Hot water and boondocking
12-11-2006, 08:44
I have a system such as you describe in my home. A small pump and timer
(110 volt) in the water hot water line circulates the hot water throughout the
house, so hot water is available at each faucet when it is turned on. The
timer can be set like a light timer, so it does not circulate at night.
Roger Webb
91WBWL
Cedar Rapids, IA
12-11-2006, 13:24
We took a 4 day trip and had only power available. I left with a
full water tank and mostly empty grey and black tanks. By the last
day I had about 1/4 tank of water left. I began to think about ways
to conserve water to streach the time we could stay. One thought was
the waste of water waiting for the sink or shower hot water to come
up to temperature. It was cold outside so it took a while, wasted
water and holding tank capacity.
In hotels/motels/large buildings they use a circulating system
that keeps the hot water supply hot so you don't wait for hot water
at the tub or tap. It would seem that this could be done in an RV by
adding a return line from the far end of the hot water system, a one-
way valve and a pump. Then all you would need to do is activate the
pump for a minute or so to charge the system, and then start the
shower. It would conserve the water supply as well as the grey tank
space.
Has anyone seen this kind of system in use?
Gardner
78FC33
12-11-2006, 13:34
Gardner,
I'm all ears for this. Had the same thought while out camping this past
weekend. Thanks for posting.
Curt Sprenger
Anaheim Hills, Calif.
>space.
>Gardner
>78FC33
>Yahoo! Groups Links
12-11-2006, 13:44
One easy water saver is a recirculating toilet. I had one in my previous Travco
and really
liked it. I haven't seen a hot water recirculating system on an RV. You could
catch the
cold water in a pan and use it to wash dishes etc.
Kerry
82 FC 35
Denver
> space.
> Gardner
> 78FC33
12-11-2006, 14:01
Gardner,
Form my post last night:
It seems like Kathy and are in cold weather a lot and many times dry
camping. I hated to waste water getting hot water to the shower so I routed
a return line from the shower back to the water heater. I then placed a
relay on the pressure control switch of the primary pump to control both
pumps. If the primary pump is running the recirculation pump is off. If
pressure is up and the primary pump shuts off then the recirculation pump
runs. When you turn the pump switch on before stepping into the shower you
have instant hot water. It works well for it's intended purpose to conserve
water but I don't believe that it would keep the cold water side from
freezing.
- Chuck Wheeler -
82 FC 31 SB
Fort Worth, TX
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Gardner Yeaw
Sent: Monday, December 11, 2006 7:25 PM
Subject: [WanderlodgeForum] Hot water and boondocking
space.
Gardner
78FC33
12-11-2006, 14:19
Chuck,
Thanks. By the way, My wife's name is Kathy also, so it seems
that wives named Kathy like the solution, so it must be a winner.
I like the idea of using relays so that the pumps don't fight each
other. I have a similar relay logic system in my home. The garage
and bedroom share the same supply side for the hot water heating
system, so I built a relay logic system that gives the bedroom
priority. A little boolean logic and some radio shack relays and you
are in business.
Gardner
78FC33
--- In WanderlodgeForum@yahoogroups.com, "Chuck
winner. wrote:
> Gardner,
dry
I routed
placed a
control both
off. If
recirculation pump
shower you
conserve
from
> freezing.
> - Chuck Wheeler -
> 82 FC 31 SB
> Fort Worth, TX
> _____
ways
was
come
water
by
one-
tank
> space.
> Gardner
> 78FC33
12-11-2006, 17:09
Chuck and Gardner:
Am interested in this as well, by why can one not use the cold water line with a
few solenoids as well??
Terrace, B.C. Canada
----- Original Message ----
Sent: Monday, December 11, 2006 6:19:12 PM
Subject: [WanderlodgeForum] Re: Hot water and boondocking
Chuck,
are in business.
Gardner
78FC33
--- In WanderlodgeForum@ yahoogroups. com, "Chuck
winner. wrote:
> Gardner,
dry
I routed
placed a
control both
off. If
recirculation pump
shower you
conserve
from
> freezing.
> - Chuck Wheeler -
> 82 FC 31 SB
> Fort Worth, TX
> _____
> From: WanderlodgeForum@ yahoogroups. com
> [mailto:WanderlodgeForum@ yahoogroups. com] On Behalf Of Gardner Yeaw
> To: WanderlodgeForum@ yahoogroups. com
ways
was
come
> In hotels/motels/ large buildings they use a circulating system
water
by
one-
tank
> space.
> Gardner
> 78FC33
#ygrp-mlmsg {font-size:13px;font-family:arial,helvetica,clean,sans-serif;}
#ygrp-mlmsg table {font-size:inherit;font:100%;}
#ygrp-mlmsg select, input, textarea {font:99% arial,helvetica,clean,sans-serif;}
#ygrp-mlmsg pre, code {font:115% monospace;}
#ygrp-mlmsg * {line-height:1.22em;}
#ygrp-text{
font-family:Georgia;
#ygrp-text p{
margin:0 0 1em 0;
#ygrp-tpmsgs{
font-family:Arial;
clear:both;
#ygrp-vitnav{
padding-top:10px;
font-family:Verdana;
font-size:77%;
margin:0;
#ygrp-vitnav a{
padding:0 1px;
#ygrp-actbar{
clear:both;
margin:25px 0;
white-space:nowrap;
color:#666;
text-align:right;
#ygrp-actbar .left{
float:left;
white-space:nowrap;
.bld{font-weight:bold;}
#ygrp-grft{
font-size:77%;
padding:15px 0;
#ygrp-ft{
font-family:verdana;
font-size:77%;
border-top:1px solid #666;
padding:5px 0;
#ygrp-mlmsg #logo{
padding-bottom:10px;
#ygrp-vital{
background-color:#e0ecee;
margin-bottom:20px;
padding:2px 0 8px 8px;
#ygrp-vital #vithd{
font-size:77%;
font-weight:bold;
color:#333;
text-transform:uppercase;
#ygrp-vital ul{
padding:0;
margin:2px 0;
#ygrp-vital ul li{
list-style-type:none;
clear:both;
border:1px solid #e0ecee;
#ygrp-vital ul li .ct{
font-weight:bold;
color:#ff7900;
float:right;
width:2em;
text-align:right;
padding-right:.5em;
#ygrp-vital ul li .cat{
font-weight:bold;
#ygrp-vital a {
text-decoration:none;
#ygrp-vital a:hover{
text-decoration:underline;
#ygrp-sponsor #hd{
color:#999;
font-size:77%;
#ygrp-sponsor #ov{
padding:6px 13px;
margin-bottom:20px;
#ygrp-sponsor #ov ul{
padding:0 0 0 8px;
margin:0;
#ygrp-sponsor #ov li{
list-style-type:square;
padding:6px 0;
font-size:77%;
#ygrp-sponsor #ov li a{
font-size:130%;
#ygrp-sponsor #nc {
background-color:#eee;
margin-bottom:20px;
padding:0 8px;
#ygrp-sponsor .ad{
padding:8px 0;
#ygrp-sponsor .ad #hd1{
font-family:Arial;
font-weight:bold;
color:#628c2a;
font-size:100%;
line-height:122%;
#ygrp-sponsor .ad a{
#ygrp-sponsor .ad a:hover{
#ygrp-sponsor .ad p{
margin:0;
o {font-size:0;}
.MsoNormal {
margin:0 0 0 0;
#ygrp-text tt{
font-size:120%;
blockquote{margin:0 0 0 4px;}
.replbq {margin:4;}
Do You Yahoo!?
http://mail.yahoo.com
12-11-2006, 17:21
That's a real good idea Bill. Moving water won't "normally" freeze.
Terry Neal
Bozeman, MT
82PT40
74FC34
Wilhelmus Schreurs wrote:
> Chuck and Gardner:
> line with a few solenoids as well??
> From: Gardner Yeaw >
> Chuck,
> are in business.
> Gardner
> 78FC33
> winner. wrote:
> > Gardner,
> dry
> I routed
> placed a
> control both
> off. If
> recirculation pump
> shower you
> conserve
> from
> > freezing.
> > - Chuck Wheeler -
> > 82 FC 31 SB
> > Fort Worth, TX
> > _____
> ways
> was
> come
> water
> by
> one-
> the
> tank
> > space.
> > Gardner
> > 78FC33
> #ygrp-text{
> #ygrp-text p{
> margin:0 0 1em 0;
> #ygrp-tpmsgs{
> font-family:Arial;
> clear:both;
> #ygrp-vitnav{
> padding-top:10px;
> font-size:77%;
> margin:0;
> #ygrp-vitnav a{
> padding:0 1px;
> #ygrp-actbar{
> clear:both;
> margin:25px 0;
> white-space:nowrap;
> color:#666;
> text-align:right;
> #ygrp-actbar .left{
> float:left;
> white-space:nowrap;
> #ygrp-grft{
> font-size:77%;
> padding:15px 0;
> #ygrp-ft{
> font-size:77%;
> padding:5px 0;
> #ygrp-mlmsg #logo{
> #ygrp-vital{
> margin-bottom:20px;
> #ygrp-vital #vithd{
> font-size:77%;
> font-weight:bold;
> color:#333;
> #ygrp-vital ul{
> padding:0;
> margin:2px 0;
> #ygrp-vital ul li{
> clear:both;
> font-weight:bold;
> color:#ff7900;
> float:right;
> width:2em;
> text-align:right;
> padding-right:.5em;
> font-weight:bold;
> #ygrp-vital a {
> #ygrp-sponsor #hd{
> color:#999;
> font-size:77%;
> #ygrp-sponsor #ov{
> padding:6px 13px;
> margin-bottom:20px;
> padding:0 0 0 8px;
> margin:0;
> padding:6px 0;
> font-size:77%;
> font-size:130%;
> #ygrp-sponsor #nc {
> margin-bottom:20px;
> padding:0 8px;
> #ygrp-sponsor .ad{
> padding:8px 0;
> font-family:Arial;
> font-weight:bold;
> color:#628c2a;
> font-size:100%;
> line-height:122%;
> margin:0;
> o {font-size:0;}
> .MsoNormal {
> margin:0 0 0 0;
> #ygrp-text tt{
> font-size:120%;
> .replbq {margin:4;}
> Do You Yahoo!?
> http://mail.yahoo.com <http://mail.yahoo.com>
12-12-2006, 03:16
Gardner,
I like your hot water circulating idea.
Just a thought on cold water freeze up.
Could you put a seperate water heater in the cold water line with a circulating
pump and set a thermostat at say
50 degrees.
Howard Truitt
Camilla, Ga.
86 PT40
Sent: Monday, December 11, 2006 9:01 PM
Subject: RE: [WanderlodgeForum] Hot water and boondocking
Gardner,
freezing.
- Chuck Wheeler -
82 FC 31 SB
Fort Worth, TX
_____
space.
Gardner
78FC33
Checked by AVG Free Edition.
Version: 7.1.409 / Virus Database: 268.15.15/580 - Release Date: 12/8/2006
12-12-2006, 04:30
Gardner,
Thanks to Howard for his cold water idea. Here is a "whole house" hot
water recirculating kit that will do what we are talking about. Crosses
the hot water over to the cold line for it's return trip to the water
heater. No additional return line needed. Just buy an additional cold
water connector for any additional water line runs you may have. The PT
coaches have 2 runs, one down each side of the coach, so this will work.
Link is: http://www.rewci.com/whhohotwaci.html
Terry Neal
Bozeman, MT
82PT40
74FC34
Howard O. Truitt wrote:
> Gardner,
> circulating pump and set a thermostat at say
> 50 degrees.
> Howard Truitt
> Camilla, Ga.
> 86 PT40
> From: Chuck Wheeler
> Gardner,
> routed
> conserve
> freezing.
> - Chuck Wheeler -
> 82 FC 31 SB
> Fort Worth, TX
> _____
> space.
> Gardner
> 78FC33
