Back Up Camera
08-25-2006, 12:11
Back Up Camera
Hi,
I need to replace my Sanyo VDC 2512 black/white back up camera. I have
done a web search and can't find that exact model number. Can anyone
tell me where I can find a Sanyo replacement or recommend another
comparable camera? I don't have time to be modifying the box where the
camera sits, so I need something that will mount like the Sanyo.
Any help will be greatly appreciated.
Randy Merrill
1993 WLWB
Ocala, Florida
08-25-2006, 12:19
Back Up Camera
Randy
Go to http://rvcams.com/ call Tim he might even be there yet tonight, he
works long hours. He did a great job for me.
Steve Quandt
1993-PT40
Iron Mountain, Mi
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Randy Merrill
Sent: Friday, August 25, 2006 7:11 PM
Subject: [WanderlodgeForum] Back Up Camera
Hi,
Randy Merrill
1993 WLWB
Ocala, Florida
08-25-2006, 17:51
Back Up Camera
Hi Randy,
I have a B & W camera that I replaced with a Sony color setup. My monitor went
bad and became intermittent. I have no idea what the camera is worth. (If I
can still find it). I saved the camera & monitor because I've heard that
someone on the forum fixes the monitors. Anyway, I'm not going to use either.
Make an offer if interested in the camera.
Sent: Friday, August 25, 2006 5:11 PM
Hi,
Randy Merrill
1993 WLWB
Ocala, Florida
08-25-2006, 23:36
Back Up Camera
Randy,
Not knowing your problem Let me tell you about mine. My camera picture would
flicker badly. I took it out took out the circuit board and checked the solder
joints on the back. about 4 or 5 were cracked. I resoldered put camera back in
and it works beautiful. I had afuzzy picture and I took the cover off of the
camera there is a piece of 1/4 inch plexi glass in the cover it had crazed
badly. I replaced it and now have a stable clear picture. Saved several hundred
dollars to buy fuel with.
Howard Truitt
Camilla, Ga.
86 8V92 PT40
Sent: Friday, August 25, 2006 8:11 PM
Hi,
Randy Merrill
1993 WLWB
Ocala, Florida
Checked by AVG Free Edition.
Version: 7.1.405 / Virus Database: 268.11.5/425 - Release Date: 8/22/2006
08-26-2006, 04:18
Back Up Camera
I concur with the recommendation of http://www.rvcams.com Tim helped me immensely.
For around $400 I put in a colour flat panel monitor and new rear camera. I
used existing coaxial cable with a Radio Shack S/Coax adapter. I have
pictures of dash install and rear camera install if interested.
On 25/08/06, Randy Merrill wrote:
> Hi,
> Randy Merrill
> 1993 WLWB
> Ocala, Florida
Rob, Sue & Merlin Robinson
94 WLWB
08-26-2006, 06:01
Back Up Camera
Rob,COLOUR monitor are they 50 Hertz?
GregoryO'Connor
94pt
NotFromNiceville
--- In WanderlodgeForum@yahoogroups.com, "Rob Robinson"
immensely.
camera. I
have
> > Hi,
have
anyone
where the
> > Randy Merrill
> > 1993 WLWB
> > Ocala, Florida
> 94 WLWB
08-26-2006, 06:46
Back Up Camera
Greg here are the specs for the particular system I bought......
*Complete Specs for 68-CHNV*
*Camera Specs:* TV System NTSC Image Sensor Panasonic 1/4" CCD CCD
Effective Pixels (NTSC)510(H) x 492(V) Resolution 380 TV lines Horizontal
Sync Frequency EIA: 15.750 khz -- CCIR:15.625 khz Scanning System 2:1
Interlace Sensitivity 0 lux (IR On), with >30' IR Range SYNC System
Internal Signal
to Noise Ratio better than 48dB Electronic Shutter
(NTSC)1/60-1/100,000 sec. Gamma
Correction 0.45 Lens f 2.5 mm Video Output 1.0 Vp-p composite video at 75
ohm Backlight Compensation Automatic Gain Control AGC Power Supply DC 12V
(+/-10%), 125 ma Weight 480 gr Storage Temperature -22°F to 140°F Operation
Temperature 32°F to 122°F View Angle 130° diagonally -- 78°/104° Ver/Hor
Construction Aluminum, with painted finish Dimensions 3.75"w x 3.20"h x 2.64
"d *Monitor Specs:* Display TFT Color LCD Exterior Dimensions (6.8) 6.77"W
x 5.6"H x 1.25"D Display Dimensions 5-7/16" W x 4-1/8"H Number of Pixels
268,568 Screen Size 6.8" Diagonally LCD Display Dots 1152(H)x234(V)
System Selectable
NTSC or PAL Input Signal 1.0 V p-p Composite at 75 ohms Power Source
DC 12V Operation
Temperature 23 °F to 122 °F Storage Temperature -13 °F to 158 °F Power
Consumption 6 watts max Weight 1.05 lbs Inputs 2 audio/video
> GregoryO'Connor
> 94pt
> NotFromNiceville
> "Rob Robinson"
> immensely.
> camera. I
> have
> > > Hi,
> have
> anyone
> where the
> > > Randy Merrill
> > > 1993 WLWB
> > > Ocala, Florida
> > 94 WLWB
94 WLWB
08-27-2006, 05:38
Back Up Camera
Rob, is it worth an upgrade from the factory B&W system? and is there
a way to get intercom to enhance voice contact with
lookout 'ComeOnBack' person?
When I back up my Dumptruck and trailer I get out and take a walk
around then I place a mini cone next to landmarks. Never do I hit a
thing, no camera, life is stressfree and easy. However backing up
the bus is very stressful as the copilot says "I'll look" and my walk
around review would spark a 'you have no trust debate'. Who wants to
start a trip this way.
As I back up I hear "a little to the right". My question is "my
right or your right" Then I hear "we are facing the same way what do
you think". I respond "I shouldn't be thinking, you are directing
me, just point, damit" Then I see clearly in the monitor a single
digit reply. This is the only time I can see a command as every
other time he is in view of a mirror or the camera and only an arm
in one and a torso in the other.
Then a new sign language, hands to the side, what's that mean? As
he starts to push on the bumper I realize the Umpire SAFE sign L is
equivalent to Bus driver STOP sign L. Then the walk to the drivers
window. The pace is reminiscent of an Umpite walk to the mound, does
the repeated over exaggerated 'He's safe motion' evoke a Baseball
authority ambition in someone? As he approaches I adjust my cup and
wait for his first pitch. The co pilot says "when I do this ( he
motions safe)it means stop". I hold my arms out forward, thumbs side
by side, palms facing him and say "I thought this meant stop". He
replies "that means, Ouh - hay - Beep -Beep, are you wearing double
knit polyester or something". I reply "What?, are you Donna Sommers
now?, this aint a Prevost, no Discoball hanging in the galley". I
then jump out of my seat, take a walk around, place some landmark
indicators and back the bus in safe. I often wondered if the
nightstand placed rear and center was a selling feature in the
classic FC's, prompted by backup /setup anxiety.
GregoryO'Connor
94ptRomolandCA
CCD
Horizontal
2:1
> Internal Signal
at 75
DC 12V
Operation
Ver/Hor
3.20"h x 2.64
(6.8) 6.77"W
Pixels
> System Selectable
> DC 12V Operation
Power
> > GregoryO'Connor
> > 94pt
> > NotFromNiceville
> > --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> > "Rob Robinson"
> > immensely.
rear
> > camera. I
> > have
> > > > Hi,
camera. I
> > have
> > anyone
another
> > where the
Sanyo.
> > > > Randy Merrill
> > > > 1993 WLWB
> > > > Ocala, Florida
> > > 94 WLWB
> 94 WLWB
08-27-2006, 05:59
Back Up Camera
Cheap walkie talkies, DON'T talk unless you KNOW I
am going to hit something.
Bob Janes
there
walk
to
do
does
side
double
Sommers
> GregoryO'Connor
> 94ptRomolandCA
CCD
> CCD
> Horizontal
> 2:1
System
> > Internal Signal
video
> at 75
Supply
> DC 12V
> Operation
> Ver/Hor
> 3.20"h x 2.64
> (6.8) 6.77"W
> Pixels
(V)
> > System Selectable
Source
> > DC 12V Operation
F
> Power
> > > GregoryO'Connor
> > > 94pt
> > > NotFromNiceville
> > > --- In WanderlodgeForum@yahoogroups.com > 40yahoogroups.com>,
> > > "Rob Robinson"
me
> > > immensely.
> rear
> > > camera. I
adapter. I
> > > have
interested.
> > > > > Hi,
> camera. I
> > > have
Can
> > > anyone
> another
> > > where the
> Sanyo.
> > > > > Randy Merrill
> > > > > 1993 WLWB
> > > > > Ocala, Florida
> > > > 94 WLWB
> > 94 WLWB
08-27-2006, 06:07
Back Up Camera
Hi Greg. I rarely ever back up without someone behind me, especially in an
campground. There is always the chance a small child or pet will dart in
behind. They seem to love the vacant campsite next door. I use my Backup
Camera system to watch the toad. I rarely use it for backing info. Often Sue
will notice something in the campsite that I miss (ie overhanging branches).
My old b&w system died and since it was 11 years old I didn't want to frig
with it. It has been my experience that jury-rigging-fixing something
electronic that old is often an exercise in futility and expensive. I think
b&w gives you better picture, especially at night but I opted for the colour
camera. I've heard that colour shows up fire but b&w doesn't. A fire shows
up like dust or grey smoke but the flames are not easily seen. That's not
the reason I opted for colour. Colour is cool. I think your sign-language
problem is beyond my help. You both need expert advice VBG. Kidnap the local
'flag person' and hold them ransom until they part with the secret hand
motions for traffic control.
> GregoryO'Connor
> 94ptRomolandCA
> "Rob Robinson"
> CCD
> Horizontal
> 2:1
> > Internal Signal
> at 75
> DC 12V
> Operation
> Ver/Hor
> 3.20"h x 2.64
> (6.8) 6.77"W
> Pixels
> > System Selectable
> > DC 12V Operation
> Power
> > > GregoryO'Connor
> > > 94pt
> > > NotFromNiceville
> > > --- In
> > 40yahoogroups.com>,
> > > "Rob Robinson"
> > > immensely.
> rear
> > > camera. I
> > > have
> > > > > Hi,
> camera. I
> > > have
> > > anyone
> another
> > > where the
> Sanyo.
> > > > > Randy Merrill
> > > > > 1993 WLWB
> > > > > Ocala, Florida
> > > > 94 WLWB
> > 94 WLWB
94 WLWB
