WATER PROBLEMS
11-25-2006, 14:25
WATER PROBLEMS
WHEN TRYING TO FILL MY WATER TANK, I SEE WATER LEAKING OUT OF THE
COACH ABOVE THE FUEL TANK.I HAVE CHECKED ALL THE DRAIN VALVES AND THEY
ARE CLOSED.ARE THERE SEALS IN THE BRASS VALVES THAT ARE THE DRAIN
VALVES.( THE LONG HANDLE VALVES)DOES THE COACH HAVE A VALVE THAT OPENS
WHEN THE TANK GETS FULL OR DOES THE WATER PRESSURE JUST GO THROUGHOUT
THE COACH?
WHEN I USE THE WATER SYSTEM WITH THE TANK VALVE CLOSED EVERYTHING IS
NORMAL AND NO LEAKS UNDER THE COACH. I SEE NO WATER INSIDE THE COACH
AROUND THE TANK, HOT WATER HEATER ANY VALVES OR LINES
THANKS FOR ANY HELP YOU GUYS MAY GIVE
RE BRAKE 83 FC-35 SB "SAGECOACH"
11-25-2006, 16:08
WATER PROBLEMS
Sounds like the fresh tank is overflowing. Mine will do the same thing when
it is overfilled. Just turn off the tank fill switch and it should quit.
Full water pressure will be delivered to the coach by shore water. Your
sporlan Valve may be malfunctioning..
Stephen H
81 FC33-SB
Florida
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of putneyflash
Sent: Saturday, November 25, 2006 9:25 PM
Subject: [WanderlodgeForum] WATER PROBLEMS
THE COACH?
11-26-2006, 01:51
WATER PROBLEMS
Thanks is that the valve in the water line that diverts the water from tank to
coach when the water tank switch is turned on? My tank lights show empty .
thanks for the response
re brake 1983 fc-35
> From: "Stephen H" <share@...>
> Date: 2006/11/25 Sat PM 11:08:12 EST
> To:
> Subject: RE: [WanderlodgeForum] WATER PROBLEMS
> Stephen H
> 81 FC33-SB
> Florida
> _____
> THE COACH?
11-26-2006, 02:22
WATER PROBLEMS
Re Brake, I have just been "fiddling" with the water system on my 81FC35. The
Sporlan was stuck all or slightly open, This causes a few things, first, it will
let shore line water pressure charge the lines in the coach as well as try to
fill the storage tank (depending on how much it is stuck), this will ultimately
result on water coming out of the tank overflow and running on the ground. If it
were to stick closed (not energized, as if outside switch were in off position,
even if you hold it on "fill"), you would get water out of the inside coach
lines, but not fill the tank. On my rig, the valve was stuck slightly open adn I
could not get water pressure in the coach from the onboard water pump, the pump
would run, but the water just ran around in a closed circut adn never build
pressure. The valve I worked on is under the drivers side bed, betweed teh water
tank and the hot water heater, mounted to the floor. It has a little tag on it
that says "Sporlan" (I think that is
some other language for "finicky). You can take it apart by removing the 4, 3/8
bolts and check it out. Don't lost the little spring. Re-build kits are
available. Good Luck, Doug
putneyflash@... wrote: Thanks is that the valve in the water
line that diverts the water from tank to coach when the water tank switch is
re brake 1983 fc-35
> To:
> Stephen H
> 81 FC33-SB
> Florida
> _____
> THE COACH?
Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey"
Check out the all-new Yahoo! Mail beta - Fire up a more powerful email and get
things done faster.
11-26-2006, 11:24
WATER PROBLEMS
Mine is labeled "Tank Fill" it is located in the outside compartment right
beside where you hook up the fresh water hose.
If the sporlan valve is working correctly, tank should not overfill if in
the off position.
I had to install a rebuild kit- from Stephen Birtles, and all is well. Easy
to replace once the bed, and wood is out of the way.
Stephen 81 FC-33SB
_____
putneyflash@...
Sent: Sunday, November 26, 2006 8:52 AM
Subject: Re: RE: [WanderlodgeForum] WATER PROBLEMS
to coach when the water tank switch is turned on? My tank lights show empty
re brake 1983 fc-35
> From: "Stephen H" <share@tampabay. <mailto:share%40tampabay.rr.com>
rr.com>
> To:
yahoogroups.com>
when
> Stephen H
> 81 FC33-SB
> Florida
11-27-2006, 14:44
WATER PROBLEMS
if you can give me stephen's e mail i will contact him. i took it apart todat
but did not remove the base unit from the lines.
thanks again
re brake
> Date: 2006/11/26 Sun PM 06:24:18 EST
> To:
> Subject: RE: RE: [WanderlodgeForum] WATER PROBLEMS
> the off position.
> Stephen 81 FC-33SB
> _____
> putneyflash@...
> re brake 1983 fc-35
> rr.com>
> > To:
> yahoogroups.com>
> when
> > Stephen H
> > 81 FC33-SB
> > Florida
11-28-2006, 12:37
WATER PROBLEMS
Here is one email address for Stephen Birtles. sbirtles@...
Curt Sprenger
Anaheim Hills, Calif.
>thanks again
>re brake
>>To:
>>the off position.
>>Stephen 81 FC-33SB
>> _____
>>putneyflash@...
>>re brake 1983 fc-35
>>rr.com>
>>>To:
>>yahoogroups.com>
>>when
>>>Stephen H
>>>81 FC33-SB
>>>Florida
>Yahoo! Groups Links
11-28-2006, 12:59
WATER PROBLEMS
Stephen can also be reached at
sbirtles@...<sbirtles%40cogeco.ca>
> Curt Sprenger
> todat but did not remove the base unit from the lines.
> >thanks again
> >re brake
> >>From: "Stephen H" <share@... <share%40tampabay.rr.com>>
> >>To:
> right
> in
> >>the off position.
> Easy
> >>Stephen 81 FC-33SB
> >> _____
> On Behalf Of
> >>putneyflash@... > >>Sent: Sunday, November 26, 2006 8:52 AM
> tank
> empty
> >>re brake 1983 fc-35
> >>>From: "Stephen H" <share@tampabay. <mailto:share% <share%25>40tampabay.
> rr.com>
> >>rr.com>
> >>>To:
> >>yahoogroups.com>
> >>when
> quit.
> >>>Stephen H
> >>>81 FC33-SB
> >>>Florida
> >Yahoo! Groups Links
Rob, Sue & Merlin Robinson
94 WLWB
11-28-2006, 14:22
WATER PROBLEMS
Thanks guys, steve called me and the repair kit is on the way. Thanks alot
re brake 1983 FC-35 sb "sagecoach"
> From: "Rob Robinson"
> Date: 2006/11/28 Tue PM 07:59:52 EST
> Subject: Re: [WanderlodgeForum] WATER PROBLEMS
> > Curt Sprenger
> > >thanks again
> > >re brake
> > >>To:
> > right
> > in
> > >>the off position.
> > Easy
> > >>Stephen 81 FC-33SB
> > >> _____
> > On Behalf Of
> > >>putneyflash@... > > >>Sent: Sunday, November 26, 2006 8:52 AM
> > tank
> > empty
> > >>re brake 1983 fc-35
> > rr.com>
> > >>rr.com>
> > >>>To:
> > >>yahoogroups.com>
> > >>when
> > quit.
> > >>>Stephen H
> > >>>81 FC33-SB
> > >>>Florida
> > >Yahoo! Groups Links
> 94 WLWB
11-28-2006, 14:25
WATER PROBLEMS
I talked to R.E. today his sporlan kit is on the way
thanks to all
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "Rob Robinson"
> > Curt Sprenger
apart
> > >thanks again
> > >re brake
> > >>To:
> > right
overfill if
> > in
> > >>the off position.
well.
> > Easy
> > >>Stephen 81 FC-33SB
> > >> _____
> > >>From:
> > On Behalf Of
> > >>To:
water from
> > tank
show
> > empty
> > >>re brake 1983 fc-35
> > rr.com>
> > >>rr.com>
> > >>>To:
> > >>yahoogroups.com>
same thing
> > >>when
> > quit.
water. Your
> > >>>Stephen H
> > >>>81 FC33-SB
> > >>>Florida
> > >Yahoo! Groups Links
> 94 WLWB
