Over heating -- cause found
09-07-2006, 09:01
Jimmy- the Wanderlodge Pete has comes with the side radiator. The SP's have
the rear and the FC's have the front.We have an oil cooler in front of the radiator on the PT's and I suspect the newer coaches may be arranged that way, also.? [Non-text portions of this message have been removed] |
09-07-2006, 09:19
Pete My 89 SP was collecting a lot of oily dirt on the rad & after cooler
rad & I read on line that you could extend the breather tube that comes down from the engine to the rear of the coach. After a couple of years of really cleaning my rad that I had recored right I bought it I ran the pipe to the rear curb side last summer. I have my rad open right now & I will wash it but it really doesn't need it. No oily dirt on it. Don 89 SP 36' Butler, PA On the way home with my new-to-me 'bird at the end of May, I was concerned about it running on the "hot" end of the safe zone during a couple of legs of the trip ... and having significant overheating problems on the grades outside Salt Lake City coming west on I-80 in Nevada in 92 degree weather. Finally got my 'bird into a radiator shop and discovered that 35 to 40 percent of the radiator was completely plugged by a mixture of oil and dirt -- turning it practically into concrete. This has been a frequently reported problem with DD 6Vxx and 8Vxx engines (noted for tossing a bit of oil around) ... but (apparently) the Series 60 isn't immune either. What is a particular concern is that inspection of the radiator while it was in the vehicle did not reveal the blockage. Due to shrouds, AC evaporator, etc., the view of the area outside the center portion (where the fan spins) can't be seen (at least I couldn't see it clearly). The center area (where the fan spins) was open and clear (a bright light was clearly visible looking through the radiator). The fan seems to pull the crud out of that area, but there isn't enough air pressure outside the immediate area of the fan to keep other portions of the radiator clear. I suspect that all the pusher models are prone to this problem. I don't know if it's unique to my model BB or if others have better access to their radiators -- but the caution is to make cleaning the radiator and checking to be sure that it isn't clogged with the oil- dust "cement" as a regular part of annual maintenance. Since it required pulling the radiator to find the problem, I'm going ahead and replacing the core with a more modern/effective design (this is a big bucks project) so I hope to not have further heating problems for awhile. Pete Masterson _aeonix1@..._ (mailto:aeonix1@...) [Non-text portions of this message have been removed] |
09-07-2006, 09:38
concerned about it running on the "hot" end of the safe zone during a couple of legs of the trip ... and having significant overheating problems on the grades outside Salt Lake City coming west on I-80 in Nevada in 92 degree weather. Finally got my 'bird into a radiator shop and discovered that 35 to 40 percent of the radiator was completely plugged by a mixture of oil and dirt -- turning it practically into concrete. This has been a frequently reported problem with DD 6Vxx and 8Vxx engines (noted for tossing a bit of oil around) ... but (apparently) the Series 60 isn't immune either. What is a particular concern is that inspection of the radiator while it was in the vehicle did not reveal the blockage. Due to shrouds, AC evaporator, etc., the view of the area outside the center portion (where the fan spins) can't be seen (at least I couldn't see it clearly). The center area (where the fan spins) was open and clear (a bright light was clearly visible looking through the radiator). The fan seems to pull the crud out of that area, but there isn't enough air pressure outside the immediate area of the fan to keep other portions of the radiator clear. I suspect that all the pusher models are prone to this problem. I don't know if it's unique to my model BB or if others have better access to their radiators -- but the caution is to make cleaning the radiator and checking to be sure that it isn't clogged with the oil- dust "cement" as a regular part of annual maintenance. Since it required pulling the radiator to find the problem, I'm going ahead and replacing the core with a more modern/effective design (this is a big bucks project) so I hope to not have further heating problems for awhile. Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA [Non-text portions of this message have been removed] |
09-07-2006, 10:42
Pete,
I have been reading about Wanderlodges for a while and do not own one, but I can dream. But this topic comes up quite often on the Diesel RV Yahoo users group. Some pushers (like my '97 with a Cummins ISB) have the radiator in the back behind the engine and some radiators are on the side of the RV beside the engine. I have wondered about the Wanderlodges on this issue for sometime. I take it from your description, you is at the back which is prone to picking up road film. Keeping this back radiators clean is difficult. The other group suggests spraying with Simple Green and let it soak for a while then pressure wash from the back side (toward the engine) to blow it out. All, Are some new Wanderlodges side radiators? What year did they change? Thanks, Jimmy -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Pete Masterson Sent: Thursday, September 07, 2006 4:39 PM To: WanderlodgeForum@yahoogroups.com; wanderlodge@yahoogroups.com Subject: [WanderlodgeForum] Over heating -- cause found On the way home with my new-to-me 'bird at the end of May, I was concerned about it running on the "hot" end of the safe zone during a couple of legs of the trip ... and having significant overheating problems on the grades outside Salt Lake City coming west on I-80 in Nevada in 92 degree weather. Finally got my 'bird into a radiator shop and discovered that 35 to 40 percent of the radiator was completely plugged by a mixture of oil and dirt -- turning it practically into concrete. This has been a frequently reported problem with DD 6Vxx and 8Vxx engines (noted for tossing a bit of oil around) ... but (apparently) the Series 60 isn't immune either. What is a particular concern is that inspection of the radiator while it was in the vehicle did not reveal the blockage. Due to shrouds, AC evaporator, etc., the view of the area outside the center portion (where the fan spins) can't be seen (at least I couldn't see it clearly). The center area (where the fan spins) was open and clear (a bright light was clearly visible looking through the radiator). The fan seems to pull the crud out of that area, but there isn't enough air pressure outside the immediate area of the fan to keep other portions of the radiator clear. I suspect that all the pusher models are prone to this problem. I don't know if it's unique to my model BB or if others have better access to their radiators -- but the caution is to make cleaning the radiator and checking to be sure that it isn't clogged with the oil- dust "cement" as a regular part of annual maintenance. Since it required pulling the radiator to find the problem, I'm going ahead and replacing the core with a more modern/effective design (this is a big bucks project) so I hope to not have further heating problems for awhile. Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
09-07-2006, 11:12
Pete
That seemed to keep the toad cleaner too. Except in sloppy weather like when I left here last winter. Don 89 SP 36' Butler, PA Don, That's a great tip .... I'll see if I can do the same thing... be nice if I could run an extension right past the toad! Pete Masterson _aeonix1@..._ (mailto:aeonix1@...) '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA On Sep 7, 2006, at 6:19 PM, _dspithaler@..._ (mailto:dspithaler@...) wrote: > > Pete My 89 SP was collecting a lot of oily dirt on the rad & > after cooler > rad & I read on line that you could extend the breather tube that > comes down [Non-text portions of this message have been removed] |
09-07-2006, 13:48
No... the Wanderlodge pushers have the radiator to the left side (as
you face toward the front) -- since the beginning as far as I know.. Of course the FC units have the radiator in the front. DD 6vxx and 8vxx engines are noted for small oil leaks and mist, so any road dust gets mixed with the oil and starts to coat the radiator. The simple green - pressure wash idea is probably a good one (almost any detergent that's gentle on aluminum would do). However, it is a procedure that should be started early ... after eleven years of accumulation (as in my case) has occurred, a jack-hammer is probably a better tool. With the radiator out of my coach, you can see that the engine, particularly on the radiator side, is also coated with a fair amount of the oil-dirt crud. The radiator shop will steam clean everything before reassembly. Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA On Sep 7, 2006, at 3:42 PM, The Squires wrote: > Pete, > > I have been reading about Wanderlodges for a while and do not own > one, but I > can dream. But this topic comes up quite often on the Diesel RV > Yahoo users > group. Some pushers (like my '97 with a Cummins ISB) have the > radiator in > the back behind the engine and some radiators are on the side of > the RV > beside the engine. I have wondered about the Wanderlodges on this > issue for > sometime. I take it from your description, you is at the back > which is > prone to picking up road film. Keeping this back radiators clean is > difficult. The other group suggests spraying with Simple Green and > let it > soak for a while then pressure wash from the back side (toward the > engine) > to blow it out. > > All, > > Are some new Wanderlodges side radiators? What year did they change? > > Thanks, > Jimmy > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Pete Masterson > Sent: Thursday, September 07, 2006 4:39 PM > To: WanderlodgeForum@yahoogroups.com; wanderlodge@yahoogroups.com > Subject: [WanderlodgeForum] Over heating -- cause found > > > On the way home with my new-to-me 'bird at the end of May, I was > concerned about it running on the "hot" end of the safe zone > during a > couple of legs of the trip ... and having significant overheating > problems on the grades outside Salt Lake City coming west on I-80 in > Nevada in 92 degree weather. > > Finally got my 'bird into a radiator shop and discovered that 35 to > 40 percent of the radiator was completely plugged by a mixture of > oil > and dirt -- turning it practically into concrete. This has been a > frequently reported problem with DD 6Vxx and 8Vxx engines (noted for > tossing a bit of oil around) ... but (apparently) the Series 60 > isn't > immune either. > > What is a particular concern is that inspection of the radiator > while > it was in the vehicle did not reveal the blockage. Due to > shrouds, AC > evaporator, etc., the view of the area outside the center portion > (where the fan spins) can't be seen (at least I couldn't see it > clearly). The center area (where the fan spins) was open and > clear (a > bright light was clearly visible looking through the radiator). The > fan seems to pull the crud out of that area, but there isn't enough > air pressure outside the immediate area of the fan to keep other > portions of the radiator clear. > > I suspect that all the pusher models are prone to this problem. I > don't know if it's unique to my model BB or if others have better > access to their radiators -- but the caution is to make cleaning the > radiator and checking to be sure that it isn't clogged with the oil- > dust "cement" as a regular part of annual maintenance. > > Since it required pulling the radiator to find the problem, I'm > going > ahead and replacing the core with a more modern/effective design > (this is a big bucks project) so I hope to not have further heating > problems for awhile. > > Pete Masterson > aeonix1@... > '95 Bluebird Wanderlodge WBDA 42' > El Sobrante, CA > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
09-07-2006, 14:22
Don,
That's a great tip .... I'll see if I can do the same thing... be nice if I could run an extension right past the toad! Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 42' El Sobrante, CA On Sep 7, 2006, at 6:19 PM, dspithaler@... wrote: > > Pete My 89 SP was collecting a lot of oily dirt on the rad & > after cooler > rad & I read on line that you could extend the breather tube that > comes down > from the engine to the rear of the coach. After a couple of years > of really > cleaning my rad that I had recored right I bought it I ran the > pipe to the > rear curb side last summer. I have my rad open right now & I will > wash it but > it really doesn't need it. No oily dirt on it. > Don > 89 SP 36' > Butler, PA > [Non-text portions of this message have been removed] |
09-08-2006, 00:45
---DON:
I extended my pipe on my 90 SP 36 also so my radiator stays clean! An easy task; rubber hose and PVC to the hitch prevents anything from getting into the radiator. To me, the SP is an early version of the M380 only with a SIDE DOOR. I have one cherry 90SP36 FOR SALE if someone wants a great coach, ready to go with no 10-20K$$$$ to put into it...or if u know someone who wants a "ready to go" 80FC31 with NO 10-20K$$$ needed to fix it, then have them EMAIL me.....the 80 bird is with me in Florida and the 90SP is chillin in Vegas...I am leaving for AustRALIA IN late October. Hurry! Thanks. Regards & LOL Hank Hannigan 90sp36 80fc31 PS the other day, I forgot to add Ralphs name to the "check out" crew for anyone looking at a bird..sorry Ralph F.........also there are other forum members capable of checking out a bird and giving an opinion to a "NEWBY" buyer. In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote: > > > Pete My 89 SP was collecting a lot of oily dirt on the rad & after cooler > rad & I read on line that you could extend the breather tube that comes down > from the engine to the rear of the coach. After a couple of years of really > cleaning my rad that I had recored right I bought it I ran the pipe to the > rear curb side last summer. I have my rad open right now & I will wash it but > it really doesn't need it. No oily dirt on it. > Don > 89 SP 36' > Butler, PA > > > > > On the way home with my new-to-me 'bird at the end of May, I was > concerned about it running on the "hot" end of the safe zone during a > couple of legs of the trip ... and having significant overheating > problems on the grades outside Salt Lake City coming west on I-80 in > Nevada in 92 degree weather. > > Finally got my 'bird into a radiator shop and discovered that 35 to > 40 percent of the radiator was completely plugged by a mixture of oil > and dirt -- turning it practically into concrete. This has been a > frequently reported problem with DD 6Vxx and 8Vxx engines (noted for > tossing a bit of oil around) ... but (apparently) the Series 60 isn't > immune either. > > What is a particular concern is that inspection of the radiator while > it was in the vehicle did not reveal the blockage. Due to shrouds, AC > evaporator, etc., the view of the area outside the center portion > (where the fan spins) can't be seen (at least I couldn't see it > clearly). The center area (where the fan spins) was open and clear (a > bright light was clearly visible looking through the radiator). The > fan seems to pull the crud out of that area, but there isn't enough > air pressure outside the immediate area of the fan to keep other > portions of the radiator clear. > > I suspect that all the pusher models are prone to this problem. I > don't know if it's unique to my model BB or if others have better > access to their radiators -- but the caution is to make cleaning the > radiator and checking to be sure that it isn't clogged with the oil- > dust "cement" as a regular part of annual maintenance. > > Since it required pulling the radiator to find the problem, I'm going > ahead and replacing the core with a more modern/effective design > (this is a big bucks project) so I hope to not have further heating > problems for awhile. > > Pete Masterson > _aeonix1@..._ (mailto:aeonix1@...) > > > > > > > > > > [Non-text portions of this message have been removed] > |
09-08-2006, 17:12
Pete, after reading your post I inspectd my radiator (94pt8V92)and
was not able to get a good look at the Fins. as you posted, many things are in the way. After night fall I placed a shop light bulb between the shroud and the radiator ( from engine compartment). I was then able to get a very good inspection of the fins by viewing the light through the radiator vent door.the parimiter is dirty but no blockage. I plan on washing it up using laundry detergent ( Arial in plastic bag). dont forget to replace your R cap or test it for rated opening. his will keep you from having leaks with high pressure and keep you from cutting hoses by over tension on clamps Gregory O'Connor 94ptRomoland Ca- -- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > On the way home with my new-to-me 'bird at the end of May, I was > concerned about it running on the "hot" end of the safe zone during a > couple of legs of the trip ... and having significant overheating > problems on the grades outside Salt Lake City coming west on I-80 in > Nevada in 92 degree weather. > > Finally got my 'bird into a radiator shop and discovered that 35 to > 40 percent of the radiator was completely plugged by a mixture of oil > and dirt -- turning it practically into concrete. This has been a > frequently reported problem with DD 6Vxx and 8Vxx engines (noted for > tossing a bit of oil around) ... but (apparently) the Series 60 isn't > immune either. > > What is a particular concern is that inspection of the radiator while > it was in the vehicle did not reveal the blockage. Due to shrouds, AC > evaporator, etc., the view of the area outside the center portion > (where the fan spins) can't be seen (at least I couldn't see it > clearly). The center area (where the fan spins) was open and clear (a > bright light was clearly visible looking through the radiator). The > fan seems to pull the crud out of that area, but there isn't enough > air pressure outside the immediate area of the fan to keep other > portions of the radiator clear. > > I suspect that all the pusher models are prone to this problem. I > don't know if it's unique to my model BB or if others have better > access to their radiators -- but the caution is to make cleaning the > radiator and checking to be sure that it isn't clogged with the oil- > dust "cement" as a regular part of annual maintenance. > > Since it required pulling the radiator to find the problem, I'm going > ahead and replacing the core with a more modern/effective design > (this is a big bucks project) so I hope to not have further heating > problems for awhile. > > Pete Masterson > aeonix1@... > '95 Bluebird Wanderlodge WBDA 42' > El Sobrante, CA > > > > > > > [Non-text portions of this message have been removed] > |
