dash generator start/stop switch wiring
09-05-2006, 01:51
On my 78FC33 the gen start/stop switch would only stop the genset, not
start it. The wiring diagram shows a DPDT switch, one side used for
start and the other used for stop. My kitches switch is wired that way,
but the dash switchis different. My dash switch is a DPDT with two
extra lugs (8 connections in all). It seems that both the stop and
start is run from one side of the DPDT. I moved the three connections
to the other side of the switch and now it works. So that solved the
imediate problem.
What I don't understand is what are the other two connections? There
are wires connected, but I don't know where they go. Has anyone seen
this style switch or know the function of the extra lugs?
Gardner
78FC33
09-05-2006, 02:24
Glowplugs ???. is the extra side momentary? maybe the switch was a
after factory replacement???. I have a 110 light switch in one
dumptruck that runs the fan overide, not a ford item.
GregoryO'Connor
94ptRomoland--- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw"
not
way,
connections
> imediate problem.
There
seen
> Gardner
> 78FC33
09-05-2006, 03:45
Gardner:
84 blueprint shows an 8 pin switch. attached you will find a schematic
drawing which is redrawn from the wiring diagram. Hope this helps.
Bill 84FC35SB
Terrace, B.C.
GregoryO'Connor
not
way,
connections
> imediate problem.
There
seen
> Gardner
> 78FC33
Share your photos with the people who matter at Yahoo! Canada Photos
09-05-2006, 05:18
Bill,
Thanks, I will check my e-mail when I get home. I have een going
over my documentation/drawings with a magnifying glass (literaly)and
I am slowly beginning to follow things. I just need to physically
locate many of the junctions, dtc.
Gardner
78FC33
--- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs
> Gardner:
schematic drawing which is redrawn from the wiring diagram. Hope
this helps.
> Bill 84FC35SB
> Terrace, B.C.
switch was a
> GregoryO'Connor
genset,
> not
for
that
> way,
two
> connections
> the
> > imediate problem.
> There
> seen
> > Gardner
> > 78FC33
09-05-2006, 09:16
Bill,
There was not an attachment? It may have been deleted by the board, can
you send it directly ( gcyeaw@... )
Thanks
Gardner
78FC33
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Wilhelmus Schreurs
Sent: Tuesday, September 05, 2006 11:45 AM
Subject: Re: [WanderlodgeForum] Re: dash generator start/stop switch wiring
Gardner:
Bill 84FC35SB
Terrace, B.C.
GregoryO'Connor
, "Gardner Yeaw"
not
way,
connections
> imediate problem.
There
seen
> Gardner
> 78FC33
