verify. Got Steven Birtles looking into it although it really doesn't mean anything, talking points maybe. The idea of repainting has previously been squashed by the wife. Thanks for the response. Were you referring to Liberace? Don't forget the cape. LOL Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Gregory OConnor To: WanderlodgeForum@yahoogroups.com Sent: Monday, July 24, 2006 9:14 PM Subject: [WanderlodgeForum] Re: Paint Leroy, are you doing touchup or a repaint? I love the looks of the 88 to 90 wbpts. Some of the stripe colors they introduced in the 90's got less classic and more personal. I often wondered if BB just allowed customers to make these design crimes in special order coaches. A fun thing to do is manipulate the color of your coach in a paint program. Doesn't sound like it will hurt to get creative with the colors if you are thinking of a repaint. while looking for a coach when I read "custom paint" it had the same effect as "she's got a pretty face" Gregory O'Connor 94pt gray silver pink and green missing a chandelier and piano --- In WanderlodgeForum@yahoogroups.com, "jwasnewski" > > Curt: > I talked to Steve Birtles today about my paint codes. He says you may > be able to decifer the numbers. I have not had success. Numbers > follow: > > 92329----No clue what this number means. > 73773----Base--Light silver--Frito-Lay Fleet I believe. > 81573----Stripe--there are two different colored stripes. > 79780----Light > 81735----Dark > > Colors are---Light silver, dark silver, turquoise stripe, salmon? > mauve? stripe. > > Thanks: > > Leroy Eckert > 1990-WB-40 > Niceville, FL > [Non-text portions of this message have been removed] |
07-24-2006, 15:45
Paint
Lee: Thanks much for the reply. A double check shows 73773 should have been
79773. The 92329 number is stamped in the upper left hand corner of the paint code sticker. So, 79773 is the correct number. Can I purchase the paint from you? I haven't found any locally. Need it for touch up purposes. What is the shelf life? Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: lcondosta To: WanderlodgeForum@yahoogroups.com Sent: Monday, July 24, 2006 8:01 PM Subject: [WanderlodgeForum] Re: Paint 81573 med lagoon met ford motor co 79780cumulus gray met ford motor co 81735 rose met ford motor co other two must be wrong codes Lee A Condosta BASF Jobber Holden Beach N.C 85PT40--- In WanderlodgeForum@yahoogroups.com, "jwasnewski" wrote: > > Curt: > I talked to Steve Birtles today about my paint codes. He says you may > be able to decifer the numbers. I have not had success. Numbers > follow: > > 92329----No clue what this number means. > 73773----Base--Light silver--Frito-Lay Fleet I believe. > 81573----Stripe--there are two different colored stripes. > 79780----Light > 81735----Dark > > Colors are---Light silver, dark silver, turquoise stripe, salmon? > mauve? stripe. > > Thanks: > > Leroy Eckert > 1990-WB-40 > Niceville, FL > [Non-text portions of this message have been removed] |
07-24-2006, 16:05
Paint
leroy, if it is touchup I would just take the bus to a good dealer
autobody shop and get an out the door quote ( may be less expensive than you think). Chances are that the paint color will change with the transfering out of the 1990's restricted formulas. and in the quart mininum mix quantities you will need you are talking over 400. bucks. A good shop can site mix and blend. you won't get the code excuse "but sir that is the paint code you ordered." Prism in the metalic paints is also something that will be hard to match unless you have special skills. maybe the paint code is a royal number. Bob and Dixie G have a 92 Royal conversion, I wonder if they have info on the codes. Gregory O'Connor 94pt no Royality Romoland Ca --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Gregory: Not thinking about a repainting. The paint is in fabulous shape, not a scratch anyplace except a couple of recent chips that I did while changing the broken end of the main Zip Dee awning brace. I dropped the main awning on the side of the coach. Ouch! Dumb! It could have been worse. > > I don't know about the paint or design on our girlie bus--- turquoise and rose over two tone gray---but our interior was altered by the original owner during construction. Our interior is top notch. I have been told that Royal did the interior, haven't been able to verify. Got Steven Birtles looking into it although it really doesn't mean anything, talking points maybe. The idea of repainting has previously been squashed by the wife. Thanks for the response. > > Were you referring to Liberace? Don't forget the cape. LOL > > Leroy Eckert > 1990 WB-40 > Niceville, FL > > > > > > ----- Original Message ----- > From: Gregory OConnor > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, July 24, 2006 9:14 PM > Subject: [WanderlodgeForum] Re: Paint > > > Leroy, are you doing touchup or a repaint? I love the looks of the 88 > to 90 wbpts. Some of the stripe colors they introduced in the 90's > got less classic and more personal. I often wondered if BB just > allowed customers to make these design crimes in special order > coaches. A fun thing to do is manipulate the color of your coach in > a paint program. Doesn't sound like it will hurt to get creative > with the colors if you are thinking of a repaint. > > while looking for a coach when I read "custom paint" it had the same > effect as "she's got a pretty face" > Gregory O'Connor > 94pt gray silver pink and green > missing a chandelier and piano > > --- In WanderlodgeForum@yahoogroups.com, "jwasnewski" > > > > > Curt: > > I talked to Steve Birtles today about my paint codes. He says you > may > > be able to decifer the numbers. I have not had success. Numbers > > follow: > > > > 92329----No clue what this number means. > > 73773----Base--Light silver--Frito-Lay Fleet I believe. > > 81573----Stripe--there are two different colored stripes. > > 79780----Light > > 81735----Dark > > > > Colors are---Light silver, dark silver, turquoise stripe, salmon? > > mauve? stripe. > > > > Thanks: > > > > Leroy Eckert > > 1990-WB-40 > > Niceville, FL > > > > > > > > [Non-text portions of this message have been removed] > |
07-25-2006, 09:17
Paint
Gregory: I did think about shading differences etc. You are
probably correct. I may get a bid from the local paint shop. The area that I screwed up is on the entry door, maybe 2x3. Didn't dent anything, just scratched and chipped the paint, obviously right where I can constantly see the damage. Thanks for the input. Been gone from CA for awhile. Isn't Romoland between Riverside and Temecula or Hemet? Lived in Riverside for 25yrs Leroy Eckert 1990WB-40 Niceville, FL -- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > leroy, if it is touchup I would just take the bus to a good dealer > autobody shop and get an out the door quote ( may be less expensive > than you think). Chances are that the paint color will change with > the transfering out of the 1990's restricted formulas. and in the > quart mininum mix quantities you will need you are talking over 400. > bucks. A good shop can site mix and blend. you won't get the code > excuse "but sir that is the paint code you ordered." Prism in the > metalic paints is also something that will be hard to match unless > you have special skills. maybe the paint code is a royal number. Bob > and Dixie G have a 92 Royal conversion, I wonder if they have info on > the codes. > Gregory O'Connor > 94pt no Royality > Romoland Ca > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > Gregory: Not thinking about a repainting. The paint is in > fabulous shape, not a scratch anyplace except a couple of recent > chips that I did while changing the broken end of the main Zip Dee > awning brace. I dropped the main awning on the side of the coach. > Ouch! Dumb! It could have been worse. > > > > I don't know about the paint or design on our girlie bus--- > turquoise and rose over two tone gray---but our interior was altered > by the original owner during construction. Our interior is top > notch. I have been told that Royal did the interior, haven't been > able to verify. Got Steven Birtles looking into it although it > really doesn't mean anything, talking points maybe. The idea of > repainting has previously been squashed by the wife. Thanks for the > response. > > > > Were you referring to Liberace? Don't forget the cape. LOL > > > > Leroy Eckert > > 1990 WB-40 > > Niceville, FL > > > > > > > > > > > > ----- Original Message ----- > > From: Gregory OConnor > > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, July 24, 2006 9:14 PM > > Subject: [WanderlodgeForum] Re: Paint > > > > > > Leroy, are you doing touchup or a repaint? I love the looks of > the 88 > > to 90 wbpts. Some of the stripe colors they introduced in the > 90's > > got less classic and more personal. I often wondered if BB just > > allowed customers to make these design crimes in special order > > coaches. A fun thing to do is manipulate the color of your coach > in > > a paint program. Doesn't sound like it will hurt to get creative > > with the colors if you are thinking of a repaint. > > > > while looking for a coach when I read "custom paint" it had the > same > > effect as "she's got a pretty face" > > Gregory O'Connor > > 94pt gray silver pink and green > > missing a chandelier and piano > > > > --- In WanderlodgeForum@yahoogroups.com, "jwasnewski" > > > > > > > > Curt: > > > I talked to Steve Birtles today about my paint codes. He says > you > > may > > > be able to decifer the numbers. I have not had success. Numbers > > > follow: > > > > > > 92329----No clue what this number means. > > > 73773----Base--Light silver--Frito-Lay Fleet I believe. > > > 81573----Stripe--there are two different colored stripes. > > > 79780----Light > > > 81735----Dark > > > > > > Colors are---Light silver, dark silver, turquoise stripe, > salmon? > > > mauve? stripe. > > > > > > Thanks: > > > > > > Leroy Eckert > > > 1990-WB-40 > > > Niceville, FL > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
07-26-2006, 13:09
Paint
--Leroy 79773-Indian silver met ford motor co. Would like to help
but the freight would be more than the paint cost Check BASF.com for a paint dist. near you. Lee Condosta Holden Beach N.C 85PT40 In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" wrote: > > Lee: Thanks much for the reply. A double check shows 73773 should have been 79773. The 92329 number is stamped in the upper left hand corner of the paint code sticker. So, 79773 is the correct number. Can I purchase the paint from you? I haven't found any locally. Need it for touch up purposes. What is the shelf life? > > Leroy Eckert > 1990 WB-40 > Niceville, FL > > > > ----- Original Message ----- > From: lcondosta > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, July 24, 2006 8:01 PM > Subject: [WanderlodgeForum] Re: Paint > > > 81573 med lagoon met ford motor co 79780cumulus gray met ford motor > co 81735 rose met ford motor co other two must be wrong codes Lee > A Condosta BASF Jobber Holden Beach N.C 85PT40--- In > WanderlodgeForum@yahoogroups.com, "jwasnewski" > wrote: > > > > Curt: > > I talked to Steve Birtles today about my paint codes. He says you > may > > be able to decifer the numbers. I have not had success. Numbers > > follow: > > > > 92329----No clue what this number means. > > 73773----Base--Light silver--Frito-Lay Fleet I believe. > > 81573----Stripe--there are two different colored stripes. > > 79780----Light > > 81735----Dark > > > > Colors are---Light silver, dark silver, turquoise stripe, salmon? > > mauve? stripe. > > > > Thanks: > > > > Leroy Eckert > > 1990-WB-40 > > Niceville, FL > > > > > > > > [Non-text portions of this message have been removed] > |
07-26-2006, 16:57
Paint
Leroy, If you get back to California look me up. Romoland is south
of March Air Field. A scratch here or there adds character. Wonder if a BB Bird decal would do the trick. Gregory O'Connor 94ptRomoland Ca In WanderlodgeForum@yahoogroups.com, "jwasnewski" wrote: > > Gregory: I did think about shading differences etc. You are > probably correct. I may get a bid from the local paint shop. The > area that I screwed up is on the entry door, maybe 2x3. Didn't dent > anything, just scratched and chipped the paint, obviously right where > I can constantly see the damage. Thanks for the input. > Been gone from CA for awhile. Isn't Romoland between Riverside and > Temecula or Hemet? Lived in Riverside for 25yrs > > Leroy Eckert > 1990WB-40 > Niceville, FL > > > > > > > > > > -- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > leroy, if it is touchup I would just take the bus to a good dealer > > autobody shop and get an out the door quote ( may be less expensive > > than you think). Chances are that the paint color will change with > > the transfering out of the 1990's restricted formulas. and in > the > > quart mininum mix quantities you will need you are talking over > 400. > > bucks. A good shop can site mix and blend. you won't get the code > > excuse "but sir that is the paint code you ordered." Prism in the > > metalic paints is also something that will be hard to match unless > > you have special skills. maybe the paint code is a royal number. > Bob > > and Dixie G have a 92 Royal conversion, I wonder if they have info > on > > the codes. > > Gregory O'Connor > > 94pt no Royality > > Romoland Ca > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > > > > Gregory: Not thinking about a repainting. The paint is in > > fabulous shape, not a scratch anyplace except a couple of recent > > chips that I did while changing the broken end of the main Zip Dee > > awning brace. I dropped the main awning on the side of the coach. > > Ouch! Dumb! It could have been worse. > > > > > > I don't know about the paint or design on our girlie bus--- > > turquoise and rose over two tone gray---but our interior was > altered > > by the original owner during construction. Our interior is top > > notch. I have been told that Royal did the interior, haven't been > > able to verify. Got Steven Birtles looking into it although it > > really doesn't mean anything, talking points maybe. The idea of > > repainting has previously been squashed by the wife. Thanks for > the > > response. > > > > > > Were you referring to Liberace? Don't forget the cape. LOL > > > > > > Leroy Eckert > > > 1990 WB-40 > > > Niceville, FL > > > > > > > > > > > > > > > > > > ----- Original Message ----- > > > From: Gregory OConnor > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Monday, July 24, 2006 9:14 PM > > > Subject: [WanderlodgeForum] Re: Paint > > > > > > > > > Leroy, are you doing touchup or a repaint? I love the looks of > > the 88 > > > to 90 wbpts. Some of the stripe colors they introduced in the > > 90's > > > got less classic and more personal. I often wondered if BB just > > > allowed customers to make these design crimes in special order > > > coaches. A fun thing to do is manipulate the color of your > coach > > in > > > a paint program. Doesn't sound like it will hurt to get > creative > > > with the colors if you are thinking of a repaint. > > > > > > while looking for a coach when I read "custom paint" it had the > > same > > > effect as "she's got a pretty face" > > > Gregory O'Connor > > > 94pt gray silver pink and green > > > missing a chandelier and piano > > > > > > --- In WanderlodgeForum@yahoogroups.com, "jwasnewski" > > > > > > > > > > > Curt: > > > > I talked to Steve Birtles today about my paint codes. He says > > you > > > may > > > > be able to decifer the numbers. I have not had success. > Numbers > > > > follow: > > > > > > > > 92329----No clue what this number means. > > > > 73773----Base--Light silver--Frito-Lay Fleet I believe. > > > > 81573----Stripe--there are two different colored stripes. > > > > 79780----Light > > > > 81735----Dark > > > > > > > > Colors are---Light silver, dark silver, turquoise stripe, > > salmon? > > > > mauve? stripe. > > > > > > > > Thanks: > > > > > > > > Leroy Eckert > > > > 1990-WB-40 > > > > Niceville, FL > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > |
07-26-2006, 23:42
Paint
Gregory: Hopefully we can travel to CA next summer. Sounds like I'll need a
class A license pulling a trailer. 7000 pound flat trailer with auto. The grandkids go back to school next week, that will limit our travel area. Leaving this afternoon for the IHBA boat drags in Gadsden, Alabama. My friend Don Ermshar, Riverside, CA is currently second in points, Blown Alchohol Flat Bottom doing 178MPH in the 1/4, on water. He's now 65 and has a screw loose. Also have friends in Hemet, Temecula and Aguanga. Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Gregory OConnor To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, July 26, 2006 11:57 PM Subject: [WanderlodgeForum] Re: Paint Leroy, If you get back to California look me up. Romoland is south of March Air Field. A scratch here or there adds character. Wonder if a BB Bird decal would do the trick. Gregory O'Connor 94ptRomoland Ca In WanderlodgeForum@yahoogroups.com, "jwasnewski" wrote: > > Gregory: I did think about shading differences etc. You are > probably correct. I may get a bid from the local paint shop. The > area that I screwed up is on the entry door, maybe 2x3. Didn't dent > anything, just scratched and chipped the paint, obviously right where > I can constantly see the damage. Thanks for the input. > Been gone from CA for awhile. Isn't Romoland between Riverside and > Temecula or Hemet? Lived in Riverside for 25yrs > > Leroy Eckert > 1990WB-40 > Niceville, FL > > > > > > > > > > -- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > leroy, if it is touchup I would just take the bus to a good dealer > > autobody shop and get an out the door quote ( may be less expensive > > than you think). Chances are that the paint color will change with > > the transfering out of the 1990's restricted formulas. and in > the > > quart mininum mix quantities you will need you are talking over > 400. > > bucks. A good shop can site mix and blend. you won't get the code > > excuse "but sir that is the paint code you ordered." Prism in the > > metalic paints is also something that will be hard to match unless > > you have special skills. maybe the paint code is a royal number. > Bob > > and Dixie G have a 92 Royal conversion, I wonder if they have info > on > > the codes. > > Gregory O'Connor > > 94pt no Royality > > Romoland Ca > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > > > > Gregory: Not thinking about a repainting. The paint is in > > fabulous shape, not a scratch anyplace except a couple of recent > > chips that I did while changing the broken end of the main Zip Dee > > awning brace. I dropped the main awning on the side of the coach. > > Ouch! Dumb! It could have been worse. > > > > > > I don't know about the paint or design on our girlie bus--- > > turquoise and rose over two tone gray---but our interior was > altered > > by the original owner during construction. Our interior is top > > notch. I have been told that Royal did the interior, haven't been > > able to verify. Got Steven Birtles looking into it although it > > really doesn't mean anything, talking points maybe. The idea of > > repainting has previously been squashed by the wife. Thanks for > the > > response. > > > > > > Were you referring to Liberace? Don't forget the cape. LOL > > > > > > Leroy Eckert > > > 1990 WB-40 > > > Niceville, FL > > > > > > > > > > > > > > > > > > ----- Original Message ----- > > > From: Gregory OConnor > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Monday, July 24, 2006 9:14 PM > > > Subject: [WanderlodgeForum] Re: Paint > > > > > > > > > Leroy, are you doing touchup or a repaint? I love the looks of > > the 88 > > > to 90 wbpts. Some of the stripe colors they introduced in the > > 90's > > > got less classic and more personal. I often wondered if BB just > > > allowed customers to make these design crimes in special order > > > coaches. A fun thing to do is manipulate the color of your > coach > > in > > > a paint program. Doesn't sound like it will hurt to get > creative > > > with the colors if you are thinking of a repaint. > > > > > > while looking for a coach when I read "custom paint" it had the > > same > > > effect as "she's got a pretty face" > > > Gregory O'Connor > > > 94pt gray silver pink and green > > > missing a chandelier and piano > > > > > > --- In WanderlodgeForum@yahoogroups.com, "jwasnewski" > > > > > > > > > > > Curt: > > > > I talked to Steve Birtles today about my paint codes. He says > > you > > > may > > > > be able to decifer the numbers. I have not had success. > Numbers > > > > follow: > > > > > > > > 92329----No clue what this number means. > > > > 73773----Base--Light silver--Frito-Lay Fleet I believe. > > > > 81573----Stripe--there are two different colored stripes. > > > > 79780----Light > > > > 81735----Dark > > > > > > > > Colors are---Light silver, dark silver, turquoise stripe, > > salmon? > > > > mauve? stripe. > > > > > > > > Thanks: > > > > > > > > Leroy Eckert > > > > 1990-WB-40 > > > > Niceville, FL > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] |
07-27-2006, 03:50
Paint
Leroy, Class A is needed for trailers at and above 10,000# GVW even
if they are empty. 5th wheel at or above 15,000# GVW. CHP pulls out these rules when it looks like the driver is being unsafe. The easiest way to beat a ticket is by default - when the CHP officer does not showup in court. I was cited by a Officer J Kennedy and rescheduled court for 'Good Friday'. When Officer H. Grinblatt gave me a ticket I rescheduled for the start of 'Yom Kippur'. My most recent ticket was isued by Officer Ms. Kimberly C. I sent a check. Women can multitask. Gregory O'Connor 94ptRomoland Ca --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Gregory: Hopefully we can travel to CA next summer. Sounds like I'll need a class A license pulling a trailer. 7000 pound flat trailer with auto. The grandkids go back to school next week, that will limit our travel area. Leaving this afternoon for the IHBA boat drags in Gadsden, Alabama. My friend Don Ermshar, Riverside, CA is currently second in points, Blown Alchohol Flat Bottom doing 178MPH in the 1/4, on water. He's now 65 and has a screw loose. Also have friends in Hemet, Temecula and Aguanga. > > Leroy Eckert > 1990 WB-40 > Niceville, FL > > > > > > > > ----- Original Message ----- > From: Gregory OConnor > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, July 26, 2006 11:57 PM > Subject: [WanderlodgeForum] Re: Paint > > > Leroy, If you get back to California look me up. Romoland is south > of March Air Field. A scratch here or there adds character. Wonder > if a BB Bird decal would do the trick. > Gregory O'Connor > 94ptRomoland Ca > > In WanderlodgeForum@yahoogroups.com, "jwasnewski" > wrote: > > > > Gregory: I did think about shading differences etc. You are > > probably correct. I may get a bid from the local paint shop. The > > area that I screwed up is on the entry door, maybe 2x3. Didn't > dent > > anything, just scratched and chipped the paint, obviously right > where > > I can constantly see the damage. Thanks for the input. > > Been gone from CA for awhile. Isn't Romoland between Riverside and > > Temecula or Hemet? Lived in Riverside for 25yrs > > > > Leroy Eckert > > 1990WB-40 > > Niceville, FL > > > > > > > > > > > > > > > > > > > > -- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > > > > leroy, if it is touchup I would just take the bus to a good > dealer > > > autobody shop and get an out the door quote ( may be less > expensive > > > than you think). Chances are that the paint color will change > with > > > the transfering out of the 1990's restricted formulas. and in > > the > > > quart mininum mix quantities you will need you are talking over > > 400. > > > bucks. A good shop can site mix and blend. you won't get the > code > > > excuse "but sir that is the paint code you ordered." Prism in the > > > metalic paints is also something that will be hard to match > unless > > > you have special skills. maybe the paint code is a royal number. > > Bob > > > and Dixie G have a 92 Royal conversion, I wonder if they have > info > > on > > > the codes. > > > Gregory O'Connor > > > 94pt no Royality > > > Romoland Ca > > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > > > > > > > Gregory: Not thinking about a repainting. The paint is in > > > fabulous shape, not a scratch anyplace except a couple of recent > > > chips that I did while changing the broken end of the main Zip > Dee > > > awning brace. I dropped the main awning on the side of the > coach. > > > Ouch! Dumb! It could have been worse. > > > > > > > > I don't know about the paint or design on our girlie bus--- > > > turquoise and rose over two tone gray---but our interior was > > altered > > > by the original owner during construction. Our interior is top > > > notch. I have been told that Royal did the interior, haven't > been > > > able to verify. Got Steven Birtles looking into it although it > > > really doesn't mean anything, talking points maybe. The idea of > > > repainting has previously been squashed by the wife. Thanks for > > the > > > response. > > > > > > > > Were you referring to Liberace? Don't forget the cape. LOL > > > > > > > > Leroy Eckert > > > > 1990 WB-40 > > > > Niceville, FL > > > > > > > > > > > > > > > > > > > > > > > > ----- Original Message ----- > > > > From: Gregory OConnor > > > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Monday, July 24, 2006 9:14 PM > > > > Subject: [WanderlodgeForum] Re: Paint > > > > > > > > > > > > Leroy, are you doing touchup or a repaint? I love the looks > of > > > the 88 > > > > to 90 wbpts. Some of the stripe colors they introduced in the > > > 90's > > > > got less classic and more personal. I often wondered if BB > just > > > > allowed customers to make these design crimes in special > order > > > > coaches. A fun thing to do is manipulate the color of your > > coach > > > in > > > > a paint program. Doesn't sound like it will hurt to get > > creative > > > > with the colors if you are thinking of a repaint. > > > > > > > > while looking for a coach when I read "custom paint" it had > the > > > same > > > > effect as "she's got a pretty face" > > > > Gregory O'Connor > > > > 94pt gray silver pink and green > > > > missing a chandelier and piano > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "jwasnewski" > > > > > > > > > > > > > > Curt: > > > > > I talked to Steve Birtles today about my paint codes. He > says > > > you > > > > may > > > > > be able to decifer the numbers. I have not had success. > > Numbers > > > > > follow: > > > > > > > > > > 92329----No clue what this number means. > > > > > 73773----Base--Light silver--Frito-Lay Fleet I believe. > > > > > 81573----Stripe--there are two different colored stripes. > > > > > 79780----Light > > > > > 81735----Dark > > > > > > > > > > Colors are---Light silver, dark silver, turquoise stripe, > > > salmon? > > > > > mauve? stripe. > > > > > > > > > > Thanks: > > > > > > > > > > Leroy Eckert > > > > > 1990-WB-40 > > > > > Niceville, FL > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > |
