FC Generator Compartment Walls
10-20-2006, 02:23
What are they made of? Kryptonite?
I am trying to thread some self-tapping screws into the "ceiling" of the compartment to secure my insulation that keeps sagging regardless of the amount of adhesive I apply. Anyone have any tips? I can't seem to get anything to penetrate. Scott Forman 82 FC35RB Memphis |
10-20-2006, 08:25
Scott- do you have the original insulation? If so, it is probably coming
apart and should be replaced. Stephen Birtles has the new stuff and it is worth an investment . Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
10-20-2006, 23:34
If you have already installed new insulation or your existing material
is in good sound condition and just can't get it to stay "up"...I would suggest trying a new adhesive and/or to mount a few insulation hangers with either an epoxy or 3M 5200 Marine adhesive. "Hangers" are avail from West Marine and basically are a two part system consisting of a very large bottomed "thumbtack" that is mounted to the ceiling with adhesive or screws, the "pin" goes thru the insulation and a square sliding tab goes over the pin...holding up your insulation. You can easily slit the insulation and slip one in, then tape the cut with mylar tape. Hangers like this are common use in marine engine room applications. Frank 85FC33 Woodbridge, VA. --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > What are they made of? Kryptonite? > > I am trying to thread some self-tapping screws into the "ceiling" of > the compartment to secure my insulation that keeps sagging regardless > of the amount of adhesive I apply. Anyone have any tips? I can't seem > to get anything to penetrate. > > Scott Forman > 82 FC35RB > Memphis > |
10-21-2006, 02:43
---Scott:
If u need new insulation...suggest u consider "LIZARD SKIN" it is a space age product that I painted on the doghouse of my 80FC31 and it is a ceramic heat/sound shield.........I think it is great..and about the same price of two lead/sponge shields that I bought at Marine store for my 90SP36........I would rather have the "LIZARD SKIN." Check it out on the net. Regards, Hank Hannigan 80FC31...creampuff for sale in Vegas for $30,000 now! In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > What are they made of? Kryptonite? > > I am trying to thread some self-tapping screws into the "ceiling" of > the compartment to secure my insulation that keeps sagging regardless > of the amount of adhesive I apply. Anyone have any tips? I can't seem > to get anything to penetrate. > > Scott Forman > 82 FC35RB > Memphis > |
10-21-2006, 02:44
---Scott:
10-21-2006, 05:55
I am going to make an exception because I believe this is so
important. Do not use LIZARD SKIN on your doghouse or generator compartment. It is a wonderful material when used as an INSULATOR however it does absolutely nothing for the real problem caused by a diesel engine running in close proximity to the driving compartment....NOISE! To reduce noise you need a composite insulation that combines both a heat shield and a sound suppressor. To do this effectively, that is to attenuate the specific kinds of radiated noise that diesels put out, you need a 2# per sq foot composite foam insulation which contains a lead as a separator between the two densities of foam. There is also the same composite that uses a heavy vinyl separator and it does work but at a reduced There are several companies that sell this including http://www.soundown.com however JC Whitney is NOT one of them. If you decide to do it on the cheap that is of course your efficiency. The choice is yours but if you want to really reduce the noise and the heat then use the correct product. Lizard skin is a ceramic insulator and is not suitable for this job. Tom Warner Vernon Center, NY 1985 PT 40 you need At 10:43 AM 10/21/2006, you wrote: >---Scott: >If u need new insulation...suggest u consider "LIZARD SKIN" it is a >space age product that I painted on the doghouse of my 80FC31 and it >is a ceramic heat/sound shield.........I think it is great..and about >the same price of two lead/sponge shields that I bought at Marine >store for my 90SP36........I would rather have the "LIZARD SKIN." >Check it out on the net. >Regards, >Hank Hannigan >80FC31...creampuff for sale in Vegas for $30,000 now! > > > > > In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> >wrote: > > > > What are they made of? Kryptonite? > > > > I am trying to thread some self-tapping screws into the "ceiling" of > > the compartment to secure my insulation that keeps sagging >regardless > > of the amount of adhesive I apply. Anyone have any tips? I can't >seem > > to get anything to penetrate. > > > > Scott Forman > > 82 FC35RB > > Memphis > > |
10-21-2006, 10:23
Hi Hank
I just read abour Lizaed skin last night and thought about it today when I cleaned up my engine compartment. Soggy foam stuff hanging all around and some foam actually dis integrating, creating a hell of a mess. Now, if I could get the engine out and then respray the engine compartment with Lizard Skin, that would create a nice compartment. How do you like your 90 SP36? You can find my Handbook on a 91 SP in the files section. Juergen in PA 1991 WLSP36 Henry Jay Hannigan ---Scott: If u need new insulation...suggest u consider "LIZARD SKIN" it is a space age product that I painted on the doghouse of my 80FC31 and it is a ceramic heat/sound shield.........I think it is great..and about the same price of two lead/sponge shields that I bought at Marine store for my 90SP36........I would rather have the "LIZARD SKIN." Check it out on the net. Regards, Hank Hannigan 80FC31...creampuff for sale in Vegas for $30,000 now! In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > What are they made of? Kryptonite? > > I am trying to thread some self-tapping screws into the "ceiling" of > the compartment to secure my insulation that keeps sagging regardless > of the amount of adhesive I apply. Anyone have any tips? I can't seem > to get anything to penetrate. > > Scott Forman > 82 FC35RB > Memphis > --------------------------------- Do you Yahoo!? Get on board. You're invited to try the new Yahoo! Mail. [Non-text portions of this message have been removed] |
10-21-2006, 14:51
JUERGEN: MY 90 SP 36 IS A GREAT BIRD AND I'VE DECIDED TO KEEP IT RATHER THAN GIVE IT AWAY FOR $75,000 REGARDLESS OF THE MARKET ETC....IT IS WORTH MUCH MORE...AS FOR LIZARD SKIN, I USED IT ON THE 80FC31 NOT ON THE 90SP...I PUT THE LEAD/FOAM PURCHASED AT MARINE STORES FOR OVER $100 PER SHEAT..IT IS NICE BUT HAS A MIDDLE SAG IN IT BUT MUCH IMPROVED OVER THE "CRAP" BLUEBIRD INSTALLED ORIGINALLY..WHAT A MESS THAT WAS...CRUMBLES AFTER 16 YEARS..IMAGINE THAT! I MAY DO THE FRONT RADIATOR HOUSING ON THE SP IN A FEW YEARS WITH "LIZARD SKIN." NO MORE MESS OR SAGGING!! ALSO, I PAINTED IT ON.NOT SPRAYED!!!IT IS SAME AS "MUD" USED ON SHEET ROCK IN CONSISTANCY... I LIKED IT AND COST WAS JUST A BIT HIGHER THAN.. THE LEAD FOAM SHEETS.. HOPE THAT ANSWERS YOUR QUESTION. ALSO PLEASE TELL YOUR FRIENDS INTERESTED IN A GREAT BIRD TO EMAIL ME OR CALL ON MY 80fc31..IT IS READY TO GO!!! REGARDS, HANK HANNIGAN 80FC31 FOR SALE IN VEGAS 90SP 36..NOT FOR SALE ANYMORE...IN VEGAS WE LEAVE FOR AUSTRALIA ON 2 NOVEMBER..... - In WanderlodgeForum@yahoogroups.com, Juergen wrote: > > Hi Hank > I just read abour Lizaed skin last night and thought about it today when I cleaned up my engine compartment. Soggy foam stuff hanging all around and some foam actually dis integrating, creating a hell of a mess. Now, if I could get the engine out and then respray the engine compartment with Lizard Skin, that would create a nice compartment. How do you like your 90 SP36? You can find my Handbook on a 91 SP in the files section. > Juergen in PA > 1991 WLSP36 > > Henry Jay Hannigan wrote: ---Scott: > If u need new insulation...suggest u consider "LIZARD SKIN" it is a > space age product that I painted on the doghouse of my 80FC31 and it > is a ceramic heat/sound shield.........I think it is great..and about > the same price of two lead/sponge shields that I bought at Marine > store for my 90SP36........I would rather have the "LIZARD SKIN." > Check it out on the net. > Regards, > Hank Hannigan > 80FC31...creampuff for sale in Vegas for $30,000 now! > > In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > What are they made of? Kryptonite? > > > > I am trying to thread some self-tapping screws into the "ceiling" of > > the compartment to secure my insulation that keeps sagging > regardless > > of the amount of adhesive I apply. Anyone have any tips? I can't > seem > > to get anything to penetrate. > > > > Scott Forman > > 82 FC35RB > > Memphis > > > > > > > > > --------------------------------- > Do you Yahoo!? > Get on board. You're invited to try the new Yahoo! Mail. > > [Non-text portions of this message have been removed] > |
10-21-2006, 17:48
We have composite insulation in stock will be in Georgia October 29
if anyone needs some let me know Stpehen 77fc35 |
10-21-2006, 17:48
