Aux. air up for Pokey??
11-28-2006, 07:53
Doug- under the coach on one of the air tanks is a Schrader valve that you
can attach an air line to. It's way up there- I had to use a flashlite- old eyes. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
11-28-2006, 11:07
OK, I got my cruise repaired and wanted to air the system up to see if
I had solved the air bleed off from the vaccum generator (plus I think I may have an air bag leak after BOUNDING through the delapidated highways of New Orleans on the way home). It's cold here in Gunnison and Pokey becomes "Smokey" when started if it's too cold, and I try not to start her unless I have time to let her fully warm up and maybe go for a short drive (...maybe Cabo...). So I hooked shop air up to the aux. air port in the left center compartment, and got some air in one tank, but didn't look like any went in the other. Is there an easy way to air the rig up using shop air?? Thanks as always, Doug |
11-28-2006, 14:38
ON my 1983 FC-35 their is a service valve for shop air behind the lube oil
reservoir, (Close to the air dryer) that should fill all tanksand reflect on your dash gages. Hope this helps re brake 1983 fc-35 > > From: "doug_ngl" > Date: 2006/11/28 Tue PM 06:07:06 EST > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Aux. air up for Pokey?? > > OK, I got my cruise repaired and wanted to air the system up to see if > I had solved the air bleed off from the vaccum generator (plus I think > I may have an air bag leak after BOUNDING through the delapidated > highways of New Orleans on the way home). It's cold here in Gunnison > and Pokey becomes "Smokey" when started if it's too cold, and I try not > to start her unless I have time to let her fully warm up and maybe go > for a short drive (...maybe Cabo...). So I hooked shop air up to the > aux. air port in the left center compartment, and got some air in one > tank, but didn't look like any went in the other. Is there an easy way > to air the rig up using shop air?? Thanks as always, Doug > > > |
11-28-2006, 16:18
Thanks, I'll look tomorrow. Doug
putneyflash@... wrote: ON my 1983 FC-35 their is a service valve for shop air behind the lube oil reservoir, (Close to the air dryer) that should fill all tanksand reflect on your dash gages. Hope this helps re brake 1983 fc-35 > > From: "doug_ngl" > Date: 2006/11/28 Tue PM 06:07:06 EST > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Aux. air up for Pokey?? > > OK, I got my cruise repaired and wanted to air the system up to see if > I had solved the air bleed off from the vaccum generator (plus I think > I may have an air bag leak after BOUNDING through the delapidated > highways of New Orleans on the way home). It's cold here in Gunnison > and Pokey becomes "Smokey" when started if it's too cold, and I try not > to start her unless I have time to let her fully warm up and maybe go > for a short drive (...maybe Cabo...). So I hooked shop air up to the > aux. air port in the left center compartment, and got some air in one > tank, but didn't look like any went in the other. Is there an easy way > to air the rig up using shop air?? Thanks as always, Doug > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" --------------------------------- Everyone is raving about the all-new Yahoo! Mail beta. [Non-text portions of this message have been removed] |
