Shocks
01-02-2007, 08:24
Shocks
Bob- didn't your coach come with Konis? If so they are adjustable. On my
coach, when i was at Steve Gureaskos', we adjusted 1 shock and replaced another-
made agreat difference
83PT40
Weatherford, tx
01-02-2007, 13:12
Shocks
How do I determine which Bilsteins will fit our '84 FC31 WLII?
The rear axle is air suspension and is no doubt the same setup as
other '84 FCs.
The front axle is leaf springs and probably the same as FCs just before
BB started using air suspension (81? 82?).
As always, thanks for the help!
Bob Griesel '84 FC31 WLII WA
01-02-2007, 15:48
Shocks
Thanks Earnie. Does anyone have Koni part numbers for an 84 FC? - Bob
my
replaced another-
> Ernie Ekberg
> 83PT40
> Weatherford, tx
01-02-2007, 23:46
Shocks
Hey Bob, Happy New Year to you and Sandy.
Below is the correspondence I had with Koni recently. (Read from bottom up)
As you know, my 79 does not have air suspension either front or back. I
replaced the fronts this week and have not had the opportunity yet to drive it
since so at this point I am unable to say if there is a difference. I do know
there was a substantial difference in the resistance by hand. The originals on
my coach were Gabriels per the original manual. The replacements were crossed
from those numbers. I replaced the rears with Monroes as Koni says they do
not have a replacement that size. I did drive the coach after replacing the
rears only and noticed a significant difference, so, I am eager to see the
difference with the fronts replaced.
I purchased my stainless steel top hats from Mansker Tires (Les Schwaub). I
don't know if they were a standard stock item for them, but they did have them
in stock that day.
Steve Anderson
79 FC 35
Poulsbo, Wa.
We have a front shock that is pretty close to the specifications of the
Gabriel shock (based on an aftermarket catalog). Please see the
following:
BB # 614966 = Monroe 74028
lMax = 22.625
lMin = 14.625
Koni 90 2256SP1
lMax = 22.52
lMin = 14.80
Our shock was designed for the front axle of a transit bus, so it should
be close to what you need. It is also adjustable, in case you need more
force to control the bouncing.
The rear shock is a little more difficult
BB #614974 = Monroe 74006
lMax = 21.625
lMin = 14.25
We don't have a Koni shock that is close to that.
You may have to call Bluebird about the rear, and see if they know if
there is a Koni equivalent to the Bluebird number. What they should
know (that I don't) is where the actual limits to the suspension are...
What is the lowest the shock can go, and what is the nominal height of
the shock?
If I get the dimensions wrong either way, you could rip the shocks
apart.
The fronts have a suggested list of $206, but you can get them through
is for $165 each. Just call 866.566.4175 and ask for customer service.
Hope this helps.
Regards,
Justin McCoy
859-488-0314
866-566-4175 x 314 (toll free)
-----Original Message-----
Sent: Tuesday, November 21, 2006 11:44 AM
To: jmccoy@...
Subject: Koni Web Site Contact - Heavy Duty
name : John S. (Steve) Anderson
address : 1079 NW Liberty Ln Poulsbo, Wa. 98370
phone : 360.779.4156
fax :
Comments : I would like to purchase a set of KONI adjustable shocks for
my 1979 Blue Bird motorhome. The original coach shocks were Gabriel
brand. The part numbers I have for the front shocks are Gabriel part no.
0680054 with a Blue Bird part no. 0614966. The stroke on these front
shocks is 8.76 in. The Gabriel part no for the rear shocks is 680010,
with a Blue Bird part no. of 0614974. The stroke for the rears is 7.51
in. I will also need the bushings for all these shocks if they do not
come with the shocks. Please let me know the Koni part numbers, the cost
of these parts and how I can purchase them. VR Steve Anderson
SUBMIT : Submit Query
CFID : 13489092
CFTOKEN : 4ca660c17daeb771-0B48770F-0869-F5AD-C1D91148BD7B0D5F
This e-mail and any files transmitted with it are proprietary and intended
solely
for the use of the individual or entity to whom they are addressed. If you
have
received this e-mail in error please notify the sender. Please note that any
views
or opinions presented in this e-mail are solely those of the author and do
not
necessarily represent those of ITT, Inc.
In a message dated 1/2/2007 5:22:39 PM Pacific Standard Time,
sundance101@... writes:
other '84 FCs.
01-03-2007, 08:57
Shocks
Hi
we just put new Koni adj shocks on our bird a week or so ago,
I called Koni but was able to get them thru bluebird for about $40
less per shock (around $130)
just for your info.
Rose Mary
82 FC
Rocky Point Mex
beautiful and warm!
bottom up)
back. I
yet to drive it
originals on
were crossed
says they do
replacing the
to see the
Schwaub). I
did have them
> in stock that day.
> Steve Anderson
> 79 FC 35
> Poulsbo, Wa.
of the
> following:
> lMax = 22.625
> lMin = 14.625
> Koni 90 2256SP1
> lMax = 22.52
> lMin = 14.80
should
need more
> lMax = 21.625
> lMin = 14.25
know if
should
are...
height of
> the shock?
> apart.
through
service.
> Hope this helps.
> Regards,
> Justin McCoy
> 859-488-0314
> From: ebirder2000@... [mailto:ebirder2000@...]
> To: jmccoy@...
> fax :
shocks for
Gabriel
part no.
front
680010,
7.51
not
the cost
> CFID : 13489092
intended
> solely
addressed. If you
> have
note that any
> views
author and do
> not
> other '84 FCs.
before
