Oil pressure gauge
01-02-2007, 07:32
Oil pressure gauge
Mike Mine has always ran at 80# when just starting up until it gets
warmed up then it cruses at 70# & drops back to 35# at idle at a stop. Mine has
done that since I have had it which is aver 3 years.& 25000 miles. Do you
think there is something wrong with the gauge or sender when it starts & runs
at 80# till operating temp?
Don
89 SP 36'
Butler, PA
I wonder about both gages. 80 is about 40 #s high for idle pressure. Sweet
spot is 35 hot idle and 65/75 at cruise with Rottella 15/40. The dash gage has
an electric sender as far as I know and that sender might be faulty.
Mike Hohnstein
Germantown, WI
83FC35
To: _WanderlodgeForum@WanderlodgeFWan_
(mailto:WanderlodgeForum@yahoogroups.com)
Sent: Tuesday, January 02, 2007 2:54 PM
Subject: [WanderlodgeForum] Oil pressure gauge
My engine oil pressure gauge is not working properly. I was road
testing the other day and the gauge read 25 Psi. I installed a
caterpillar mechnical gauge in the r.h. cylinder headtoday and at idle
cold it shows 80 PSI (it was about 51 degrees when testing)while the
dash gauge still shows 25 psi
Anyone replaced the dash gauge? it looks to be a job. ANY suggestions
or knowledge would be appreciated.
RE Brake
01-02-2007, 08:54
Oil pressure gauge
RE Brake 1983 35' sb
01-02-2007, 10:56
Oil pressure gauge
Mike Hohnstein
Germantown, WI
83FC35
01-02-2007, 15:34
Oil pressure gauge
Indicated 80 # @ low idle is high, even cold. I would be much more concerned
with pressures at operating temp.
MH
Sent: Tuesday, January 02, 2007 6:32 PM
Subject: Re: [WanderlodgeForum] Oil pressure gauge
has
Don
89 SP 36'
Butler, PA
Mike Hohnstein
Germantown, WI
83FC35
RE Brake
01-03-2007, 04:38
Oil pressure gauge
Sounds like the sensor,
Try here for troubleshooting tips and tech support phone number.
http://www.teleflexmarine.com/cgi-bin/frameset2.cgi?
site=gauges&type=us&link2=1047
Bill 88 FC
--- In WanderlodgeForum@yahoogroups.com, "putneyflash"
idle
01-03-2007, 11:26
Oil pressure gauge
I don't think it has a sensor, I think its a mechnical gauge. will keep ypu
posted
thanks
re brake 1983 fc-35 sb
> From: "pattypape"
> Date: 2007/01/03 Wed AM 11:38:38 EST
> Subject: [WanderlodgeForum] Re: Oil pressure gauge
> Bill 88 FC
> idle
01-03-2007, 11:28
Oil pressure gauge
I agree with hot oil operating pressure, i was simply making sure i had oil
pressure
thanks
re brake
> From: "Mike Hohnstein" <MHOHNSTEIN@...>
> Date: 2007/01/02 Tue PM 10:34:12 EST
> To:
> MH
> From: dspithaler@...
has
runs
> Don
> 89 SP 36'
> Butler, PA
has
> Mike Hohnstein
> Germantown, WI
> 83FC35
> From: putneyflash
> RE Brake
02-24-2008, 08:30
Oil pressure gauge
Thanks, Ron, I now recollect that gauge. I'll have to do some cleaning to read it~
83PT40
Buffalo, Wy
Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
02-24-2008, 08:32
Oil pressure gauge
I'm wondering if that sending unit is located beside the direct reading gauge that Ron just mentioned?
83PT40
Buffalo, Wy, on my way to Livingston, Mt in the am---if it don't SNOW
02-24-2008, 09:12
Oil pressure gauge
In a message dated 2/24/2008 8:04:29 P.M. Central Standard Time, billpatty@... writes:
miles and a few more climbs.
and one big decent into Billings
83PT40
Buffalo, Wy
