Morse Side landing (flood) lights
10-15-2006, 14:48
Anyone know a source for the side "landing lights" as they are called?
I need 2 of them it seems the bulbs are not replaceable. Looked on e-
bay, and goggled- nothing found, unless I'm searching on the wrong
name..??
Stephen H
81 FC-33SB
Plant City, FL
10-15-2006, 16:39
I replaced 2 of mine and used 50 watt lights instead of the 100 watters that
were original, provides plenty of light. Not easy but doable. Got the new
flood lights bulbs from Napa. I seem to remember that there was thread on this
forum about doing this.
Good luck
Sent: Sunday, October 15, 2006 7:48 PM
Subject: [WanderlodgeForum] Morse Side landing (flood) lights
name..??
Stephen H
81 FC-33SB
Plant City, FL
10-16-2006, 09:36
Jay- I thought through all these years that we had aircraft landing lights. i
guess I learned something new today.
83 PT40
Livingston, Montana SNOW!!!!
10-16-2006, 13:19
Stephen,
I replaced 1 of the side landing lights on my Bird.
The local replacement bulbs are a flood light and 50 watts, they can
be found at farm supply stores.
The correct bulbs have an unusual beam height and width. They are GE
Lamp#4519. They can be purchased from
http://www.topbulb.com/find/Product_Desc...ctID=42032
They run $35 ea.
Spec's are as follows:
GE Lamp #4519
13.0 Volt
100 Watt
30,000 Candle Power
40 degree horizontal beam spread
7 degree Vertical beam spread
screw terminals
These are actually a Marine landing light, there are some similiar
lights that are designed as airplane landing lights. I am not sure how
our fixtures would react to the much higher heat of that bulb.
Those specs (for the airplane bulb) look like this:
GE Lamp#4313
13.0 Volt
250 Watt
140,000 Candle Power
16 degree horizontal beam spread
7 degree vertical beam spread
screw terminals.
I'd like to know if anyone has tried the airplane landing lights, and
if they had any adverse effect on the fixture or wiring.
Thanks
Jay Darst
85PT40
Springfield, IL where has been dribling rain for about 14 hours
straight.
called?
> name..??
> Stephen H
> 81 FC-33SB
> Plant City, FL
