shore power connection
08-11-2006, 08:24
I don't seem to have a cable that would plug into 30amp shore power and
50amp recep. on the coach. Where can I find the 50amp male end that
fits our coach? It looks like the manufacturer is arrow hart, but I'm
not having any luck finding one.
Tom Sorrentino
Bedford Hills, NY
1987 PT38
1978 33' FC for not much longer
08-11-2006, 08:28
Tom:
Congrats on the new Coach. I thought the "blue" cord was a 50amp Coach end
to 30 amp. Or you do have an adapter for your 50 amp cord.
Ralph
Safe travels,
>Tom Sorrentino
>Bedford Hills, NY
>1987 PT38
08-11-2006, 08:31
Never mind, the blue cord is a 30 to 30. But I thought there was an adapter
50 to 30 in the side compartment.
Ralph
At 03:28 PM 8/11/2006 -0500, you wrote:
>Tom:
>Ralph
>Safe travels,
08-11-2006, 10:05
30 amp to 50 amp adaptors are available at RV outlets like Camping
World (you can order online). Walmart may have them as well.
One thing to note is that 30 amps is only 110 v, so the jump from 50
to 30 amps is a reduction in available power by about 2/3...
Pete Masterson
aeonix1@...
'95 Bluebird Wanderlodge WBDA 4203
El Sobrante, CA
> and
> Tom Sorrentino
> Bedford Hills, NY
> 1987 PT38
> Yahoo! Groups Links
08-11-2006, 12:36
Pete; Thank you. My coach has the standard 50amp connection and below that a
factory twist on 30amp connection.
I will try to connect the 30amp cord to the 50amp cord and see if the batteries
charge through the inverter curcuit. I do not plan on using that configuration
often, but you never know.
Thanks again.
Leroy Eckert
1990 WB40
Niceville, FL
Sent: Friday, August 11, 2006 5:05 PM
Subject: Re: [WanderlodgeForum] shore power connection
Pete Masterson
aeonix1@...
El Sobrante, CA
> and
> Tom Sorrentino
> Bedford Hills, NY
> 1987 PT38
> Yahoo! Groups Links
08-12-2006, 07:08
Pete,
The thought never crossed my mind about using the 50 amp cord and just
adapting it down to 30 amps at the shore power connection. This would
work fine for me, the only disadvantage I can see is having to deal
with the heavier cord, which is fine with me. Thanks you saved me a lot
of work.
Tom Sorrentino
Bedford Hills, NY
1987 PT38
1978 FC 33' (not for long)
--- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino"
> Tom Sorrentino
> Bedford Hills, NY
> 1987 PT38
