Generator replacement 1978 FC33
11-01-2006, 06:28
Does anyone have experience replacing a generator on a 1978 FC33? I'm
looking at buying this Bird, which is in good condition except for the
gen (dead). Roughly how much would it cost to have one installed?
Thanks in advance,
Brent
11-01-2006, 15:32
Hi Brent,
We replaced a propane generator on our 84FC with a 8KW PowerTech diesel
generator in
2001. We had it installed at the PowerTech factory in Florida for $6,300
including tax.
We've logged 1,000 hours on it since then and it's been a good, reliable unit.
We only
have two roof airs and easily run them and anything else on our coach without a
problem.
If you want to run three roof airs, an 8KW unit may be too small for you. We
picked the
8KW because it was the largest enclosed unit we could fit into our compartment.
You can
fit a larger unenclosed unit in your coach but will experience more noise as a
result. Hope
this helps in your decision.
Regards, Eric in San Antonio
84FC35SBWL2
--- In WanderlodgeForum@yahoogroups.com, "swartzentruber1" <swartzentruber1@...>
> Thanks in advance,
> Brent
11-01-2006, 16:51
Eric,
Thanks for the information. That's a large up front investment if I
bought this WL, so the price will have to be right. He is asking
$20K OBO, which seems high for a rig with 250K miles and no
generator, but it had a brand new CAT installed 7000 miles ago.
Any thoughts . . .
--- In WanderlodgeForum@yahoogroups.com, "Eric Johnson"
> Hi Brent,
diesel generator in
$6,300 including tax.
reliable unit. We only
coach without a problem.
for you. We picked the
compartment. You can
noise as a result. Hope
> 84FC35SBWL2
<swartzentruber1@>
FC33? I'm
for the
installed?
> > Thanks in advance,
> > Brent
11-01-2006, 20:47
On the Vintage Bird site under classifieds are 2 generators for sale.
83 PT40
Livingston, Montana
11-02-2006, 04:26
Brent, the size of a replacement Genset is personal depending on the
needs of the owner. Blue Birds are steel and heat up in the sun.
that is one reason many want major Watt gensets. Exact replacement
units will fit in the bay with little modifications but I read that
many owners have modified their radiator locations. You could always
find a used later model RV style genset and shove it in the big
opening only to upgrade to a larger one if you determine if your
needs require. There are repair facilities that specialize in RV gen
service and the one here in SoCal always has used warranty units for
sale. RV gensets differ from construction genset because the exhaust
which uses horsepower to make it quiet are set up different. Y2K
caused a glut of backup low quality gensets to come into existance so
chose a RV name brand. Did the advert say Brand new 3208 or reman
obsolete Cat?
GregoryO'Connor
<swartzentruber1@...> wrote:
> Eric,
I
> Any thoughts . . .
> > Hi Brent,
> diesel generator in
for
our
more
> > 84FC35SBWL2
> <swartzentruber1@>
> FC33? I'm
> for the
> installed?
> > > Thanks in advance,
> > > Brent
11-02-2006, 12:36
Great ideas and information.
My experience is in a large aluminum Lance camper, in which I rarely
used Air or the generator for that matter. So I'm hoping I could
get by with a 5-7KW unit. I would prefer diesel or LP just to keep
the number of different fuels to a minimum, but in the end my budget
will decide. If we are boondocking, it will likely be on the beach,
desert in winter, or in the mountains - not too hot.
I had read that someone raised their gen compartment to increase
ground-clearance. I assume they had to use a smaller gen to allow
for the change.
replacement
that
always
gen
for
exhaust
so
> obsolete Cat?
> GregoryO'Connor
> <swartzentruber1@> wrote:
> > Eric,
if
> I
asking
> > Any thoughts . . .
> > wrote:
> > > Hi Brent,
PowerTech
> > diesel generator in
> for
good,
our
small
> our
> more
> > > 84FC35SBWL2
> > <swartzentruber1@>
> > FC33? I'm
except
> > for the
> > installed?
> > > > Thanks in advance,
> > > > Brent
