Air Bag System
07-29-2006, 12:02
Air Bag System
Is it normal to hear air escaping from system?
Under the coach, driver's side, just behind the front bumper, is an air
fitting that continually leaks air. I have tried plugging this off but the air
bags didn't fill properly so I removed the plug.
If I shut the engine off and don't purge the air, the front bags leak down in
30-45 min but rear stays up. This just doesn't seem normal.
I'm taking the coach in Monday for some other work. Would appreciate any
information on what to tell the shop folks as they are not really familiar with
BB systems.
Thanks!
Alex Smith
82FC35
Tallahassee
Do You Yahoo!?
http://mail.yahoo.com
07-29-2006, 13:21
Air Bag System
This is the vacuum generator (aspirator) for the cruise-control
system in the '79-mid'83 FC. It blows air through a venturi to create
the vacuum.
If it is venting constantly or frequently, you likely have a vacuum
leak, check the vacuum lines at the rear of the engine.
- Jeff Miller
in Holland, MI
--- In WanderlodgeForum@yahoogroups.com, Alex Smith
an air fitting that continually leaks air. I have tried plugging this
off but the air bags didn't fill properly so I removed the plug.
leak down in 30-45 min but rear stays up. This just doesn't seem
normal.
appreciate any information on what to tell the shop folks as they are
not really familiar with BB systems.
> Thanks!
> Alex Smith
> 82FC35
> Tallahassee
> Do You Yahoo!?
07-29-2006, 13:42
Air Bag System
That happened with our '81FC and it had something to do with the cruise control.
I'm sorry I don't have any of the particulars as those were in the days when we
were taking the bird to the BB bus shop for repairs. However, it also went down
in front first even after the audible leak was fixed. As I recall though the
part that produces vacuum for the cruise control was defective. I found where
the air was venting and plugged it but that didn't work. Does that make sense?
Good luck.
To: wanderlodgeforum@yahoogroups.com
Sent: Saturday, July 29, 2006 5:02 PM
Subject: [WanderlodgeForum] Air Bag System
BB systems.
Thanks!
Alex Smith
82FC35
Tallahassee
Do You Yahoo!?
http://mail.yahoo.com<http://mail.yahoo.com/>
07-31-2006, 01:26
Air Bag System
Jeff, the coach is in the shop today so I'll ask them to check for a leak. The
air is coming from what looks like where another air line would be attached.
Would this be what the venturi looks like? Thanks.
Alex
82FC35
Tallahassee
the vacuum.
- Jeff Miller
in Holland, MI
normal.
> Thanks!
> Alex Smith
> 82FC35
> Tallahassee
> Do You Yahoo!?
Do you Yahoo!?
Next-gen email? Have it all with the all-new Yahoo! Mail Beta.
07-31-2006, 01:41
Air Bag System
Thanks Richard, I tried the same. And it doen't make sense unless this is just
the way it works. All this information helps.
Alex
cruise control. I'm sorry I don't have any of the particulars as those were in
the days when we were taking the bird to the BB bus shop for repairs. However,
it also went down in front first even after the audible leak was fixed. As I
recall though the part that produces vacuum for the cruise control was
defective. I found where the air was venting and plugged it but that didn't
Good luck.
Under the coach, driver's side, just behind the front bumper, is an air fitting
that continually leaks air. I have tried plugging this off but the air bags
BB systems.
Thanks!
Alex Smith
82FC35
Tallahassee
Do You Yahoo!?
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+
countries) for 2¢/min or less.
