					Security system
					12-11-2006, 17:17
				 Post: #1 | |||
| Security system
					Need some advice from you long time birders: Has anyone thought of/or tied in there "security lights" to the burglar system on their coach.? I was thinking of tieing it in only when the security switch is operated, but still be able to use the landing/parking lights as required. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] | |||
					12-12-2006, 03:11
				 Post: #2 | |||
| Security system
					Hi Bill, I haven't done it but it is very easy to do; just wire a small relay to jumper the security light switch. Use the alarm 12V output to activate the relay coil. Since the security lights already have a large relay that is activated by the security switch, a small, low current relay to jump the switch is all that is necessary. When the alarm is not activated, all will work normally. Hardest part would be running the wires from the alarm output to the security switch. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > Need some advice from you long time birders: > Has anyone thought of/or tied in there "security lights" to the burglar system on their coach.? > I was thinking of tieing it in only when the security switch is operated, but still be able to use the landing/parking lights as required. > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > [Non-text portions of this message have been removed] > | |||
					12-12-2006, 03:59
				 Post: #3 | |||
| Security system
					Have you thought of what might happen if you alarm the system when boondocking or not connected to shore power and you are away? This could very quickly run down your batteries if you are powering via inverter. tom warner vernon center,ny 1985 PT 40 At 10:11 AM 12/12/2006, you wrote: >Hi Bill, > >I haven't done it but it is very easy to do; just wire a small relay >to jumper the security light switch. Use the alarm 12V output to >activate the relay coil. Since the security lights already have a >large relay that is activated by the security switch, a small, low >current relay to jump the switch is all that is necessary. When the >alarm is not activated, all will work normally. Hardest part would be >running the wires from the alarm output to the security switch. > >Rich D. '99LXi43' CT > > >--- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > > > > Need some advice from you long time birders: > > Has anyone thought of/or tied in there "security lights" to the >burglar system on their coach.? > > I was thinking of tieing it in only when the security switch is >operated, but still be able to use the landing/parking lights as >required. > > > > Bill 84 FC 35 SB "$quanderlodge" > > Terrace, B.C. Canada > > > > > > > > > > __________________________________________________ > > Do You Yahoo!? > > Tired of spam? Yahoo! Mail has the best spam protection around > > http://mail.yahoo.com > > > > [Non-text portions of this message have been removed] > > > > > > > >Yahoo! Groups Links > > > | |||
					12-12-2006, 07:27
				 Post: #4 | |||
| Security system
					No reason not to, provided the relay will time-out and turn them off so that it doesn't drain the battery when the coach is not attended. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > Need some advice from you long time birders: > Has anyone thought of/or tied in there "security lights" to the burglar system on their coach.? > I was thinking of tieing it in only when the security switch is operated, but still be able to use the landing/parking lights as required. > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > [Non-text portions of this message have been removed] > | |||
					12-12-2006, 17:46
				 Post: #5 | |||
| Security system
					Good point Jeff.  I was just thinking of when the security light switch is activated, but I guess it could go both ways. What an idea. Thanks Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Jeff Miller To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, December 12, 2006 11:27:14 AM Subject: [WanderlodgeForum] Re: Security system No reason not to, provided the relay will time-out and turn them off so that it doesn't drain the battery when the coach is not attended. - Jeff Miller in Holland, MI --- In WanderlodgeForum@ yahoogroups. com, Wilhelmus Schreurs > > Need some advice from you long time birders: > Has anyone thought of/or tied in there "security lights" to the burglar system on their coach.? > I was thinking of tieing it in only when the security switch is operated, but still be able to use the landing/parking lights as required. > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > > > ____________ _________ _________ _________ _________ __ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail. yahoo.com > > [Non-text portions of this message have been removed] > <!-- #ygrp-mlmsg {font-size:13px;font-family:arial,helvetica,clean,sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial,helvetica,clean,sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0; } #ygrp-tpmsgs{ font-family:Arial; clear:both; } #ygrp-vitnav{ padding-top:10px; font-family:Verdana; font-size:77%; margin:0; } #ygrp-vitnav a{ padding:0 1px; } #ygrp-actbar{ clear:both; margin:25px 0; white-space:nowrap; color:#666; text-align:right; } #ygrp-actbar .left{ float:left; white-space:nowrap; } .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana; font-size:77%; padding:15px 0; } #ygrp-ft{ font-family:verdana; font-size:77%; border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px; } #ygrp-vital{ background-color:#e0ecee; margin-bottom:20px; padding:2px 0 8px 8px; } #ygrp-vital #vithd{ font-size:77%; font-family:Verdana; font-weight:bold; color:#333; text-transform:uppercase; } #ygrp-vital ul{ padding:0; margin:2px 0; } #ygrp-vital ul li{ list-style-type:none; clear:both; border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold; color:#ff7900; float:right; width:2em; text-align:right; padding-right:.5em; } #ygrp-vital ul li .cat{ font-weight:bold; } #ygrp-vital a { text-decoration:none; } #ygrp-vital a:hover{ text-decoration:underline; } #ygrp-sponsor #hd{ color:#999; font-size:77%; } #ygrp-sponsor #ov{ padding:6px 13px; background-color:#e0ecee; margin-bottom:20px; } #ygrp-sponsor #ov ul{ padding:0 0 0 8px; margin:0; } #ygrp-sponsor #ov li{ list-style-type:square; padding:6px 0; font-size:77%; } #ygrp-sponsor #ov li a{ text-decoration:none; font-size:130%; } #ygrp-sponsor #nc { background-color:#eee; margin-bottom:20px; padding:0 8px; } #ygrp-sponsor .ad{ padding:8px 0; } #ygrp-sponsor .ad #hd1{ font-family:Arial; font-weight:bold; color:#628c2a; font-size:100%; line-height:122%; } #ygrp-sponsor .ad a{ text-decoration:none; } #ygrp-sponsor .ad a:hover{ text-decoration:underline; } #ygrp-sponsor .ad p{ margin:0; } o {font-size:0;} .MsoNormal { margin:0 0 0 0; } #ygrp-text tt{ font-size:120%; } blockquote{margin:0 0 0 4px;} .replbq {margin:4;} --> __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] | |||
					12-12-2006, 17:59
				 Post: #6 | |||
| Security system
					Tom; Well it was just a question, and you bring up a good point. Jeff also responded and mentioned that a timed relay should be installed. Just wondering what others would think, and goodness, like always lots of good advice here. Thanks Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Tom Warner To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, December 12, 2006 7:59:00 AM Subject: Re: [WanderlodgeForum] Re: Security system Have you thought of what might happen if you alarm the system when boondocking or not connected to shore power and you are away? This could very quickly run down your batteries if you are powering via inverter. tom warner vernon center,ny 1985 PT 40 At 10:11 AM 12/12/2006, you wrote: >Hi Bill, > >I haven't done it but it is very easy to do; just wire a small relay >to jumper the security light switch. Use the alarm 12V output to >activate the relay coil. Since the security lights already have a >large relay that is activated by the security switch, a small, low >current relay to jump the switch is all that is necessary. When the >alarm is not activated, all will work normally. Hardest part would be >running the wires from the alarm output to the security switch. > >Rich D. '99LXi43' CT > > >--- In WanderlodgeForum@ yahoogroups. com, Wilhelmus Schreurs > > > > > Need some advice from you long time birders: > > Has anyone thought of/or tied in there "security lights" to the >burglar system on their coach.? > > I was thinking of tieing it in only when the security switch is >operated, but still be able to use the landing/parking lights as >required. > > > > Bill 84 FC 35 SB "$quanderlodge" > > Terrace, B.C. Canada > > > > > > > > > > ____________ _________ _________ _________ _________ __ > > Do You Yahoo!? > > Tired of spam? Yahoo! Mail has the best spam protection around > > http://mail. yahoo.com > > > > [Non-text portions of this message have been removed] > > > > > > > >Yahoo! Groups Links > > > <!-- #ygrp-mlmsg {font-size:13px;font-family:arial,helvetica,clean,sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial,helvetica,clean,sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0; } #ygrp-tpmsgs{ font-family:Arial; clear:both; } #ygrp-vitnav{ padding-top:10px; font-family:Verdana; font-size:77%; margin:0; } #ygrp-vitnav a{ padding:0 1px; } #ygrp-actbar{ clear:both; margin:25px 0; white-space:nowrap; color:#666; text-align:right; } #ygrp-actbar .left{ float:left; white-space:nowrap; } .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana; font-size:77%; padding:15px 0; } #ygrp-ft{ font-family:verdana; font-size:77%; border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px; } #ygrp-vital{ background-color:#e0ecee; margin-bottom:20px; padding:2px 0 8px 8px; } #ygrp-vital #vithd{ font-size:77%; font-family:Verdana; font-weight:bold; color:#333; text-transform:uppercase; } #ygrp-vital ul{ padding:0; margin:2px 0; } #ygrp-vital ul li{ list-style-type:none; clear:both; border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold; color:#ff7900; float:right; width:2em; text-align:right; padding-right:.5em; } #ygrp-vital ul li .cat{ font-weight:bold; } #ygrp-vital a { text-decoration:none; } #ygrp-vital a:hover{ text-decoration:underline; } #ygrp-sponsor #hd{ color:#999; font-size:77%; } #ygrp-sponsor #ov{ padding:6px 13px; background-color:#e0ecee; margin-bottom:20px; } #ygrp-sponsor #ov ul{ padding:0 0 0 8px; margin:0; } #ygrp-sponsor #ov li{ list-style-type:square; padding:6px 0; font-size:77%; } #ygrp-sponsor #ov li a{ text-decoration:none; font-size:130%; } #ygrp-sponsor #nc { background-color:#eee; margin-bottom:20px; padding:0 8px; } #ygrp-sponsor .ad{ padding:8px 0; } #ygrp-sponsor .ad #hd1{ font-family:Arial; font-weight:bold; color:#628c2a; font-size:100%; line-height:122%; } #ygrp-sponsor .ad a{ text-decoration:none; } #ygrp-sponsor .ad a:hover{ text-decoration:underline; } #ygrp-sponsor .ad p{ margin:0; } o {font-size:0;} .MsoNormal { margin:0 0 0 0; } #ygrp-text tt{ font-size:120%; } blockquote{margin:0 0 0 4px;} .replbq {margin:4;} --> __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
