89 8.0 onan diesel gen set, hard to start
10-23-2006, 12:07
Has been hard to start ever since I bought it , over a year ago. It
cranks great, but wont fire now. I replaced the fuel filter several
months ago to eliminate it.The tank is full of fuel and the fuel
solinoid energizes when start button pressed.I loosened the bleed nut
on the top of the filter and fuel squirts out in a steady stream when
I crank it. I then loosened the rear(3 cyl)injector on top and fuel
just drizzels out when cranked.
How should the fuel squirt out when a connection is loosened? I
tried it from all four locations of start buttons. Tom said I could
have an air leak but how can you tell? I have no place where fuel
leaks out...
Anybody else ever had this problem and what was the fix.. frustrated
this has been going on forever....
Thanks for any help you can provide.
Ed Gardels 89sp
Arlington, Texas getting cooler!!
10-23-2006, 12:31
Ed,
Are you warming the glow plugs by holding the stop button for a few
seconds? You should hear the fuel pump running while doing this
(tick-tick-tick...).
Gary Miller
83 FC 33 Powertech diesel(kubota) genny
Milwaukee area
--- In WanderlodgeForum@yahoogroups.com, "Ed Gardels"
nut
when
> leaks out...
frustrated
> Ed Gardels 89sp
10-23-2006, 13:16
ED,
This 3 cylinder likes the glow plugs. It may be easier to start
especially in cooler weather, From the generator compartment, Both
the start and glow plug switches can be used at the same time.
First warm the glow plugs, about 30 sec. then toggle the glow plug
switch as you try to start. The other three interior switches heat
the glow plugs in the "Off" position only.
If this does not work for you, there may be a defective glow plug.
Bill 88 FC Michigan
It
several
nut
when
fuel
could
> leaks out...
frustrated
> Ed Gardels 89sp
10-23-2006, 13:19
--- In WanderlodgeForum@yahoogroups.com, "Gary Miller"
>Yes, Gary I have tried warmingthe plugs. On aprevious post, Tom
said it should even start without warming.
any other ideas???
Ed Gardels 89sp
Arlington, Texas
> Ed,
few
> Gary Miller
> Milwaukee area
It
several
bleed
> nut
> when
fuel
I
could
fuel
> > leaks out...
> frustrated
> > Ed Gardels 89sp
10-23-2006, 13:33
>Bill, You can press both switches at same time? Warm and start.
Ive never warmed it more than 10 seconds. Will try that tommorrow.
Thanks for the help...
Ed Gardels 89sp
> ED,
> Bill 88 FC Michigan
> It
> several
bleed
> nut
> when
> fuel
I
> could
fuel
> > leaks out...
> frustrated
> > Ed Gardels 89sp
10-23-2006, 15:50
Well...
My paper brains (blue box) are located in my coach, and it's been a
while since I wore my Wanderlodge thinking cap.
The way I hear it, the three cylinder Kubota has a history of
starting a bit rough when cold, but it can always get started with a
little help from the glow plugs and priming.
With my start switch in 'stop', I get glow plugs and priming. You
might check if your glow plug circuit is being energized by putting
a voltmeter on it. It really sounds like a glow plug problem or
circuit to me.
Gary Miller
83 FC 33
Milwaukee area
> any other ideas???
> Ed Gardels 89sp
> Arlington, Texas
> > Ed,
> few
> > Gary Miller
> > Milwaukee area
ago.
> It
> several
fuel
> bleed
> > nut
stream
> > when
> fuel
loosened?
> I
> could
> fuel
> > > leaks out...
> > frustrated
> > > Ed Gardels 89sp
10-24-2006, 01:41
The steel lines after the high pressure injection pump should squirt
out with a pulse when the engine is turned over. I loosen one at a
time while cranking the engine. CurtS had issues with his Yanmar (
john Deere)and it would not start unless the return lines were let
open. it may be time for injector cleaning. If it was my genset, I
would pull off the injectors and have them bench tested and rebuilt.
You could also check if there is a good flow on the supply fitting to
the high press injector pump. Keep the batteries fully charged while
cranking the genset over because low battery turns is sure to eatup
the starter. If it was the injector spray, replace the engine oil
after you clean up the problem. The Kabotas wash out when they dont
start and I have seen as much as a quart of Dfuel make its way into
the lube oil.
GregoryO'Connor
94ptRomolandCa
nut
when
> leaks out...
frustrated
> Ed Gardels 89sp
10-24-2006, 03:17
Ed,
Preheat the glow plugs and feel to see if they are heating up. On my 12 KW, I
heat it for ten seconds and it will fire right up otherwise it grinds and
grinds.
Howard Truitt
Camilla, Ga.
86 PT40
Sent: Monday, October 23, 2006 8:07 PM
Subject: [WanderlodgeForum] 89 8.0 onan diesel gen set, hard to start
leaks out...
Ed Gardels 89sp
Checked by AVG Free Edition.
Version: 7.1.408 / Virus Database: 268.13.5/482 - Release Date: 10/18/2006
10-24-2006, 06:21
>Gary... Ive never heard any clicking while warming the plugs,
however, I some times here it after I finish cranking with it not
starting. I thougt the clicking was coming from the control box.
Thanks for the help
Ed Gardels 89sp
Arlington Texas
> Ed,
few
> Gary Miller
> Milwaukee area
It
several
bleed
> nut
> when
fuel
I
could
fuel
> > leaks out...
> frustrated
> > Ed Gardels 89sp
10-24-2006, 08:34
Ed
On my genny I heat for 15 sec then turn engine over a couple of turns, heat
for 15 more then it cranks running rough momentarily. If the weather is not
cold or it has been run lately it will crank after first heating.
LT 90 SP in Eclectic, AL
Sent: Tuesday, October 24, 2006 10:17 AM
Subject: Re: [WanderlodgeForum] 89 8.0 onan diesel gen set, hard to start
> Ed,
> KW, I heat it for ten seconds and it will fire right up otherwise it
> grinds and grinds.
> Howard Truitt
> Camilla, Ga.
> 86 PT40
> From: Ed Gardels
> leaks out...
> Ed Gardels 89sp
> 10/18/2006
> Yahoo! Groups Links
