hydrogen in tires
01-09-2007, 07:02
hydrogen in tires
I think the main advantage of nitrogen vs. compressed air is that the
nitrogen is dry, and has no moisture in it, which is bad for tires. Costco, who is now becoming one of the nation's largest passenger car and light truck tire retailers, now use nitrogen when installing their new tires. that's what they told me anyway...FWIW.... Kevin Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] |
01-09-2007, 11:45
hydrogen in tires
Nitrogen
I keep reading about putting nitrogen in tires. 2 web sites: www. ezinearticles.com/?Selling-Nitrogen-In-Tires---Is-It-All-A-Lot-Of-Hot-Air?&id=38\ 142 and http://www.getnitrogen.org They say 78% of our air is nitrogen so are we just trying to eliminate the 21% of the oxygen? Is it worth the trouble? I will say trying to maintain the correct tire pressure is a PITA. The FMCA mag. had an article several issues back about carrying a pressurized tank of Nitrogen to top off when needed. I'd appreciate thoughts and/or comments. Jack VanDenBerg Glenn, Mi. Presently in SPI, Tx `05 Lxi450 |
01-09-2007, 12:57
hydrogen in tires
There are at least two advantages to nitrogen.
The first is that it should have little or no moisture because it is produced at a specialized facility where there should be certain levels of quality control. Compressed air from in-house compressors contains water, the amount depends on the current humidity. Second, nitrogen is an inert gas, that is to say it does not react chemicaly with anything. Oxygen, as you know, reacts with most everything. So filling with nitrogen will prevent oxidation of the inner tire as well as the rim. Is it worth the extra cost, if any? I don't know. But if you decide to go that way you need to continue to use it wen you adjust tire pressure or you will end up contaminating the atmosphere inside the tire. So carry a tank of nitrogen or seek out local suppliers. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > I think the main advantage of nitrogen vs. compressed air is that the > nitrogen is dry, and has no moisture in it, which is bad for tires. Costco, who is > now becoming one of the nation's largest passenger car and light truck tire > retailers, now use nitrogen when installing their new tires. that's what > they told me anyway...FWIW.... > > Kevin > Yorba Linda, CA > 1986 38' PT > > > [Non-text portions of this message have been removed] > |
01-09-2007, 13:41
hydrogen in tires
As an owner/operator of a tire store, I have been hit up by all my suppliers to
get on board with the nitrogen trend. While there are benefits of nitrogen that cannot be disputed, the nitrogen systems are being promoted to me as primarily a new profit center. The dryness of nitrogen as I see it is most beneficial in new vehicles that have TMPS on board, due to the sensitivity of the TPMS sensors to moisture (not to mention their rather costly replacement value). It it worth it to replace the "air" in your rigs tires with nitrogen? I suppose every little bit helps (dryness, pressure stability, tread life), but in the grand scheme of things, I just can't see it. Another thing to keep in mind, there is no substitute for putting a gauge on your tires every day (or at least "bumping" them. Don't let nitrogen's claims to greater pressure stability lull you into thinking your tires are fine. I see more tire failures due to lack of correct pressure (usually from natural aspiration or slow leaks) than any other culprit. Doug n' Pokey Gardner Yeaw There are at least two advantages to nitrogen. The first is that it should have little or no moisture because it is produced at a specialized facility where there should be certain levels of quality control. Compressed air from in-house compressors contains water, the amount depends on the current humidity. Second, nitrogen is an inert gas, that is to say it does not react chemicaly with anything. Oxygen, as you know, reacts with most everything. So filling with nitrogen will prevent oxidation of the inner tire as well as the rim. Is it worth the extra cost, if any? I don't know. But if you decide to go that way you need to continue to use it wen you adjust tire pressure or you will end up contaminating the atmosphere inside the tire. So carry a tank of nitrogen or seek out local suppliers. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > I think the main advantage of nitrogen vs. compressed air is that the > nitrogen is dry, and has no moisture in it, which is bad for tires. Costco, who is > now becoming one of the nation's largest passenger car and light truck tire > retailers, now use nitrogen when installing their new tires. that's what > they told me anyway...FWIW.... > > Kevin > Yorba Linda, CA > 1986 38' PT > > > [Non-text portions of this message have been removed] > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
01-09-2007, 14:07
hydrogen in tires
I use CO2, a 20 pound bottle, has worked for me for 30+ years. Email me
privately and I'll forward to you a picture of the tank, gauge, hose that I carry in our 'Bird. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. adieu2ysailing wrote: >Nitrogen >I keep reading about putting nitrogen in tires. 2 web sites: www. >ezinearticles.com/?Selling-Nitrogen-In-Tires---Is-It-All-A-Lot-Of-Hot-Air?&id=3\ 8142 > and http://www.getnitrogen.org > They say 78% of our air is nitrogen so are we just trying to >eliminate the 21% of the oxygen? Is it worth the trouble? I will say >trying to maintain the correct tire pressure is a PITA. The FMCA mag. >had an article several issues back about carrying a pressurized tank >of Nitrogen to top off when needed. >I'd appreciate thoughts and/or comments. > >Jack VanDenBerg >Glenn, Mi. Presently in SPI, Tx >`05 Lxi450 > > > > > >Yahoo! Groups Links > > > > > > |
01-09-2007, 14:23
hydrogen in tires
Nitrogen is not an inert gas. I haven't done the research to learn its relative
corrosiveness compared with oxygen, but it is corrosive. On 1/10/2007 at 12:57 AM Gardner Yeaw wrote: >There are at least two advantages to nitrogen. > Second, nitrogen is an inert gas, that is to say it does not >react chemicaly with anything. Oxygen, as you know, reacts with most >everything. So filling with nitrogen will prevent oxidation of the >inner tire as well as the rim. Don Bradner 90 PT40 without-a-name so far |
01-09-2007, 14:33
hydrogen in tires
Yes, I have heard some good things about using Nitrogen in the tires..
The tank can also power Air Tools. But I use CO2 in mine, a 20#tank for the Bird and a 5# one for the Jeep. Interestingly enough, it costs the same to refill either one... But the heading, "Hydrogen in Tires" sounds interging.. And, at the first good pothole, it may give a new meaning to "Leaps Tall Buildings with a Single Bound"! Jack Smith 1873FC31 SoCal --- In WanderlodgeForum@yahoogroups.com, "adieu2ysailing" > > Nitrogen > I keep reading about putting nitrogen in tires. 2 web sites: www. > ezinearticles.com/?Selling-Nitrogen-In-Tires---Is-It-All-A-Lot-Of-Hot-Air?&id=38\ 142 > and http://www.getnitrogen.org > They say 78% of our air is nitrogen so are we just trying to > eliminate the 21% of the oxygen? Is it worth the trouble? I will say > trying to maintain the correct tire pressure is a PITA. The FMCA mag. > had an article several issues back about carrying a pressurized tank > of Nitrogen to top off when needed. > I'd appreciate thoughts and/or comments. > > Jack VanDenBerg > Glenn, Mi. Presently in SPI, Tx > `05 Lxi450 > |
01-09-2007, 14:56
hydrogen in tires
Yes, the title is very interesting. Hydrogen, well the HINDENBURG was not too
sucessful on landing in NJ, so if you run on Hydrogen, stay out of the heat or warm climates Juergen in PA 1991 WLSP36 Jack & Donna Smith I have heard some good things about using Nitrogen in the tires.. The tank can also power Air Tools. But I use CO2 in mine, a 20#tank for the Bird and a 5# one for the Jeep. Interestingly enough, it costs the same to refill either one... But the heading, "Hydrogen in Tires" sounds interging.. And, at the first good pothole, it may give a new meaning to "Leaps Tall Buildings with a Single Bound"! Jack Smith 1873FC31 SoCal --- In WanderlodgeForum@yahoogroups.com, "adieu2ysailing" > > Nitrogen > I keep reading about putting nitrogen in tires. 2 web sites: www. > ezinearticles.com/?Selling-Nitrogen-In-Tires---Is-It-All-A-Lot-Of-Hot-Air?&id=38\ 142 > and http://www.getnitrogen.org > They say 78% of our air is nitrogen so are we just trying to > eliminate the 21% of the oxygen? Is it worth the trouble? I will say > trying to maintain the correct tire pressure is a PITA. The FMCA mag. > had an article several issues back about carrying a pressurized tank > of Nitrogen to top off when needed. > I'd appreciate thoughts and/or comments. > > Jack VanDenBerg > Glenn, Mi. Presently in SPI, Tx > `05 Lxi450 > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
01-09-2007, 15:16
hydrogen in tires
From Wikipedia:
Nitrogen is a nonmetal, with an electronegativity of 3.0. It has five electrons in its outer shell and is therefore trivalent in most compounds. The triple bond in molecular nitrogen (N2) is the strongest in nature. The resulting difficulty of converting (N2) into other compounds, and the ease (and associated high energy release) of converting nitrogen compounds into elemental N2, have dominated the role of nitrogen in both nature and human economic activities. [In other words, many nitrogen compounds are quite explosive, but elemental nitrogen is quite stable.] Nitrogen gas has a wide variety of applications, including serving as an inert replacement for air where oxidation is undesirable; To preserve the freshness of packaged or bulk foods (by delaying rancidity and other forms of oxidative damage) On top of liquid explosives for safety The production of electronic parts such as transistors, diodes, and integrated circuits Dried and pressurized, as a dielectric gas for high voltage equipment The manufacture of stainless steel Use in military aircraft fuel systems to reduce fire hazard, see inerting system Filling automotive and aircraft tires[1] due to its inertness and lack of moisture or oxidative qualities, as opposed to air, though this is not necessary for consumer automobiles.[2] Nitrogen molecules are less likely to escape from the inside of a tire compared to the traditional air mixture used. Air consists mostly of nitrogen and oxygen. Nitrogen molecules have a larger effective diameter than oxygen molecules and therefore diffuse through porous substances more slowly.[3] A further example of its versatility is its use as a preferred alternative to carbon dioxide to pressurize kegs of some beers, particularly thicker stouts and Scottish and English ales, due to the smaller bubbles it produces, which make the dispensed beer smoother and headier. A modern application of a pressure sensitive nitrogen capsule known commonly as a "widget" now allows nitrogen charged beers to be packaged in cans and bottles. ==== You can read the complete article at <http://en.wikipedia.org/wiki/ Nitrogen_gas> Elemental Nitrogen is "almost" inert as it does not give up it's N2 molecular form easily. Under pressures in an engine, nitrogen-oxides can form and other chemical processes can "fix" nitrogen in a biologically useful form. In tires, it would essentially be considered inert. Since hydrogen is quite a small molecule, it would escape from tires much more readily than nitrogen. Probably wouldn't make a great filler for tires. Hydrogen is also quite explosive under certain circumstances. When I purchased a compressor (to keep up my tire pressures), I also purchased a filter attachment. It seems to remove a fair amount of the water from the compressed air before it goes into the tire. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Jan 9, 2007, at 6:23 PM, Don Bradner wrote: > Nitrogen is not an inert gas. I haven't done the research to learn > its relative corrosiveness compared with oxygen, but it is corrosive. > > On 1/10/2007 at 12:57 AM Gardner Yeaw wrote: > >> There are at least two advantages to nitrogen. > >> Second, nitrogen is an inert gas, that is to say it does not >> react chemicaly with anything. Oxygen, as you know, reacts with most >> everything. So filling with nitrogen will prevent oxidation of the >> inner tire as well as the rim. [Non-text portions of this message have been removed] |
01-09-2007, 15:17
hydrogen in tires
Don,
You got me! but nitrogen is not as corrosive as oxygen. Here is a description: Nitrogen gas is slightly lighter than air and slightly soluble in water. It is commonly thought of and used as an inert gas; but it is not truly inert. It forms nitric oxide and nitrogen dioxide with oxygen, ammonia with hydrogen, and nitrogen sulfide with sulfur. Nitrogen compounds are formed naturally through biological activity. Compounds are also formed at high temperature or at moderate temperature with the aid of catalysts. At high temperatures, nitrogen will combine with active metals, such as lithium, magnesium and titanium to form nitrides. Nitrogen is necessary for various biological processes, and is used as a fertilizer, usually in the form of ammonia or ammonia-based compounds. Compounds formed with halogens and certain organic compounds can be explosive. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" wrote: > > Nitrogen is not an inert gas. I haven't done the research to learn its relative corrosiveness compared with oxygen, but it is corrosive. > > On 1/10/2007 at 12:57 AM Gardner Yeaw wrote: > > >There are at least two advantages to nitrogen. > > > Second, nitrogen is an inert gas, that is to say it does not > >react chemicaly with anything. Oxygen, as you know, reacts with most > >everything. So filling with nitrogen will prevent oxidation of the > >inner tire as well as the rim. > > Don Bradner > 90 PT40 without-a-name so far > |
