Stay running problem
01-01-2007, 14:57
I am one of those "lurkers" that is referred to in this forum. I like
to look and learn but now have a question I hope someone can answer. We have a BB with an 8v92 Detroit. She will start fine, runs for about 30 seconds,on high idle, the check engine light comes on and she dies. She dies within 10 seconds on normal idle. She will restart but continues to die. I have read on the forum something about the codes flashing. I am assuming that is the sequence of flashes under the "do not shift". If I am correct so far, be advised there is 4 flashes. What does this mean? Does anyone have an idea where to start? Any help/ideas would be appreciated. Paul & Jo Carver 1993 WB La Verne, CA |
01-01-2007, 15:36
Paul and Jo. the 10 to 30 second factored with high and low
difference kinda hints to low/no oil pressure ????? or high heat reading????? It may just be a sender problem or the real deal. The flashes and codes are gathered by pushing the check buttons, on a full moon , facing north , while genuflecting. then the codes reveal a bunch of crap that could be a result of the rapid shut down. I think the blinks you see are just an attention getter for the driver. I say it is a sender failure because it happened while the bus was parked. I hope someone here can't offer a better clue for you. I would hire a mobile mechanic. The hook ups for the computer- reader on my 94pt are under the shift selector. I have to remove the screws and lift the cover off. I hope the two of you make it to quartzsite Gregory O'Connor 94pt 951-830-5997 --- In WanderlodgeForum@yahoogroups.com, "gpaulcarver" wrote: > > I am one of those "lurkers" that is referred to in this forum. I like > to look and learn but now have a question I hope someone can answer. > > We have a BB with an 8v92 Detroit. She will start fine, runs for about > 30 seconds,on high idle, the check engine light comes on and she dies. > She dies within 10 seconds on normal idle. She will restart but > continues to die. > > I have read on the forum something about the codes flashing. I am > assuming that is the sequence of flashes under the "do not shift". If > I am correct so far, be advised there is 4 flashes. What does this > mean? Does anyone have an idea where to start? Any help/ideas would > be appreciated. > > Paul & Jo Carver > 1993 WB > La Verne, CA > |
01-01-2007, 16:19
Greg, I just love your sence of humor, always makes reading your
responses fun. Oil level and guage read good, heat the same. There is no water in the fuel and air filter good. Checked all the guages on the dash before the shut down and all look fine. We suspect a sender problem but don't know where to start. Was hoping not to have to get a mobile mechanic, I can hear the cha- ching already. Won't be able to make it to Quartzsite as Paul may be retired but, I still have to work. Will miss you and Tim and the great bunch that was at the first rally in Orange County. Paul & Jo Carver 1993 WB La Verne, CA PS I am to old to genuflect! --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Paul and Jo. the 10 to 30 second factored with high and low > difference kinda hints to low/no oil pressure ????? or high heat > reading????? It may just be a sender problem or the real deal. > > The flashes and codes are gathered by pushing the check buttons, on > a full moon , facing north , while genuflecting. then the codes > reveal a bunch of crap that could be a result of the rapid shut down. > I think the blinks you see are just an attention getter for the > driver. I say it is a sender failure because it happened while the > bus was parked. I hope someone here can't offer a better clue for > you. > > I would hire a mobile mechanic. The hook ups for the computer- > reader on my 94pt are under the shift selector. I have to remove > the screws and lift the cover off. > > I hope the two of you make it to quartzsite > Gregory O'Connor > 94pt > 951-830-5997 > > --- In WanderlodgeForum@yahoogroups.com, "gpaulcarver" > wrote: > > > > I am one of those "lurkers" that is referred to in this forum. I > like > > to look and learn but now have a question I hope someone can answer. > > > > We have a BB with an 8v92 Detroit. She will start fine, runs for > about > > 30 seconds,on high idle, the check engine light comes on and she > dies. > > She dies within 10 seconds on normal idle. She will restart but > > continues to die. > > > > I have read on the forum something about the codes flashing. I am > > assuming that is the sequence of flashes under the "do not shift". > If > > I am correct so far, be advised there is 4 flashes. What does this > > mean? Does anyone have an idea where to start? Any help/ideas > would > > be appreciated. > > > > Paul & Jo Carver > > 1993 WB > > La Verne, CA > > > |
01-02-2007, 00:51
The oil sending switches (pressure switch) starboard side rear rail just aft of
the tag axle. I got a brass plug removed the switch got a switch from a dealer he had to order it. I have wondered that if in an emergency failure of the pressure switch, knowing that you had oil whether you could short the switch and run the coach. I will try to find the model number later today and post it. Jim Riordan 88WLWB XXV Stuart, Fl. Paul Carver Greg, I just love your sence of humor, always makes reading your responses fun. Oil level and guage read good, heat the same. There is no water in the fuel and air filter good. Checked all the guages on the dash before the shut down and all look fine. We suspect a sender problem but don't know where to start. Was hoping not to have to get a mobile mechanic, I can hear the cha- ching already. Won't be able to make it to Quartzsite as Paul may be retired but, I still have to work. Will miss you and Tim and the great bunch that was at the first rally in Orange County. Paul & Jo Carver 1993 WB La Verne, CA PS I am to old to genuflect! --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Paul and Jo. the 10 to 30 second factored with high and low > difference kinda hints to low/no oil pressure ????? or high heat > reading????? It may just be a sender problem or the real deal. > > The flashes and codes are gathered by pushing the check buttons, on > a full moon , facing north , while genuflecting. then the codes > reveal a bunch of crap that could be a result of the rapid shut down. > I think the blinks you see are just an attention getter for the > driver. I say it is a sender failure because it happened while the > bus was parked. I hope someone here can't offer a better clue for > you. > > I would hire a mobile mechanic. The hook ups for the computer- > reader on my 94pt are under the shift selector. I have to remove > the screws and lift the cover off. > > I hope the two of you make it to quartzsite > Gregory O'Connor > 94pt > 951-830-5997 > > --- In WanderlodgeForum@yahoogroups.com, "gpaulcarver" > wrote: > > > > I am one of those "lurkers" that is referred to in this forum. I > like > > to look and learn but now have a question I hope someone can answer. > > > > We have a BB with an 8v92 Detroit. She will start fine, runs for > about > > 30 seconds,on high idle, the check engine light comes on and she > dies. > > She dies within 10 seconds on normal idle. She will restart but > > continues to die. > > > > I have read on the forum something about the codes flashing. I am > > assuming that is the sequence of flashes under the "do not shift". > If > > I am correct so far, be advised there is 4 flashes. What does this > > mean? Does anyone have an idea where to start? Any help/ideas > would > > be appreciated. > > > > Paul & Jo Carver > > 1993 WB > > La Verne, CA > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
01-02-2007, 03:23
I would aleays look for the simple stuff first. Check the battery
connections and make sure they are clean. Check the batteries and make sure there is not a bad one. The computors that run these engines are very sensitve to low voltage or bad grounds. Mike McMahan 1989 PT40 --- In WanderlodgeForum@yahoogroups.com, "gpaulcarver" wrote: > > I am one of those "lurkers" that is referred to in this forum. I like > to look and learn but now have a question I hope someone can answer. > > We have a BB with an 8v92 Detroit. She will start fine, runs for about > 30 seconds,on high idle, the check engine light comes on and she dies. > She dies within 10 seconds on normal idle. She will restart but > continues to die. > > I have read on the forum something about the codes flashing. I am > assuming that is the sequence of flashes under the "do not shift". If > I am correct so far, be advised there is 4 flashes. What does this > mean? Does anyone have an idea where to start? Any help/ideas would > be appreciated. > > Paul & Jo Carver > 1993 WB > La Verne, CA > |
01-02-2007, 14:05
Thanks for the idea, Jim. Problem being air bags are depleated,
can't get under coach to see, and won't run long enough to air up. Run the generator you say, I should mention that the starter on the generator went out about a week ago. It seems at this point we have no other option but to call for a mobile mechanic. But, do appreciate your response and will be sure and mention it to the mechanic. Paul & Jo Carver 1993 WB La Verne, CA -- In WanderlodgeForum@yahoogroups.com, jim riordan > > The oil sending switches (pressure switch) starboard side rear rail just aft of the tag axle. I got a brass plug removed the switch got a switch from a dealer he had to order it. I have wondered that if in an emergency failure of the pressure switch, knowing that you had oil whether you could short the switch and run the coach. I will try to find the model number later today and post it. > > Jim Riordan > 88WLWB XXV > Stuart, Fl. > > Paul Carver > Greg, I just love your sence of humor, always makes reading your > responses fun. > > Oil level and guage read good, heat the same. There is no water in > the fuel and air filter good. Checked all the guages on the dash > before the shut down and all look fine. We suspect a sender problem > but don't know where to start. > > Was hoping not to have to get a mobile mechanic, I can hear the cha- > ching already. > > Won't be able to make it to Quartzsite as Paul may be retired but, I > still have to work. Will miss you and Tim and the great bunch that > was at the first rally in Orange County. > > Paul & Jo Carver > 1993 WB > La Verne, CA > > PS I am to old to genuflect! > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > Paul and Jo. the 10 to 30 second factored with high and low > > difference kinda hints to low/no oil pressure ????? or high heat > > reading????? It may just be a sender problem or the real deal. > > > > The flashes and codes are gathered by pushing the check buttons, > on > > a full moon , facing north , while genuflecting. then the codes > > reveal a bunch of crap that could be a result of the rapid shut > down. > > I think the blinks you see are just an attention getter for the > > driver. I say it is a sender failure because it happened while > the > > bus was parked. I hope someone here can't offer a better clue for > > you. > > > > I would hire a mobile mechanic. The hook ups for the computer- > > reader on my 94pt are under the shift selector. I have to remove > > the screws and lift the cover off. > > > > I hope the two of you make it to quartzsite > > Gregory O'Connor > > 94pt > > 951-830-5997 > > > > --- In WanderlodgeForum@yahoogroups.com, "gpaulcarver" > > wrote: > > > > > > I am one of those "lurkers" that is referred to in this forum. I > > like > > > to look and learn but now have a question I hope someone can > answer. > > > > > > We have a BB with an 8v92 Detroit. She will start fine, runs for > > about > > > 30 seconds,on high idle, the check engine light comes on and she > > dies. > > > She dies within 10 seconds on normal idle. She will restart but > > > continues to die. > > > > > > I have read on the forum something about the codes flashing. I > am > > > assuming that is the sequence of flashes under the "do not > shift". > > If > > > I am correct so far, be advised there is 4 flashes. What does > this > > > mean? Does anyone have an idea where to start? Any help/ideas > > would > > > be appreciated. > > > > > > Paul & Jo Carver > > > 1993 WB > > > La Verne, CA > > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > [Non-text portions of this message have been removed] > |
01-02-2007, 14:13
I like your thinking, I too like to look for the simple stuff first.
I move switches, check wires and fuses while Paul is looking for his volt meter. Believe it or not, more times then not, I get it fixed/figured out before he gets all his tools ready. Anyway, we checked the batteries and connections and all seem good. All three starting batteries were replaced about a year and a half ago. Paul & Jo Carver 1993 WB La Verne, CA -- In WanderlodgeForum@yahoogroups.com, "Mike McMahan" <mmcmahan@...> wrote: > > I would aleays look for the simple stuff first. Check the battery > connections and make sure they are clean. Check the batteries and > make sure there is not a bad one. The computors that run these > engines are very sensitve to low voltage or bad grounds. Mike > McMahan 1989 PT40 > > > --- In WanderlodgeForum@yahoogroups.com, "gpaulcarver" > wrote: > > > > I am one of those "lurkers" that is referred to in this forum. I > like > > to look and learn but now have a question I hope someone can > answer. > > > > We have a BB with an 8v92 Detroit. She will start fine, runs for > about > > 30 seconds,on high idle, the check engine light comes on and she > dies. > > She dies within 10 seconds on normal idle. She will restart but > > continues to die. > > > > I have read on the forum something about the codes flashing. I am > > assuming that is the sequence of flashes under the "do not > shift". If > > I am correct so far, be advised there is 4 flashes. What does > this > > mean? Does anyone have an idea where to start? Any help/ideas > would > > be appreciated. > > > > Paul & Jo Carver > > 1993 WB > > La Verne, CA > > > |
01-03-2007, 07:28
Paul,
Be glad you can't air up your air bags. Getting under a BB with only the air bags up is like Russian Roulette. Don't take the chance call a mobile repairman. Regards, Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: Paul Carver To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, January 02, 2007 9:05 PM Subject: [WanderlodgeForum] Re: Stay running problem Thanks for the idea, Jim. Problem being air bags are depleated, can't get under coach to see, and won't run long enough to air up. Run the generator you say, I should mention that the starter on the generator went out about a week ago. It seems at this point we have no other option but to call for a mobile mechanic. But, do appreciate your response and will be sure and mention it to the mechanic. Paul & Jo Carver 1993 WB La Verne, CA -- In WanderlodgeForum@yahoogroups.com, jim riordan > > The oil sending switches (pressure switch) starboard side rear rail just aft of the tag axle. I got a brass plug removed the switch got a switch from a dealer he had to order it. I have wondered that if in an emergency failure of the pressure switch, knowing that you had oil whether you could short the switch and run the coach. I will try to find the model number later today and post it. > > Jim Riordan > 88WLWB XXV > Stuart, Fl. > > Paul Carver > Greg, I just love your sence of humor, always makes reading your > responses fun. > > Oil level and guage read good, heat the same. There is no water in > the fuel and air filter good. Checked all the guages on the dash > before the shut down and all look fine. We suspect a sender problem > but don't know where to start. > > Was hoping not to have to get a mobile mechanic, I can hear the cha- > ching already. > > Won't be able to make it to Quartzsite as Paul may be retired but, I > still have to work. Will miss you and Tim and the great bunch that > was at the first rally in Orange County. > > Paul & Jo Carver > 1993 WB > La Verne, CA > > PS I am to old to genuflect! > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > Paul and Jo. the 10 to 30 second factored with high and low > > difference kinda hints to low/no oil pressure ????? or high heat > > reading????? It may just be a sender problem or the real deal. > > > > The flashes and codes are gathered by pushing the check buttons, > on > > a full moon , facing north , while genuflecting. then the codes > > reveal a bunch of crap that could be a result of the rapid shut > down. > > I think the blinks you see are just an attention getter for the > > driver. I say it is a sender failure because it happened while > the > > bus was parked. I hope someone here can't offer a better clue for > > you. > > > > I would hire a mobile mechanic. The hook ups for the computer- > > reader on my 94pt are under the shift selector. I have to remove > > the screws and lift the cover off. > > > > I hope the two of you make it to quartzsite > > Gregory O'Connor > > 94pt > > 951-830-5997 > > > > --- In WanderlodgeForum@yahoogroups.com, "gpaulcarver" > > wrote: > > > > > > I am one of those "lurkers" that is referred to in this forum. I > > like > > > to look and learn but now have a question I hope someone can > answer. > > > > > > We have a BB with an 8v92 Detroit. She will start fine, runs for > > about > > > 30 seconds,on high idle, the check engine light comes on and she > > dies. > > > She dies within 10 seconds on normal idle. She will restart but > > > continues to die. > > > > > > I have read on the forum something about the codes flashing. I > am > > > assuming that is the sequence of flashes under the "do not > shift". > > If > > > I am correct so far, be advised there is 4 flashes. What does > this > > > mean? Does anyone have an idea where to start? Any help/ideas > > would > > > be appreciated. > > > > > > Paul & Jo Carver > > > 1993 WB > > > La Verne, CA > > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > [Non-text portions of this message have been removed] > ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.409 / Virus Database: 268.15.29/607 - Release Date: 12/28/2006 [Non-text portions of this message have been removed] |
01-03-2007, 09:29
Don't you have HWH jacks? Do you have a compressor? if so at the rear
of the coach starboard of the engine on the frame there should be a schrader valve you could air up the suspension, drop the hwh jacks, and BLOCK THE CHASSIS. Then you should be able to get under and check out the pressure switch mine was a kyser 1042-08200-03 got at Freightliner in west palm beach fl Jim Riordan 88 WLWB XXV Stuart, Fl --- In WanderlodgeForum@yahoogroups.com, "Paul Carver" wrote: > > Thanks for the idea, Jim. Problem being air bags are depleated, > can't > get under coach to see, and won't run long enough to air up. Run the > generator you say, I should mention that the starter on the generator > went out about a week ago. > > It seems at this point we have no other option but to call for a > mobile mechanic. But, do appreciate your response and will be sure > and mention it to the mechanic. > > Paul & Jo Carver > 1993 WB > La Verne, CA > > > > -- In WanderlodgeForum@yahoogroups.com, jim riordan > > > > The oil sending switches (pressure switch) starboard side rear rail > just aft of the tag axle. I got a brass plug removed the switch got a > switch from a dealer he had to order it. I have wondered that if in > an emergency failure of the pressure switch, knowing that you had oil > whether you could short the switch and run the coach. I will try to > find the model number later today and post it. > > > > Jim Riordan > > 88WLWB XXV > > Stuart, Fl. > > > > Paul Carver > > Greg, I just love your sence of humor, always makes > reading your > > responses fun. > > > > Oil level and guage read good, heat the same. There is no water in > > the fuel and air filter good. Checked all the guages on the dash > > before the shut down and all look fine. We suspect a sender problem > > but don't know where to start. > > > > Was hoping not to have to get a mobile mechanic, I can hear the cha- > > ching already. > > > > Won't be able to make it to Quartzsite as Paul may be retired but, > I > > still have to work. Will miss you and Tim and the great bunch that > > was at the first rally in Orange County. > > > > Paul & Jo Carver > > 1993 WB > > La Verne, CA > > > > PS I am to old to genuflect! > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > > > > Paul and Jo. the 10 to 30 second factored with high and low > > > difference kinda hints to low/no oil pressure ????? or high heat > > > reading????? It may just be a sender problem or the real deal. > > > > > > The flashes and codes are gathered by pushing the check buttons, > > on > > > a full moon , facing north , while genuflecting. then the codes > > > reveal a bunch of crap that could be a result of the rapid shut > > down. > > > I think the blinks you see are just an attention getter for the > > > driver. I say it is a sender failure because it happened while > > the > > > bus was parked. I hope someone here can't offer a better clue for > > > you. > > > > > > I would hire a mobile mechanic. The hook ups for the computer- > > > reader on my 94pt are under the shift selector. I have to remove > > > the screws and lift the cover off. > > > > > > I hope the two of you make it to quartzsite > > > Gregory O'Connor > > > 94pt > > > 951-830-5997 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "gpaulcarver" > > > wrote: > > > > > > > > I am one of those "lurkers" that is referred to in this forum. > I > > > like > > > > to look and learn but now have a question I hope someone can > > answer. > > > > > > > > We have a BB with an 8v92 Detroit. She will start fine, runs > for > > > about > > > > 30 seconds,on high idle, the check engine light comes on and > she > > > dies. > > > > She dies within 10 seconds on normal idle. She will restart but > > > > continues to die. > > > > > > > > I have read on the forum something about the codes flashing. I > > am > > > > assuming that is the sequence of flashes under the "do not > > shift". > > > If > > > > I am correct so far, be advised there is 4 flashes. What does > > this > > > > mean? Does anyone have an idea where to start? Any help/ideas > > > would > > > > be appreciated. > > > > > > > > Paul & Jo Carver > > > > 1993 WB > > > > La Verne, CA > > > > > > > > > > > > > > > > > > > __________________________________________________ > > Do You Yahoo!? > > Tired of spam? Yahoo! Mail has the best spam protection around > > http://mail.yahoo.com > > > > [Non-text portions of this message have been removed] > > > |
01-03-2007, 16:14
Your issues with the Genset starter could???? be a clue to electrical
issues with the Detroit DDEC. The Genset starters get burnt up by trying to start it with low batteries and or cranking too long to bring fuel up to the gen from the tank. My genset fuel drifts back to the tank if it sits un used for more than 3 days. The electric fuel pump runs while you are glowing plugs with the momentary switch. You can also run just the fuel pump by jumping the positive lead. If the batteries are low, I move the tray out then hook a battery jump pack positive clamp on the big wire lug to the starter and the negative jump pack clamp is hooked up to the Genset frame. I glow the plugs regardless of the outside temp (count to 20) and it is an effortless start. I keep the Pepboys jump pack plugged in to a inverter 110 outlet in the bay (it has a builtin automatic charger) The following is what I understand about Aux. Battery switch and charging???????????? The genset will not charge the Detroit start batteries unless you turn the dash AUX. Battery switch to the position that turns on the indicator light. You will note that while the Detroit is running this light comes on automatic and the big alternators on the Detroit are charging both battery banks. When the bus is at rest (no Genset or Detroit running) and you are using the inverter it is best to keep the Aux battery switch centered (off). If you inverter camp with Aux Battery light on , both sets of batteries are being depleted. When my bus is parked for storage periods I keep it plugged in and the Aux light off/ centered. If the starter bank of batteries read low before a trip I hold the Aux momentary button while I start the Detroit. Jo and Paul, send me your phone number off line Gregoryoc @ aol. com or call me at 951-830-5997. |
