3208 boost
08-22-2006, 09:10
3208 boost
I recently installed a new 3208 250 HP in my 82 FC. I am currently
getting 10 psi of boost after turning up the fuel to boost pressure ration on the fuel pump. I still think the engine is not putting out and was wondering what boost pressure other owners are getting for max boost pressure on the 250 HP. Currently the coach is not sending cat black smoke out, and it is kind of nice not having people look at me like I just cut down the rain forest. Any input would be appreciated including tricks to max out the power. Thanks, Jim 82 FC Yorba Linda, CA |
08-22-2006, 13:57
3208 boost
Jim,
I assume you didn't do the upgrade in your back yard, so what does the outfit that installed it have to say? I would expect it was pretty expensive to do the upgrade, so I would hope they would do it right, or correct any deficiencies. Gardner 78FC33 (NA 3208) --- In WanderlodgeForum@yahoogroups.com, "bluebird3208" wrote: > > I recently installed a new 3208 250 HP in my 82 FC. I am currently > getting 10 psi of boost after turning up the fuel to boost pressure > ration on the fuel pump. I still think the engine is not putting out > and was wondering what boost pressure other owners are getting for max > boost pressure on the 250 HP. Currently the coach is not sending cat > black smoke out, and it is kind of nice not having people look at me > like I just cut down the rain forest. > > Any input would be appreciated including tricks to max out the power. > > Thanks, > > Jim > 82 FC > Yorba Linda, CA > |
08-22-2006, 13:58
3208 boost
Talk to Mike Hohnstein
that grumpy old fart has probably done more to the 3208 than anyone on this forum and he is continually trying to coax more power out of his cats. he is the most knowledgable guy I know on the subject of 3208 Stephen 77fc35 stuck with 210 --- In WanderlodgeForum@yahoogroups.com, "bluebird3208" > > I recently installed a new 3208 250 HP in my 82 FC. I am currently > getting 10 psi of boost after turning up the fuel to boost pressure > ration on the fuel pump. I still think the engine is not putting out > and was wondering what boost pressure other owners are getting for max > boost pressure on the 250 HP. Currently the coach is not sending cat > black smoke out, and it is kind of nice not having people look at me > like I just cut down the rain forest. > > Any input would be appreciated including tricks to max out the power. > > Thanks, > > Jim > 82 FC > Yorba Linda, CA > |
08-22-2006, 14:00
3208 boost
Jim,
10# on my 84 FC. It has a Cat reman pump on it that I assume is at factory specs. David Hollis 84FC35 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, "bluebird3208" wrote: > > I recently installed a new 3208 250 HP in my 82 FC. I am currently > getting 10 psi of boost after turning up the fuel to boost pressure > ration on the fuel pump. I still think the engine is not putting out > and was wondering what boost pressure other owners are getting for max > boost pressure on the 250 HP. Currently the coach is not sending cat > black smoke out, and it is kind of nice not having people look at me > like I just cut down the rain forest. > > Any input would be appreciated including tricks to max out the power. > > Thanks, > > Jim > 82 FC > Yorba Linda, CA > |
08-22-2006, 14:56
3208 boost
Break it in nicely first.
My 250s developed around 1bar/15psi at full-chat on a good climb with stock settings. If you have to make smoke to get this boost, you're overfueling, shouldn't be necessary. Are you getting enough air and fuel? Also, your coach doesn't have an electric fuel pump at the tank stock, might be a good idea to add one now. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "bluebird3208" > > I recently installed a new 3208 250 HP in my 82 FC. I am currently > getting 10 psi of boost after turning up the fuel to boost pressure > ration on the fuel pump. I still think the engine is not putting out > and was wondering what boost pressure other owners are getting for max > boost pressure on the 250 HP. Currently the coach is not sending cat > black smoke out, and it is kind of nice not having people look at me > like I just cut down the rain forest. > > Any input would be appreciated including tricks to max out the power. > > Thanks, > > Jim > 82 FC > Yorba Linda, CA > |
08-22-2006, 16:31
3208 boost
Jim,
I also have a 82 fc 35' and I am considering putting in a 3208 250 hp along with a telma drive line retarder. I live in Southern Cal. Lake Arrowhead. May I ask where and who installed your 3208 250 hp and approx cost? Any info would be greatly appreciated. Jim Marsh (newbie) 82 fc 35 SB Name: "Serendipity" --- In WanderlodgeForum@yahoogroups.com, "bluebird3208" wrote: > > I recently installed a new 3208 250 HP in my 82 FC. I am currently > getting 10 psi of boost after turning up the fuel to boost pressure > ration on the fuel pump. I still think the engine is not putting out > and was wondering what boost pressure other owners are getting for max > boost pressure on the 250 HP. Currently the coach is not sending cat > black smoke out, and it is kind of nice not having people look at me > like I just cut down the rain forest. > > Any input would be appreciated including tricks to max out the power. > > Thanks, > > Jim > 82 FC > Yorba Linda, CA > |
08-23-2006, 00:17
3208 boost
---JIM:
When they overhauled my 210 80FC31, they put in three ring pistons!! Also have a 4.88 rear end.....no problem going down the road at 75mph. usually travel at 60 mph. Regards, Hank Hannigan 80FC31 90SP36 In WanderlodgeForum@yahoogroups.com, "chunkymar" wrote: > > Jim, > I also have a 82 fc 35' and I am considering putting in a 3208 250 > hp along with a telma drive line retarder. I live in Southern Cal. > Lake Arrowhead. May I ask where and who installed your 3208 250 hp > and approx cost? Any info would be greatly appreciated. > > Jim Marsh (newbie) > 82 fc 35 SB Name: "Serendipity" > > --- In WanderlodgeForum@yahoogroups.com, "bluebird3208" > wrote: > > > > I recently installed a new 3208 250 HP in my 82 FC. I am currently > > getting 10 psi of boost after turning up the fuel to boost pressure > > ration on the fuel pump. I still think the engine is not putting > out > > and was wondering what boost pressure other owners are getting for > max > > boost pressure on the 250 HP. Currently the coach is not sending > cat > > black smoke out, and it is kind of nice not having people look at > me > > like I just cut down the rain forest. > > > > Any input would be appreciated including tricks to max out the > power. > > > > Thanks, > > > > Jim > > 82 FC > > Yorba Linda, CA > > > |
08-23-2006, 00:38
3208 boost
---I should add that my 210 80FC31 STILL flips the bird at
HILLS...does not like hills!!!! LOL Hank In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > ---JIM: > When they overhauled my 210 80FC31, they put in three ring pistons!! > Also have a 4.88 rear end.....no problem going down the road at > 75mph. > usually travel at 60 mph. > Regards, > Hank Hannigan > 80FC31 > 90SP36 > > > > > > > > > > > In WanderlodgeForum@yahoogroups.com, "chunkymar" > wrote: > > > > Jim, > > I also have a 82 fc 35' and I am considering putting in a 3208 250 > > hp along with a telma drive line retarder. I live in Southern > Cal. > > Lake Arrowhead. May I ask where and who installed your 3208 250 > hp > > and approx cost? Any info would be greatly appreciated. > > > > Jim Marsh (newbie) > > 82 fc 35 SB Name: "Serendipity" > > > > --- In WanderlodgeForum@yahoogroups.com, "bluebird3208" > > wrote: > > > > > > I recently installed a new 3208 250 HP in my 82 FC. I am > currently > > > getting 10 psi of boost after turning up the fuel to boost > pressure > > > ration on the fuel pump. I still think the engine is not > putting > > out > > > and was wondering what boost pressure other owners are getting > for > > max > > > boost pressure on the 250 HP. Currently the coach is not > sending > > cat > > > black smoke out, and it is kind of nice not having people look > at > > me > > > like I just cut down the rain forest. > > > > > > Any input would be appreciated including tricks to max out the > > power. > > > > > > Thanks, > > > > > > Jim > > > 82 FC > > > Yorba Linda, CA > > > > > > |
08-23-2006, 01:20
3208 boost
Jim, with the hill you have to run up and down, the best modification
to make is a ForSale sign. Tannys and cooling systems changed with hp increases and the drivline retarder may not be matched for driveline design. You would best ask someone with a 250hp rig to run up and down that hill before you make any mods. That would give you a feel of the added power and best case result. I love the classic looks of the 82-35, and it would be nice if you were able to make it powerfull enough to be safe on your hill. Gregory O'Connor Romoland Ca in plain view of Lake Arrowhead --- In WanderlodgeForum@yahoogroups.com, "chunkymar" wrote: > > Jim, > I also have a 82 fc 35' and I am considering putting in a 3208 250 > hp along with a telma drive line retarder. I live in Southern Cal. > Lake Arrowhead. May I ask where and who installed your 3208 250 hp > and approx cost? Any info would be greatly appreciated. > > Jim Marsh (newbie) > 82 fc 35 SB Name: "Serendipity" > > --- In WanderlodgeForum@yahoogroups.com, "bluebird3208" > wrote: > > > > I recently installed a new 3208 250 HP in my 82 FC. I am currently > > getting 10 psi of boost after turning up the fuel to boost pressure > > ration on the fuel pump. I still think the engine is not putting > out > > and was wondering what boost pressure other owners are getting for > max > > boost pressure on the 250 HP. Currently the coach is not sending > cat > > black smoke out, and it is kind of nice not having people look at > me > > like I just cut down the rain forest. > > > > Any input would be appreciated including tricks to max out the > power. > > > > Thanks, > > > > Jim > > 82 FC > > Yorba Linda, CA > > > |
08-23-2006, 01:58
3208 boost
I've got an 82 FC 35 to which a Thelma retarder has been retrofitted
(in 84). I like it a lot. It was not cheap. By memory, I think the cost was around $5k based on the paperwork in the Bluebox. In steep terrain it is hard to beat. It also has a turbo retrofitted to a 210hp NA. Since I have only driven it with the turbo, and never driven either a 210na or a 'real' 250hp turbo I can't help with the performance comparison. I can say however, that were I required to climb 2 or 3k' every day in the coach, I would not be satsified. I am quite happy on flat roads. If my NA (with aftermarket turbo) were to fail, I would probably install a 250hp turbo which would probably also require changes in the transmission and rear end. However, I'm of the opinion that removing a 210hp NA and replacing it with a 250hp turbo at a cost of (??$15K) would not produce enough of a performance difference to justify the expense. It cost the original owner of my coach about $5k to add the turbo. From the little remaining evidence of his satsifaction with the choice, I'm making an educated guess that he was not impressed. Kerry 82 FC 35 Denver |
