Issues with 84 35FC
11-27-2006, 08:50
Issues with 84 35FC
Hi All,
After a trip out to my sisters and beyond, the Bird ran great, I just had a couple of questions regarding and engine alarm light that keep coming on and off... All the vital signs of oil, oil temp, water temp, transmission temp and all levels were up to where they are supposed to be... Does anyone have an idea why this was happening??? Also a buzzer was going off from the day I first drove the Bus... I had the digital multimeter out and was checking the bus=zzer, when I put the probes on both terminals, it stopped buzzing, strange!!! Any ideas on these issues??? Suggestions... Also I put the coach in a storage facility and it is 50 miles from me now, I need to know the group size of the Gen battery, as I will have to replace it, it started to get weak when trying to start it yesterday, had to use the aux batt switch... Enough for now... TIA Sea Ya Larry 84 35FCSB NYC --------------------------------- Access over 1 million songs - Yahoo! Music Unlimited. [Non-text portions of this message have been removed] |
11-27-2006, 09:04
Issues with 84 35FC
Larry,
The size for the generator (4 cyl Perkins) on my coach is "group 31". Yours could vary. Steve Anderson 79 FC 35 Poulsbo, Wa. -----Original Message----- From: sailor7cs_365@... To: wanderlodgeforum@yahoogroups.com Sent: Mon, 27 Nov 2006 12:50 PM Subject: [WanderlodgeForum] Issues with 84 35FC Hi All, After a trip out to my sisters and beyond, the Bird ran great, I just had a couple of questions regarding and engine alarm light that keep coming on and off... All the vital signs of oil, oil temp, water temp, transmission temp and all levels were up to where they are supposed to be... Does anyone have an idea why this was happening??? Also a buzzer was going off from the day I first drove the Bus... I had the digital multimeter out and was checking the bus=zzer, when I put the probes on both terminals, it stopped buzzing, strange!!! Any ideas on these issues??? Suggestions... Also I put the coach in a storage facility and it is 50 miles from me now, I need to know the group size of the Gen battery, as I will have to replace it, it started to get weak when trying to start it yesterday, had to use the aux batt switch... Enough for now... TIA Sea Ya Larry 84 35FCSB NYC --------------------------------- Access over 1 million songs - Yahoo! Music Unlimited. [Non-text portions of this message have been removed] ________________________________________________________________________ Check out the new AOL. Most comprehensive set of free safety and security tools, free access to millions of high-quality videos from across the web, free AOL Mail and more. [Non-text portions of this message have been removed] |
11-27-2006, 09:53
Issues with 84 35FC
Larry- my 84 35FC had the intermitten buzzer come on, also. I checked all the
gauges and just surmised that it was another gremlin in the coach. Seemed to phase out the longer I drove her. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
11-27-2006, 10:40
Issues with 84 35FC
Hi Larry:
Your engine alarm light intermittent is usually caused by the temp sensor wire at the top of the radiator being broken or bad connector to ground. There is a major stress point on the wiring harness that goes through the frame on the drivers side. This is a common problem. The buzzer, depending on which system it is for could be the sensor, or ground, I would bet on the ground. It stops buzzing with the meter because your adding a resistance through the meter and supplying a floating ground, so to speak with the added resistance. On Bird's, when things are going haywire with systems, one checks the grounds, then when nothing is found, one checks grounds, then you repair it by fixing the ground. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma At 12:50 PM 11/27/2006 -0800, you wrote: >Hi All, >After a trip out to my sisters and beyond, the Bird ran great, I just had >a couple of questions regarding and engine alarm light that keep coming on >and off... >All the vital signs of oil, oil temp, water temp, transmission temp and >all levels were up to where they are supposed to be... Does anyone have an >idea why this was happening??? >Also a buzzer was going off from the day I first drove the Bus... I had >the digital multimeter out and was checking the bus=zzer, when I put the >probes on both terminals, it stopped buzzing, strange!!! >Any ideas on these issues??? Suggestions... >Also I put the coach in a storage facility and it is 50 miles from me now, >I need to know the group size of the Gen battery, as I will have to >replace it, it started to get weak when trying to start it yesterday, had >to use the aux batt switch... >Enough for now... >TIA >Sea Ya >Larry >84 35FCSB >NYC > > |
11-27-2006, 11:12
Issues with 84 35FC
Mine was doing the same thing when I bought it and a buzzer wire was cut. I
assume the alarm light and buzzer are connected. All my levels were fine also. I stopped doing it after a while. I have no idea why. If you find the source of your problem, let me know. I anticipate mine will reoccur. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, Larry > > Hi All, > After a trip out to my sisters and beyond, the Bird ran great, I just had a couple of questions regarding and engine alarm light that keep coming on and off... > All the vital signs of oil, oil temp, water temp, transmission temp and all levels were up to where they are supposed to be... Does anyone have an idea why this was happening??? > Also a buzzer was going off from the day I first drove the Bus... I had the digital multimeter out and was checking the bus=zzer, when I put the probes on both terminals, it stopped buzzing, strange!!! > Any ideas on these issues??? Suggestions... > Also I put the coach in a storage facility and it is 50 miles from me now, I need to know the group size of the Gen battery, as I will have to replace it, it started to get weak when trying to start it yesterday, had to use the aux batt switch... > Enough for now... > TIA > Sea Ya > Larry > 84 35FCSB > NYC > > > --------------------------------- > Access over 1 million songs - Yahoo! Music Unlimited. > > [Non-text portions of this message have been removed] > |
11-27-2006, 12:40
Issues with 84 35FC
Lary,
Turn up the stereo, it will drown out that annoying buzzer. Where is your storage facility? I am in New Jersey and have a 15 or 20 mile trip to my bird, near Greenwood Lake. I am not sure where you are in NYC, but this one is about 12 miles from the thruway/287 interchange. $68/month, security cameras. The owner also runs an excavation business out of the location so he has some skin in the security game as well. It is outdoors, however. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, Larry wrote: > > Hi All, > After a trip out to my sisters and beyond, the Bird ran great, I just had a couple of questions regarding and engine alarm light that keep coming on and off... > All the vital signs of oil, oil temp, water temp, transmission temp and all levels were up to where they are supposed to be... Does anyone have an idea why this was happening??? > Also a buzzer was going off from the day I first drove the Bus... I had the digital multimeter out and was checking the bus=zzer, when I put the probes on both terminals, it stopped buzzing, strange!!! > Any ideas on these issues??? Suggestions... > Also I put the coach in a storage facility and it is 50 miles from me now, I need to know the group size of the Gen battery, as I will have to replace it, it started to get weak when trying to start it yesterday, had to use the aux batt switch... > Enough for now... > TIA > Sea Ya > Larry > 84 35FCSB > NYC > > > --------------------------------- > Access over 1 million songs - Yahoo! Music Unlimited. > > [Non-text portions of this message have been removed] > |
11-27-2006, 12:59
Issues with 84 35FC
Gardner,
That's what I have been doing ;o)... I am on City Island, The Bronx, NYC... I store the coach in Chester, NY off of US 17, I only pay $70... Gated, cameras, 6am - 8pm access 7 days/week... Sea Ya Larry NYC 84 35FCSB Gardner Yeaw Lary, Turn up the stereo, it will drown out that annoying buzzer. Where is your storage facility? I am in New Jersey and have a 15 or 20 mile trip to my bird, near Greenwood Lake. I am not sure where you are in NYC, but this one is about 12 miles from the thruway/287 interchange. $68/month, security cameras. The owner also runs an excavation business out of the location so he has some skin in the security game as well. It is outdoors, however. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, Larry wrote: > > Hi All, > After a trip out to my sisters and beyond, the Bird ran great, I just had a couple of questions regarding and engine alarm light that keep coming on and off... > All the vital signs of oil, oil temp, water temp, transmission temp and all levels were up to where they are supposed to be... Does anyone have an idea why this was happening??? > Also a buzzer was going off from the day I first drove the Bus... I had the digital multimeter out and was checking the bus=zzer, when I put the probes on both terminals, it stopped buzzing, strange!!! > Any ideas on these issues??? Suggestions... > Also I put the coach in a storage facility and it is 50 miles from me now, I need to know the group size of the Gen battery, as I will have to replace it, it started to get weak when trying to start it yesterday, had to use the aux batt switch... > Enough for now... > TIA > Sea Ya > Larry > 84 35FCSB > NYC > > > --------------------------------- > Access over 1 million songs - Yahoo! Music Unlimited. > > [Non-text portions of this message have been removed] > --------------------------------- Everyone is raving about the all-new Yahoo! Mail beta. [Non-text portions of this message have been removed] |
11-27-2006, 13:02
Issues with 84 35FC
Hi Ralph,
Thank you, I will check out that ground and all the other grounds... Sea Ya Larry NYC 84 35FCSB "Ralph L. Fullenwider" Hi Larry: Your engine alarm light intermittent is usually caused by the temp sensor wire at the top of the radiator being broken or bad connector to ground. There is a major stress point on the wiring harness that goes through the frame on the drivers side. This is a common problem. The buzzer, depending on which system it is for could be the sensor, or ground, I would bet on the ground. It stops buzzing with the meter because your adding a resistance through the meter and supplying a floating ground, so to speak with the added resistance. On Bird's, when things are going haywire with systems, one checks the grounds, then when nothing is found, one checks grounds, then you repair it by fixing the ground. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma At 12:50 PM 11/27/2006 -0800, you wrote: >Hi All, >After a trip out to my sisters and beyond, the Bird ran great, I just had >a couple of questions regarding and engine alarm light that keep coming on >and off... >All the vital signs of oil, oil temp, water temp, transmission temp and >all levels were up to where they are supposed to be... Does anyone have an >idea why this was happening??? >Also a buzzer was going off from the day I first drove the Bus... I had >the digital multimeter out and was checking the bus=zzer, when I put the >probes on both terminals, it stopped buzzing, strange!!! >Any ideas on these issues??? Suggestions... >Also I put the coach in a storage facility and it is 50 miles from me now, >I need to know the group size of the Gen battery, as I will have to >replace it, it started to get weak when trying to start it yesterday, had >to use the aux batt switch... >Enough for now... >TIA >Sea Ya >Larry >84 35FCSB >NYC > > --------------------------------- Check out the all-new Yahoo! Mail beta - Fire up a more powerful email and get things done faster. [Non-text portions of this message have been removed] |
11-27-2006, 13:18
Issues with 84 35FC
Larry:
I don't know anything about FC's but I bet that bus=zzer will not bother you again. It is most likely fried. Is the light still blinking, ie are the light and buzzer related. Just a thought. Please do not turn up the stereo it could cost you a bundle. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Monday, November 27, 2006 6:40 PM Subject: [WanderlodgeForum] Re: Issues with 84 35FC Lary, Turn up the stereo, it will drown out that annoying buzzer. Where is your storage facility? I am in New Jersey and have a 15 or 20 mile trip to my bird, near Greenwood Lake. I am not sure where you are in NYC, but this one is about 12 miles from the thruway/287 interchange. $68/month, security cameras. The owner also runs an excavation business out of the location so he has some skin in the security game as well. It is outdoors, however. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, Larry wrote: > > Hi All, > After a trip out to my sisters and beyond, the Bird ran great, I just had a couple of questions regarding and engine alarm light that keep coming on and off... > All the vital signs of oil, oil temp, water temp, transmission temp and all levels were up to where they are supposed to be... Does anyone have an idea why this was happening??? > Also a buzzer was going off from the day I first drove the Bus... I had the digital multimeter out and was checking the bus=zzer, when I put the probes on both terminals, it stopped buzzing, strange!!! > Any ideas on these issues??? Suggestions... > Also I put the coach in a storage facility and it is 50 miles from me now, I need to know the group size of the Gen battery, as I will have to replace it, it started to get weak when trying to start it yesterday, had to use the aux batt switch... > Enough for now... > TIA > Sea Ya > Larry > 84 35FCSB > NYC > > > --------------------------------- > Access over 1 million songs - Yahoo! Music Unlimited. > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
11-27-2006, 13:23
Issues with 84 35FC
Larry,
Mine isn't gated, but the main office building has a living facility so I think there is someone there most of the time so it's pretty safe. I haven't had any problems. They also store 18 wheeler truck tractors and boats plus the normal storage facility buildings. I am beginning to think I should store it closer to home since I seem to bring it home every weekend to work on it. The mileage adds up and with towing the Jeep I think I am spending more than the extra cost of local storage. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, Larry wrote: > > Gardner, > That's what I have been doing ;o)... > I am on City Island, The Bronx, NYC... > I store the coach in Chester, NY off of US 17, I only pay $70... Gated, cameras, 6am - 8pm access 7 days/week... > Sea Ya > Larry > NYC > 84 35FCSB > > > > Gardner Yeaw wrote: Lary, > Turn up the stereo, it will drown out that annoying buzzer. > Where is your storage facility? I am in New Jersey and have a 15 or > 20 mile trip to my bird, near Greenwood Lake. I am not sure where > you are in NYC, but this one is about 12 miles from the thruway/287 > interchange. $68/month, security cameras. The owner also runs an > excavation business out of the location so he has some skin in the > security game as well. It is outdoors, however. > > Gardner > 78FC33 > > --- In WanderlodgeForum@yahoogroups.com, Larry > wrote: > > > > Hi All, > > After a trip out to my sisters and beyond, the Bird ran great, I > just had a couple of questions regarding and engine alarm light that > keep coming on and off... > > All the vital signs of oil, oil temp, water temp, transmission > temp and all levels were up to where they are supposed to be... Does > anyone have an idea why this was happening??? > > Also a buzzer was going off from the day I first drove the Bus... > I had the digital multimeter out and was checking the bus=zzer, when > I put the probes on both terminals, it stopped buzzing, strange!!! > > Any ideas on these issues??? Suggestions... > > Also I put the coach in a storage facility and it is 50 miles from > me now, I need to know the group size of the Gen battery, as I will > have to replace it, it started to get weak when trying to start it > yesterday, had to use the aux batt switch... > > Enough for now... > > TIA > > Sea Ya > > Larry > > 84 35FCSB > > NYC > > > > > > --------------------------------- > > Access over 1 million songs - Yahoo! Music Unlimited. > > > > [Non-text portions of this message have been removed] > > > > > > > > > --------------------------------- > Everyone is raving about the all-new Yahoo! Mail beta. > > [Non-text portions of this message have been removed] > |
