Flying J
09-17-2006, 13:35
Flying J
I have used Flying J's in MO, IN, OH, PA, GA, TX, AZ, CA, NV, and
OK.
Have always been real grateful that they provide so many services
with the free dump station, free good tire air pressure, free fresh
water, free overnight parking and pizza(not free).
Fueled a couple times at the RV island. Takes about 45 minutes to
take on 250 gal of diesel.
Usually go thru the truck lanes for fuel and then swing around to
the free services island if I need those services. Have had NO
trouble with getting my 40' Bird and Jeep Grand Cherokee towed in or
out of either the truck lanes or the RV islands.
The Flying J's hit or miss on cleanliness at the fuel islands. Have
had some diesel puddles to wade thru, have had some nice clean
islands too.
The nicest Flying J's are in IL, IN, OH and MO.
Got fuel today in IN, paid $2.49/gal., Ohio wanted $2.64/gal.
Jay Darst
85PT40
Springfield, IL just got back from Urbana, OH where the grand daddy
of tractor pulling was held, The Enderle Pull-Offs. Interesting, the
6 time world champion pro-stock John Deere used a 3208 with 2 little
turbos pushing air into 1 much larger turbo, it was fueled by
alcohol. Looked a bit different than brother Dan's 3208, cause it
had spark plugs among other things ;~}
09-17-2006, 13:56
Flying J
the alky 3208 conversion is neat lets see Hohnstein stuff that in his
truck wow talk about power and grunt
Stephen 77fc35 no sparkplugs or turbos just kitty no cat
> OK.
> islands too.
> Jay Darst
> 85PT40
09-18-2006, 04:13
Flying J
Is there any reasonable solution to the BB's tendency to "gush" fuel
just before the tank is full? I try to estimate the amount of fuel to
take on ... but the fuel gauge is hardly precise enough to get within
20-30 gallons. I wear vinyl gloves when fueling, but when a gallon or
so splashes out, it tends to cover everything - gloves or not. (I've
learned to stand back!)
Pete Masterson
aeonix1@...
'95 Bluebird Wanderlodge WBDA 42'
El Sobrante, CA
On Sep 17, 2006, at 6:35 PM, Jay Darst wrote:
> <snip>
> Have
> had some diesel puddles to wade thru, <snip>
09-18-2006, 04:29
Flying J
Somewhere in the archives or files on either this site or the FC forum is a
solution
designed by someone that I believe uses PVC pipe to solve the problem.
Kerry
82 Fc 35--Gusher
Denver
> Pete Masterson
> aeonix1@...
> El Sobrante, CA
> > <snip>
> > Have
09-18-2006, 04:40
Flying J
Pete:
Check the archives for "fuel splash back" I remember someone having a
solution to this problem, just not who. Well, they do say that the "memory"
is first to go, right?
Safe travels,
>Pete Masterson
>aeonix1@...
>El Sobrante, CA
> > <snip>
> > Have
09-18-2006, 04:44
Flying J
Pete,
I think John Finn posted this solution. Wrap a terry towel around the
fuel nozzle/filler neck. Works great. Leave the towel hanging behind the
fuel door. I use a bungee cord to hold the fuel nozzle in the filler
neck. It doubles as the terry towel hanger.
Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif.
>Pete Masterson
>aeonix1@...
>El Sobrante, CA
>><snip>
>> Have
>Yahoo! Groups Links
09-18-2006, 04:51
Flying J
Pete: On my 93pt-40 , when I want to top off the tank, I take both
fuel cap's off. You can fill it to the top of the filler tube if you
want with no splash. You have to be careful and monitor the filling or
you could run the tank over. The auto release on the pump dispenser
handle usually won't work when you do this, just be sure and monitor
it.Bob 93pt-40......Illinois
09-18-2006, 05:48
Flying J
Billy Dawson, did a modification for the fuel blow back. I think he has an ad
on Vintage Birds.
83 PT40
Livingston, Montana
09-18-2006, 06:01
Flying J
I'll try that one for next time...
I've searched the archives (of both lists) for "fuel splash" and
"fuel overflow" with no luck --- although I do remember that the
topic was previously discussed many months ago (before I purchase my
'bird).
Thanks.
Pete Masterson
aeonix1@...
El Sobrante, CA
09-18-2006, 07:28
Flying J
That's the way I do it Curt, simple and effective, works every time,
even at Flying J's!!
"REMEMBER SEPTEMBER 11, 2001"
John Finn
'82 35FCRB
BLUEBIRD WANDERLODGE
TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE
GO TO;
http://www.pbase.com/image/24977457
HOPKINS, SOUTH CAROLINA
> Pete,
behind the
filler
fuel
to
within
or
(I've
> >Pete Masterson
> >aeonix1@...
> >El Sobrante, CA
> >><snip>
> >> Have
> >Yahoo! Groups Links
