HWH Pump Removal
10-28-2006, 16:18
HWH Pump Removal
Does anyone have any tips/suggestions on easy removal of the
pump/reservoir assy? It seems to be held on by a bracket between the motor and the reservoir sections, bolted to the outside step well. I believe I burned up the motor by a faulty solenoid that is stuck in the 'on' position. Motor looks to be a starter motor? Is this motor avail at a parts store? Wanting to get the assy removed tomorrow (Sunday) I cannot gain easy access behind the carpet on the step inside to see if there are bolts behind there to remove the pump. Seems like it would have to be? Wanted to ask before tearing out new carpet..!! Thank you Stephen H 81 FC-33SB Plant City, FL Enjoying cool weather FINALLY! |
10-29-2006, 03:29
HWH Pump Removal
Motor is attached to the reservoir pump via a spline. It just slides
in. This motor is well built. Take it to any generator/starter shop and they can easily repair it. Probably only brushes or broken wire. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@...> wrote: > > Does anyone have any tips/suggestions on easy removal of the > pump/reservoir assy? It seems to be held on by a bracket between the > motor and the reservoir sections, bolted to the outside step well. > > I believe I burned up the motor by a faulty solenoid that is stuck in > the 'on' position. Motor looks to be a starter motor? Is this motor > avail at a parts store? Wanting to get the assy removed tomorrow > (Sunday) I cannot gain easy access behind the carpet on the step inside > to see if there are bolts behind there to remove the pump. Seems like > it would have to be? Wanted to ask before tearing out new carpet..!! > Thank you > Stephen H > 81 FC-33SB > Plant City, FL > Enjoying cool weather FINALLY! > |
10-29-2006, 06:12
HWH Pump Removal
> > Motor is attached to the reservoir pump via a spline. It just slides > in. This motor is well built. Take it to any generator/starter shop > and they can easily repair it. Probably only brushes or broken wire. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@> wrote: > > > > Does anyone have any tips/suggestions on easy removal of the > > pump/reservoir assy? It seems to be held on by a bracket between the > > motor and the reservoir sections, bolted to the outside step well. > > > > I believe I burned up the motor by a faulty solenoid that is stuck in > > the 'on' position. Motor looks to be a starter motor? Is this motor > > avail at a parts store? Wanting to get the assy removed tomorrow > > (Sunday) I cannot gain easy access behind the carpet on the step inside > > to see if there are bolts behind there to remove the pump. Seems like > > it would have to be? Wanted to ask before tearing out new carpet..!! > > Thank you > > Stephen H > > 81 FC-33SB > > Plant City, FL > > Enjoying cool weather FINALLY! > > > The reason this motor burns up is that there is no overload protection for it. I had to have mine rebuild twice before I added a 150 Amp circuit breaker in line with the battery lead going to the relay. The reason for the overload can be the fact that unless you push the activating handle all the way over, the motor will run but the fluid is not directed to the leveler cylinder and this stalls and overloads the motor. Since I added the breaker it has tripped but no more problems with the motor. I used a Blue Sea Systems 185 Series panel mount circuit breaker 150 amp, their part # 7004. I mounted it under the lift up step that allows access to the fill port on the pump. These breakers are available from West Marine. Lucas Willemse 1980 FC 35 Los Angeles |
10-29-2006, 12:07
HWH Pump Removal
Lucas, seems to me you have found a way to save
the motor by limiting current via the breaker but the cause still remains tripping your breakers. If the pump works before oil can go to the cylinder could the switch that turns the pump on be out of adjustment turning the pump on too soon? If not, another way would be a pressure release bypass valve. Once the pressure reached a point near where damage could be done to the motor a spring-loaded valve diverts fluid to the supply tank. Bob Janes, Greenville, SC --- In WanderlodgeForum@yahoogroups.com, "Lucas Willemse" > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > Motor is attached to the reservoir pump via a spline. It just > slides > > in. This motor is well built. Take it to any generator/starter > shop > > and they can easily repair it. Probably only brushes or broken > wire. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@> > wrote: > > > > > > Does anyone have any tips/suggestions on easy removal of the > > > pump/reservoir assy? It seems to be held on by a bracket between > the > > > motor and the reservoir sections, bolted to the outside step > well. > > > > > > I believe I burned up the motor by a faulty solenoid that is > stuck in > > > the 'on' position. Motor looks to be a starter motor? Is this > motor > > > avail at a parts store? Wanting to get the assy removed tomorrow > > > (Sunday) I cannot gain easy access behind the carpet on the step > inside > > > to see if there are bolts behind there to remove the pump. Seems > like > > > it would have to be? Wanted to ask before tearing out new > carpet..!! > > > Thank you > > > Stephen H > > > 81 FC-33SB > > > Plant City, FL > > > Enjoying cool weather FINALLY! > > > > > > > The reason this motor burns up is that there is no overload > protection for it. I had to have mine rebuild twice before I added a > 150 Amp circuit breaker in line with the battery lead going to the > relay. The reason for the overload can be the fact that unless you > push the activating handle all the way over, the motor will run but > the fluid is not directed to the leveler cylinder and this stalls > and overloads the motor. Since I added the breaker it has tripped > but no more problems with the motor. I used a Blue Sea Systems 185 > Series panel mount circuit breaker 150 amp, their part # 7004. I > mounted it under the lift up step that allows access to the fill > port on the pump. These breakers are available from West Marine. > > Lucas Willemse > 1980 FC 35 > Los Angeles > |
10-29-2006, 13:00
HWH Pump Removal
Thanks to all who helped with my motor. I got it down today, not too bad-
just very dirty!~! One tip, wear safety glasses!! LOL I will bring the motor to a local shop for rebuild. I will be looking into purchasing that 150A Breaker at west marine! I don't want to go through this again!! Stephen H 81 FC-33SB Plant City, FL _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of one_dusty_hoot Sent: Sunday, October 29, 2006 7:08 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: HWH Pump Removal Lucas, seems to me you have found a way to save the motor by limiting current via the breaker but the cause still remains tripping your breakers. If the pump works before oil can go to the cylinder could the switch that turns the pump on be out of adjustment turning the pump on too soon? If not, another way would be a pressure release bypass valve. Once the pressure reached a point near where damage could be done to the motor a spring-loaded valve diverts fluid to the supply tank. Bob Janes, Greenville, SC [Non-text portions of this message have been removed] |
10-29-2006, 14:46
HWH Pump Removal
Yes there are two bolts holding the pump and reservoir to the back of the
step. The nuts are sandwiched between to layers of wood behind the carpet. If the motor is bad, you do not need to mess with the pump and reservoir hardware. Just remove the two bolts on the end of the motor and the one wire coming from the solenoid. I did this many times, got it down to 8 minutes. Turned out to be a bad ground, motor was fine. dandarst86fc35rbhuntleyil. >From: "Stephen H" <share@...> >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] HWH Pump Removal >Date: Sun, 29 Oct 2006 04:18:06 -0000 > >Does anyone have any tips/suggestions on easy removal of the >pump/reservoir assy? It seems to be held on by a bracket between the >motor and the reservoir sections, bolted to the outside step well. > >I believe I burned up the motor by a faulty solenoid that is stuck in >the 'on' position. Motor looks to be a starter motor? Is this motor >avail at a parts store? Wanting to get the assy removed tomorrow >(Sunday) I cannot gain easy access behind the carpet on the step inside >to see if there are bolts behind there to remove the pump. Seems like >it would have to be? Wanted to ask before tearing out new carpet..!! >Thank you >Stephen H >81 FC-33SB >Plant City, FL >Enjoying cool weather FINALLY! > > > _________________________________________________________________ All-in-one security and maintenance for your PC. Get a free 90-day trial! http://clk.atdmt.com/MSN/go/msnnkwlo0050...w.win\ dowsonecare.com/?sc_cid=msn_hotmail |
10-30-2006, 16:53
HWH Pump Removal
Bob, those high press bypass valves fail open often. then you have
bypass all the time and reduced function. I remove them on hydrostat tractors and use a pressure switch to an alarm. You could use a high press relay shut down also. The HWH on my 94 has a simple two button set and stow. I wonder if you could upgrade the electronics as the appliances are the same. electric/hydrolic pump , hydrolic lines and single acting cylinders??? Curt said HWH is a helpfull crowd. The newer electronics (new 12 years ago)may have a high pressure fault shutdown. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot" > > Lucas, seems to me you have found a way to save > the motor by limiting current via the breaker but > the cause still remains tripping your breakers. > > If the pump works before oil can go to the > cylinder could the switch that turns the pump > on be out of adjustment turning the pump on > too soon? > > If not, another way would be a pressure release > bypass valve. Once the pressure reached a point > near where damage could be done to the motor a > spring-loaded valve diverts fluid to the supply > tank. > Bob Janes, Greenville, SC > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Lucas Willemse" > > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > > > > Motor is attached to the reservoir pump via a spline. It just > > slides > > > in. This motor is well built. Take it to any generator/starter > > shop > > > and they can easily repair it. Probably only brushes or broken > > wire. > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@> > > wrote: > > > > > > > > Does anyone have any tips/suggestions on easy removal of the > > > > pump/reservoir assy? It seems to be held on by a bracket > between > > the > > > > motor and the reservoir sections, bolted to the outside step > > well. > > > > > > > > I believe I burned up the motor by a faulty solenoid that is > > stuck in > > > > the 'on' position. Motor looks to be a starter motor? Is this > > motor > > > > avail at a parts store? Wanting to get the assy removed > tomorrow > > > > (Sunday) I cannot gain easy access behind the carpet on the > step > > inside > > > > to see if there are bolts behind there to remove the pump. > Seems > > like > > > > it would have to be? Wanted to ask before tearing out new > > carpet..!! > > > > Thank you > > > > Stephen H > > > > 81 FC-33SB > > > > Plant City, FL > > > > Enjoying cool weather FINALLY! > > > > > > > > > > > The reason this motor burns up is that there is no overload > > protection for it. I had to have mine rebuild twice before I added > a > > 150 Amp circuit breaker in line with the battery lead going to the > > relay. The reason for the overload can be the fact that unless you > > push the activating handle all the way over, the motor will run but > > the fluid is not directed to the leveler cylinder and this stalls > > and overloads the motor. Since I added the breaker it has tripped > > but no more problems with the motor. I used a Blue Sea Systems 185 > > Series panel mount circuit breaker 150 amp, their part # 7004. I > > mounted it under the lift up step that allows access to the fill > > port on the pump. These breakers are available from West Marine. > > > > Lucas Willemse > > 1980 FC 35 > > Los Angeles > > > |
