Prepping for trip - advice?
12-03-2006, 07:48
I'm prep-ing the new Lodge ( 77FC31) for it's first major "wander" down
in Baja. Any suggestions on spare parts? Special tools So far I've replaced those 8yr old front tires with new Kumhos (BTW they looked pretty good inside and out). Fixed the Onan - new starter did the trick. Replaced leaky air brake valve. Raplaced fluids. Added GPS on roof. [Non-text portions of this message have been removed] |
12-03-2006, 08:45
Complete set of filters, fuel and air for engine and generator. Air hose so you
can air up tires from onboard compressor. I always carry a couple of different kinds of epoxy for a variety of repairs. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Brent Swartzentruber" <swartzentruber1@...> wrote: > > > I'm prep-ing the new Lodge ( 77FC31) for it's first major "wander" down > in Baja. Any suggestions on spare parts? Special tools > > So far I've replaced those 8yr old front tires with new Kumhos (BTW they > looked pretty good inside and out). Fixed the Onan - new starter did > the trick. Replaced leaky air brake valve. Raplaced fluids. Added GPS > on roof. > > > > [Non-text portions of this message have been removed] > |
12-03-2006, 09:08
I've been told that it is wise to carry a mounted spare tire or at the least
a spare tire. According to some the roads are narrow and tire damage often occurs when right hand side of vehicle slips off pavement (ie no shoulders). On 03/12/06, davidkerryedwards > > Complete set of filters, fuel and air for engine and generator. Air hose > so you can air up > tires from onboard compressor. I always carry a couple of different kinds > of epoxy for a > variety of repairs. > > Kerry > 82 FC 35 > Denver > --- In WanderlodgeForum@yahoogroups.com > "Brent Swartzentruber" > <swartzentruber1@...> wrote: > > > > > > I'm prep-ing the new Lodge ( 77FC31) for it's first major "wander" down > > in Baja. Any suggestions on spare parts? Special tools > > > > So far I've replaced those 8yr old front tires with new Kumhos (BTW they > > looked pretty good inside and out). Fixed the Onan - new starter did > > the trick. Replaced leaky air brake valve. Raplaced fluids. Added GPS > > on roof. > > > > > > > > [Non-text portions of this message have been removed] > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
12-03-2006, 09:58
Brent, Have you checked to see if you have a swing
radiator? If you do or don't I would take a set of belts, oil for both engines, 2 qts genny & 4 qts engine oil, gravel roads? a spare sealed beam, Good Insurance acceptable in Mexico, I like duct tape, no kidding!, and a coil o clothesline multi-strand wire, some fuel & radiator hose clamps, a small digital multimeter, your manual and diagrams, a few small tools, filters have been mentioned in case you run into crumy fuel (PeMex), money for bribes in case you come across some crumy cops, tire gage that reads well in your tire pressure range. Pack like you may need it and chances are you won;t. Don't pack that way and chances are you will. Above all take the will to have a great time going, being there, then returning, bring back with you the experience of a lifetime & have a ball doing it. bob janes, greenville, sc --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > Complete set of filters, fuel and air for engine and generator. Air hose so you can air up > tires from onboard compressor. I always carry a couple of different kinds of epoxy for a > variety of repairs. > > Kerry > 82 FC 35 > Denver > --- In WanderlodgeForum@yahoogroups.com, "Brent Swartzentruber" > <swartzentruber1@> wrote: > > > > > > I'm prep-ing the new Lodge ( 77FC31) for it's first major "wander" down > > in Baja. Any suggestions on spare parts? Special tools > > > > So far I've replaced those 8yr old front tires with new Kumhos (BTW they > > looked pretty good inside and out). Fixed the Onan - new starter did > > the trick. Replaced leaky air brake valve. Raplaced fluids. Added GPS > > on roof. > > > > > > > > [Non-text portions of this message have been removed] > > > |
12-03-2006, 10:34
All good items for the list - thanks guys. What about parts like a
starter or alternator? Do these things ever fail on the 3208? I'm also planning on buying 4 new batteries. Bob - what's a spare sealed beam? Brent Swartzentruber 77fc31 Ventura, CA --- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot" > > Brent, Have you checked to see if you have a swing > radiator? If you do or don't I would take a set of > belts, oil for both engines, 2 qts genny & 4 qts > engine oil, gravel roads? a spare sealed beam, > Good Insurance acceptable in Mexico, I like duct tape, > no kidding!, and a coil o clothesline multi-strand wire, > some fuel & radiator hose clamps, a small digital > multimeter, your manual and diagrams, a few small > tools, filters have been mentioned in case you run > into crumy fuel (PeMex), money for bribes in case you > come across some crumy cops, tire gage that reads > well in your tire pressure range. > > Pack like you may need it and chances are you won;t. > Don't pack that way and chances are you will. > > Above all take the will to have a great time going, > being there, then returning, bring back with you the > experience of a lifetime & have a ball doing it. > > bob janes, greenville, sc > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > Complete set of filters, fuel and air for engine and generator. > Air hose so you can air up > > tires from onboard compressor. I always carry a couple of > different kinds of epoxy for a > > variety of repairs. > > > > Kerry > > 82 FC 35 > > Denver > > --- In WanderlodgeForum@yahoogroups.com, "Brent Swartzentruber" > > <swartzentruber1@> wrote: > > > > > > > > > I'm prep-ing the new Lodge ( 77FC31) for it's first > major "wander" down > > > in Baja. Any suggestions on spare parts? Special tools > > > > > > So far I've replaced those 8yr old front tires with new Kumhos > (BTW they > > > looked pretty good inside and out). Fixed the Onan - new starter > did > > > the trick. Replaced leaky air brake valve. Raplaced fluids. > Added GPS > > > on roof. > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > |
12-03-2006, 12:22
Brent: Take plenty of FUEL FILTERS, recommend four each......, air compressor to run AIR tool to get off radiator, to change belts and take a spare"ford" fan blade and one and 1/4 open end wrench and some spare belts and get $79 GOOD SAM tow insurance just in case. Have fun in Baja... Regards, Hank Hannigan 90SP36 80FC31...FOR SALE BOTH in storage in Vegas until we return home from Australia in late January In WanderlodgeForum@yahoogroups.com, "Brent Swartzentruber" <swartzentruber1@...> wrote: > > > I'm prep-ing the new Lodge ( 77FC31) for it's first major "wander" down > in Baja. Any suggestions on spare parts? Special tools > > So far I've replaced those 8yr old front tires with new Kumhos (BTW they > looked pretty good inside and out). Fixed the Onan - new starter did > the trick. Replaced leaky air brake valve. Raplaced fluids. Added GPS > on roof. > > > > [Non-text portions of this message have been removed] > |
12-03-2006, 14:27
That "sealed beam" is your headlight.
Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Brent Swartzentruber To: WanderlodgeForum@yahoogroups.com Sent: Sunday, December 03, 2006 4:34 PM Subject: [WanderlodgeForum] Re: Prepping for trip - advice? All good items for the list - thanks guys. What about parts like a starter or alternator? Do these things ever fail on the 3208? I'm also planning on buying 4 new batteries. Bob - what's a spare sealed beam? Brent Swartzentruber 77fc31 Ventura, CA --- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot" > > Brent, Have you checked to see if you have a swing > radiator? If you do or don't I would take a set of > belts, oil for both engines, 2 qts genny & 4 qts > engine oil, gravel roads? a spare sealed beam, > Good Insurance acceptable in Mexico, I like duct tape, > no kidding!, and a coil o clothesline multi-strand wire, > some fuel & radiator hose clamps, a small digital > multimeter, your manual and diagrams, a few small > tools, filters have been mentioned in case you run > into crumy fuel (PeMex), money for bribes in case you > come across some crumy cops, tire gage that reads > well in your tire pressure range. > > Pack like you may need it and chances are you won;t. > Don't pack that way and chances are you will. > > Above all take the will to have a great time going, > being there, then returning, bring back with you the > experience of a lifetime & have a ball doing it. > > bob janes, greenville, sc > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > Complete set of filters, fuel and air for engine and generator. > Air hose so you can air up > > tires from onboard compressor. I always carry a couple of > different kinds of epoxy for a > > variety of repairs. > > > > Kerry > > 82 FC 35 > > Denver > > --- In WanderlodgeForum@yahoogroups.com, "Brent Swartzentruber" > > <swartzentruber1@> wrote: > > > > > > > > > I'm prep-ing the new Lodge ( 77FC31) for it's first > major "wander" down > > > in Baja. Any suggestions on spare parts? Special tools > > > > > > So far I've replaced those 8yr old front tires with new Kumhos > (BTW they > > > looked pretty good inside and out). Fixed the Onan - new starter > did > > > the trick. Replaced leaky air brake valve. Raplaced fluids. > Added GPS > > > on roof. > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] |
12-04-2006, 03:05
Brent,
When we made that trip in 2003 we carried a spare unmounted tire on top. Finding a duplicate in Mexico could prove very difficult or impossible but they can replace if you have the tire. I picked the best looking of the take offs. Good luck Dick Hayden - '87 PT 38 - Lake Stevens, WA [Non-text portions of this message have been removed] |
