The only thing wrong with so many sites!
04-18-2005, 08:15
Ok here is the problem and its kind of crazy? But having so many site
to choose from I don't know which one to ask questions on anymore except posting on all sites. Jon Now the reason I'm here is to ask anyone if their is are stock hosess you can buy for the oil cooler on a 3208? And where can I get them at? and least but not last if you have change these hoses out in the past how long did it take you and how many nicks and scratches did you get in the process. Oyes one more thing and I probably know the answer but you do haft drain all the fluids out of the radiator? Right Jon Jon Lechich 1978 Wanderlodge Bremertong |
04-18-2005, 08:18
transmission or engine oil cooler
Cape0001 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Jon" > > Ok here is the problem and its kind of crazy? But having so many site > to choose from I don't know which one to ask questions on anymore > except posting on all sites. Jon > > Now the reason I'm here is to ask anyone if their is are stock hosess > you can buy for the oil cooler on a 3208? And where can I get them at? > and least but not last if you have change these hoses out in the past > how long did it take you and how many nicks and scratches did you get > in the process. Oyes one more thing and I probably know the answer but > you do haft drain all the fluids out of the radiator? Right Jon > Jon Lechich > 1978 Wanderlodge > Bremertong |
04-18-2005, 08:40
> > Ok here is the problem and its kind of crazy? But having so many site > to choose from I don't know which one to ask questions on anymore > except posting on all sites. Jon > > Now the reason I'm here is to ask anyone if their is are stock hosess > you can buy for the oil cooler on a 3208? And where can I get them at? > and least but not last if you have change these hoses out in the past > how long did it take you and how many nicks and scratches did you get > in the process. Oyes one more thing and I probably know the answer but > you do haft drain all the fluids out of the radiator? Right Jon > Jon Lechich > 1978 Wanderlodge > Bremertong http://i2.photobucket.com/albums/y4/1942...C00324.jpg |
04-18-2005, 08:42
--- In WanderlodgeForum@yahoogroups.com, "cape0001"
wrote: > > transmission or engine oil cooler > Cape0001 77fc35 Boy do I sound stupid but its the engine cooler see attached picture and its the blue hosess. Jon http://i2.photobucket.com/albums/y4/1942...C00324.jpg > > > > --- In WanderlodgeForum@yahoogroups.com, "Jon" > > > > Ok here is the problem and its kind of crazy? But having so many > site > > to choose from I don't know which one to ask questions on anymore > > except posting on all sites. Jon > > > > Now the reason I'm here is to ask anyone if their is are stock > hosess > > you can buy for the oil cooler on a 3208? And where can I get them > at? > > and least but not last if you have change these hoses out in the > past > > how long did it take you and how many nicks and scratches did you > get > > in the process. Oyes one more thing and I probably know the answer > but > > you do haft drain all the fluids out of the radiator? Right Jon > > Jon Lechich > > 1978 Wanderlodge > > Bremertong |
04-18-2005, 09:09
Those are Caterpillar hoses, tell them you have the Na engine (smaller
oil cooler). You can close the water valves to the rear heat loop and to the front heater to reduce the amount of water loss, and clamp off the radiator hoses. - Jeff Miller http://www.wanderlodge.net --- In WanderlodgeForum@yahoogroups.com, "Jon" > > Ok here is the problem and its kind of crazy? But having so many site > to choose from I don't know which one to ask questions on anymore > except posting on all sites. Jon > > Now the reason I'm here is to ask anyone if their is are stock hosess > you can buy for the oil cooler on a 3208? And where can I get them at? > and least but not last if you have change these hoses out in the past > how long did it take you and how many nicks and scratches did you get > in the process. Oyes one more thing and I probably know the answer but > you do haft drain all the fluids out of the radiator? Right Jon > Jon Lechich > 1978 Wanderlodge > Bremertong |
04-18-2005, 09:16
Jon -
Just call Caterpiller in Centralia. They have an 800#. They have the hoses in stock. About 35$ with shipping. Maybe we need to get together and have a "hose swapping party". My new ones are still stored under the bed ![]() Bob(G) '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "Jon" > > Ok here is the problem and its kind of crazy? But having so many site > to choose from I don't know which one to ask questions on anymore > except posting on all sites. Jon > > Now the reason I'm here is to ask anyone if their is are stock hosess > you can buy for the oil cooler on a 3208? And where can I get them at? > and least but not last if you have change these hoses out in the past > how long did it take you and how many nicks and scratches did you get > in the process. Oyes one more thing and I probably know the answer but > you do haft drain all the fluids out of the radiator? Right Jon > Jon Lechich > 1978 Wanderlodge > Bremertong |
04-18-2005, 14:27
You're on the right forum, tech will work too.
Cat recommends changing the oil cooler hoses annually and you stray from using Cat hoses at your own peril. I tried NAPA but they weren't close. I have a 250 T, an NA might be serviced by NAPA, but Cat is better quality. Mike Hohnstein Germantown, WI ----- Original Message ----- From: Jon To: WanderlodgeForum@yahoogroups.com Sent: Monday, April 18, 2005 3:15 PM Subject: [WanderlodgeForum] The only thing wrong with so many sites! Ok here is the problem and its kind of crazy? But having so many site to choose from I don't know which one to ask questions on anymore except posting on all sites. Jon Now the reason I'm here is to ask anyone if their is are stock hosess you can buy for the oil cooler on a 3208? And where can I get them at? and least but not last if you have change these hoses out in the past how long did it take you and how many nicks and scratches did you get in the process. Oyes one more thing and I probably know the answer but you do haft drain all the fluids out of the radiator? Right Jon Jon Lechich 1978 Wanderlodge Bremertong ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
04-18-2005, 14:30
I agree. CAT seems to sell some quality product, their filters, hoses,
fluids, so far I've been happy with their product and the price has been reasonable. - Jeff Miller http://www.wanderlodge.net --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@w...> wrote: > You're on the right forum, tech will work too. > Cat recommends changing the oil cooler hoses annually and you stray from using Cat hoses at your own peril. I tried NAPA but they weren't close. I have a 250 T, an NA might be serviced by NAPA, but Cat is better quality. |
User(s) browsing this thread: 21 Guest(s)
