Shore Water
10-24-2006, 10:32
Shore Water
John,
Please ask Rich to send me copies. Much appreciated. curtsprenger @ adelphia. net remove the spaces. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. John Suter wrote: > Rich Ducci and I struggled for a year or more and >finally discovered and resolved the low shore-water >pressure problem by removing and replacing the >original pressure regulator assembly with a commercial >3/4" brass checkvalve and a 3/4" adjustable pressure >regulator (and added some other "frill" stuff). > > Rich has terrific pictures of the results, which we >understand has since been copied and is now marketed >as a complete replacement assembly unit by someone. I >know he would send copies off-line (as no attachments >are permitted to be attached to yahoo-group stuff.) >The only problem we found is, if you step up the flow >too much to the shower, you outrun the coach ability >to produce hot water. > >John Suter > > > >--- Curt Sprenger > > > >>While at the Buellton rally is past weekend, I >>hooked up to shore water >>and got almost zero water flow. The tank fill >>switch was in the off >>position. I don't have the water flow diagram. >>Suggestions appreciated. >>To get around the problem, I filled the water tank >>and used the water pump. >> >>-- >>Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. >> >> >> >> > > >__________________________________________________ >Do You Yahoo!? >Tired of spam? Yahoo! Mail has the best spam protection around >http://mail.yahoo.com > > > >Yahoo! Groups Links > > > > > > > |
10-24-2006, 23:05
Shore Water
Curt and others:
I've forwarded your requests on to Rich, although he normally follows the "goings on" here on the Forum. John --- Curt Sprenger > John, > Please ask Rich to send me copies. Much appreciated. > curtsprenger @ > adelphia. net remove the spaces. > > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > > John Suter wrote: > > > Rich Ducci and I struggled for a year or more and > >finally discovered and resolved the low shore-water > >pressure problem by removing and replacing the > >original pressure regulator assembly with a > commercial > >3/4" brass checkvalve and a 3/4" adjustable > pressure > >regulator (and added some other "frill" stuff). > > > > Rich has terrific pictures of the results, which > we > >understand has since been copied and is now > marketed > >as a complete replacement assembly unit by someone. > I > >know he would send copies off-line (as no > attachments > >are permitted to be attached to yahoo-group stuff.) > > >The only problem we found is, if you step up the > flow > >too much to the shower, you outrun the coach > ability > >to produce hot water. > > > >John Suter > > > > > > > >--- Curt Sprenger > wrote: > > > > > > > >>While at the Buellton rally is past weekend, I > >>hooked up to shore water > >>and got almost zero water flow. The tank fill > >>switch was in the off > >>position. I don't have the water flow diagram. > >>Suggestions appreciated. > >>To get around the problem, I filled the water tank > >>and used the water pump. > >> > >>-- > >>Curt Sprenger 1987 PT38 8V92, Anaheim Hills, > Calif. > >> > >> > >> > >> > > > > > >__________________________________________________ > >Do You Yahoo!? > >Tired of spam? Yahoo! Mail has the best spam > protection around > >http://mail.yahoo.com > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
10-24-2006, 23:59
Shore Water
Hi John,
I'd appreciate it if Rich would send me a copy of the shore water pressure fix. It's one of the main things I want to get fixed on my coach. Thanks, Randy Merrill 1993 40' WLWB Ocala, FL randymerri@... |
10-25-2006, 01:42
Shore Water
Hi John, Kevin, Curt, Randy
I just emailed the photos and info on the water modification to John, Kevin and Curt. Randy, email me so I have your return email address and I will send it along to you too. Yahoo does not allow attachments. I will also try to upload it to the files section. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, John Suter wrote: > > Curt and others: > > I've forwarded your requests on to Rich, although he > normally follows the "goings on" here on the Forum. > > John > > > > > --- Curt Sprenger > > > John, > > Please ask Rich to send me copies. Much appreciated. > > curtsprenger @ > > adelphia. net remove the spaces. > > > > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > > > > > > John Suter wrote: > > > > > Rich Ducci and I struggled for a year or more and > > >finally discovered and resolved the low shore-water > > >pressure problem by removing and replacing the > > >original pressure regulator assembly with a > > commercial > > >3/4" brass checkvalve and a 3/4" adjustable > > pressure > > >regulator (and added some other "frill" stuff). > > > > > > Rich has terrific pictures of the results, which > > we > > >understand has since been copied and is now > > marketed > > >as a complete replacement assembly unit by someone. > > I > > >know he would send copies off-line (as no > > attachments > > >are permitted to be attached to yahoo-group stuff.) > > > > >The only problem we found is, if you step up the > > flow > > >too much to the shower, you outrun the coach > > ability > > >to produce hot water. > > > > > >John Suter > > > > > > > > > > > >--- Curt Sprenger > > wrote: > > > > > > > > > > > >>While at the Buellton rally is past weekend, I > > >>hooked up to shore water > > >>and got almost zero water flow. The tank fill > > >>switch was in the off > > >>position. I don't have the water flow diagram. > > >>Suggestions appreciated. > > >>To get around the problem, I filled the water tank > > >>and used the water pump. > > >> > > >>-- > > >>Curt Sprenger 1987 PT38 8V92, Anaheim Hills, > > Calif. > > >> > > >> > > >> > > >> > > > > > > > > >__________________________________________________ > > >Do You Yahoo!? > > >Tired of spam? Yahoo! Mail has the best spam > > protection around > > >http://mail.yahoo.com > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > |
10-25-2006, 03:20
Shore Water
John,
Thank you very much! Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. g_man1146 wrote: >Hi John, Kevin, Curt, Randy > >I just emailed the photos and info on the water modification to >John, Kevin and Curt. >Randy, email me so I have your return email address and I will send >it along to you too. Yahoo does not allow attachments. I will also >try to upload it to the files section. >Rich D. '99LXi43' CT > > > > > |
10-25-2006, 12:47
Shore Water
Hi Rich,
Would you mind mailing me a set too please? I need to improve the flow on my city water inlet system too. Many thanks, Terry Neal Bozeman, MT 82PT40 74FC34 g_man1146 wrote: > Hi John, Kevin, Curt, Randy > > I just emailed the photos and info on the water modification to > John, Kevin and Curt. > Randy, email me so I have your return email address and I will send > it along to you too. Yahoo does not allow attachments. I will also > try to upload it to the files section. > Rich D. '99LXi43' CT > > --- In WanderlodgeForum@yahoogroups.com > > wrote: > > > > Curt and others: > > > > I've forwarded your requests on to Rich, although he > > normally follows the "goings on" here on the Forum. > > > > John > > > > > > > > > > --- Curt Sprenger > > > > > John, > > > Please ask Rich to send me copies. Much appreciated. > > > curtsprenger @ > > > adelphia. net remove the spaces. > > > > > > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > > > > > > > > > > John Suter wrote: > > > > > > > Rich Ducci and I struggled for a year or more and > > > >finally discovered and resolved the low shore-water > > > >pressure problem by removing and replacing the > > > >original pressure regulator assembly with a > > > commercial > > > >3/4" brass checkvalve and a 3/4" adjustable > > > pressure > > > >regulator (and added some other "frill" stuff). > > > > > > > > Rich has terrific pictures of the results, which > > > we > > > >understand has since been copied and is now > > > marketed > > > >as a complete replacement assembly unit by someone. > > > I > > > >know he would send copies off-line (as no > > > attachments > > > >are permitted to be attached to yahoo-group stuff.) > > > > > > >The only problem we found is, if you step up the > > > flow > > > >too much to the shower, you outrun the coach > > > ability > > > >to produce hot water. > > > > > > > >John Suter > > > > > > > > > > > > > > > >--- Curt Sprenger > > > wrote: > > > > > > > > > > > > > > > >>While at the Buellton rally is past weekend, I > > > >>hooked up to shore water > > > >>and got almost zero water flow. The tank fill > > > >>switch was in the off > > > >>position. I don't have the water flow diagram. > > > >>Suggestions appreciated. > > > >>To get around the problem, I filled the water tank > > > >>and used the water pump. > > > >> > > > >>-- > > > >>Curt Sprenger 1987 PT38 8V92, Anaheim Hills, > > > Calif. > > > >> > > > >> > > > >> > > > >> > > > > > > > > > > > >__________________________________________________ > > > >Do You Yahoo!? > > > >Tired of spam? Yahoo! Mail has the best spam > > > protection around > > > >http://mail.yahoo.com <http://mail.yahoo.com> > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________ > > Do You Yahoo!? > > Tired of spam? Yahoo! Mail has the best spam protection around > > http://mail.yahoo.com <http://mail.yahoo.com> > > > > [Non-text portions of this message have been removed] |
10-26-2006, 09:07
Shore Water
All,
Thank you for your input regarding the shore water issue. The shore water flow issue is resolved. I took the old regulator/check valve and brass fitting that connects to the coach water line with me to a good plumbing store. We tried several things until we got a very close match on length to the old parts. The parts are a 1/2" check valve, 2" nipple, and swivel connection for the shore hose. I made a plate the size of the old plastic, drilled it out, 4 screw holes, one center hole for the swivel connection. Pictures of the new unit are available if anyone is interested. I use a regulator at the camp ground faucet so I didn't bother with a pressure regulator. The water tank fills faster and the faucets have good water flow from the shore hookup. I removed the screen, etc. parts from the bath sink and drilled out the center hole in the flat plastic piece to double its size and that got the faucet flowing. Shower works great too. That was an easy fix. On to the next project... -- Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. |
10-30-2006, 03:45
Shore Water
Curt, I didn't know you were having this problem at Buellton. I suffered with
this problem on our '81 FC31, and it turned out to be the hot water drain valve was defective. That's the valve that has a long handle on it and works by operating the dial from fill to drain. That valve gets calcium build-up just like the sporlan valves do and have the same result. If your sporlan fill valve is ok, check the hot water tank drain valve. It has the same effect as the sporlan fill valve, believe it or not. Good luck., Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: jim riordan To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, October 24, 2006 9:53 AM Subject: Re: [WanderlodgeForum] Shore Water Did you check the screen at the intake? Jim Riordan Curt Sprenger wrote: While at the Buellton rally is past weekend, I hooked up to shore water and got almost zero water flow. The tank fill switch was in the off position. I don't have the water flow diagram. Suggestions appreciated. To get around the problem, I filled the water tank and used the water pump. -- Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. --------------------------------- How low will we go? Check out Yahoo! Messenger's low PC-to-Phone call rates. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
10-30-2006, 15:46
Shore Water
Dick, Others,
Some may have missed my post regarding the resolution to my problem. I replaced the original shore hook up connection stuff, the pressure reg. and back flow, with a check valve. All is resolved. We have great water flow now when hooked up to shore water. I use a pressure reg. at the camp site faucet so I don't need the regulator in the coach. I'll file the hot water tank drain valve info. for future reference in case this problem returns. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Richard Hayden wrote: >Curt, I didn't know you were having this problem at Buellton. I suffered with this problem on our '81 FC31, and it turned out to be the hot water drain valve was defective. That's the valve that has a long handle on it and works by operating the dial from fill to drain. That valve gets calcium build-up just like the sporlan valves do and have the same result. If your sporlan fill valve is ok, check the hot water tank drain valve. It has the same effect as the sporlan fill valve, believe it or not. > >Good luck., > >Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: jim riordan > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, October 24, 2006 9:53 AM > Subject: Re: [WanderlodgeForum] Shore Water > > > Did you check the screen at the intake? > > Jim Riordan > > Curt Sprenger wrote: > While at the Buellton rally is past weekend, I hooked up to shore water > and got almost zero water flow. The tank fill switch was in the off > position. I don't have the water flow diagram. Suggestions appreciated. > To get around the problem, I filled the water tank and used the water pump. > > -- > Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > --------------------------------- > How low will we go? Check out Yahoo! Messenger's low PC-to-Phone call rates. > > [Non-text portions of this message have been removed] > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > > |
10-30-2006, 15:59
Shore Water
I should add...If anyone if interested, I can provide pictures of the
replacement unit I made up. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. Curt Sprenger wrote: >Dick, Others, > >Some may have missed my post regarding the resolution to my problem. I >replaced the original shore hook up connection stuff, the pressure reg. >and back flow, with a check valve. All is resolved. We have great water >flow now when hooked up to shore water. I use a pressure reg. at the >camp site faucet so I don't need the regulator in the coach. > >I'll file the hot water tank drain valve info. for future reference in >case this problem returns. > >Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. > > > >Richard Hayden wrote: > > > >>Curt, I didn't know you were having this problem at Buellton. I suffered with this problem on our '81 FC31, and it turned out to be the hot water drain valve was defective. That's the valve that has a long handle on it and works by operating the dial from fill to drain. That valve gets calcium build-up just like the sporlan valves do and have the same result. If your sporlan fill valve is ok, check the hot water tank drain valve. It has the same effect as the sporlan fill valve, believe it or not. >> >>Good luck., >> >>Dick Hayden - '87 PT 38 - Lake Stevens, WA >> >> ----- Original Message ----- >> From: jim riordan >> To: WanderlodgeForum@yahoogroups.com >> Sent: Tuesday, October 24, 2006 9:53 AM >> Subject: Re: [WanderlodgeForum] Shore Water >> >> >> Did you check the screen at the intake? >> >> Jim Riordan >> >> Curt Sprenger wrote: >> While at the Buellton rally is past weekend, I hooked up to shore water >> and got almost zero water flow. The tank fill switch was in the off >> position. I don't have the water flow diagram. Suggestions appreciated. >> To get around the problem, I filled the water tank and used the water pump. >> >> -- >> Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. >> >> >> --------------------------------- >> How low will we go? Check out Yahoo! Messenger's low PC-to-Phone call rates. >> >> [Non-text portions of this message have been removed] >> >> >> >> >> >>[Non-text portions of this message have been removed] >> >> >> >> >>Yahoo! Groups Links >> >> >> >> >> >> >> >> >> > > > >Yahoo! Groups Links > > > > > > > |
