Heat loop flush and fill
10-19-2006, 16:26
Repaired a leak in the coolant line to the front heater core and
flushed the lines. Looking for suggestions on filling loop, I have the
lines disconnected from the motor. I recall someone mentioning using a
sump pump to fill the system but can't find the post in the archives.
Troy Tikalsky
1986 Newell
10-19-2006, 16:36
Troy that post was made by Randy Dupree. I'm not exactly sure how he did it
but he had a large reservoir that he pumped from. He'll be back from
Bainbridge GA by Sunday I think. He should chime in and give you the info
then.
> Troy Tikalsky
> 1986 Newell
Rob, Sue & Merlin Robinson
94 WLWB
10-19-2006, 17:28
Troy:
I have used a spare Par water pump to fill the system. Do you have a small
air bleeder valve on the front heater core? You will also need to find the
"high" spot in the system to further bleed air until you have a solid, not
spurting flow from there. This assures the system is full with no worries.
Safe travels,
>Troy Tikalsky
>1986 Newell
10-20-2006, 07:23
I don't have a spare Par water pump but I do have a pump on the Proheat unit I
am installing, maybe I can use this to fill the system. I don't see any bleeder
valves on the heater cores that I can find and the front core is lower than the
internal cores. Are the bleeder valves usually located on the heater core in in
the line?
Troy Tikalsky
1986 Newell
Sent: Friday, October 20, 2006 12:28 AM
Subject: Re: [WanderlodgeForum] Heat loop flush and fill
Troy:
Safe travels,
>Troy Tikalsky
>1986 Newell
