Putting in a Fantastic Fan in the kitchen
01-19-2007, 13:24
Hi group,
I have a roof vent in the kitchen that isn't motorized and I want to change it to a Fantastic fan. Problem is there is no 12v close by. I have a ceiling light by the sink, but since it is controlled by a switch at the sink, it doesn't seem to me right to tap into the wires at the light. I would have to leave the light on all the time. The only other think I can think of is to take a plumbers tape and go across to the back of the fridge and poke a hole in the ceiling panel and get power that way. Anybody do this mod and get power some other way? Bob Lawrence 84 PT 36 Tacoma, Wa. (with 8 months left before we fulltime outta here) |
01-19-2007, 14:23
This may be a long shot.
Is it possible to disconnect the hot wire at the light fixture, attach .032 safety wire to it and pull it back to the light switch. Attach a second wire to the .032 safety wire and pull both wires back to the light fixture.( Tape the end before pulling) Connect the fan wire to the constant hot side of the light switch. Reconnect the light fixture wire. Find a place in the fixture or the fan housing to fuse the fan line per manufactures spec's. Then you need the ground. I have used this procedure to pull wires with excellent results. Your post indicates the light is 12v, I hope. I have ignored the possible need for a relay. Leroy Eckert 1990 WB-40"Smoke N Mirrors Niceville, FL ----- Original Message ----- From: Bob Lawrence To: WanderlodgeForum@yahoogroups.com Sent: Friday, January 19, 2007 7:24 PM Subject: [WanderlodgeForum] Putting in a Fantastic Fan in the kitchen Hi group, I have a roof vent in the kitchen that isn't motorized and I want to change it to a Fantastic fan. Problem is there is no 12v close by. I have a ceiling light by the sink, but since it is controlled by a switch at the sink, it doesn't seem to me right to tap into the wires at the light. I would have to leave the light on all the time. The only other think I can think of is to take a plumbers tape and go across to the back of the fridge and poke a hole in the ceiling panel and get power that way. Anybody do this mod and get power some other way? Bob Lawrence 84 PT 36 Tacoma, Wa. (with 8 months left before we fulltime outta here) [Non-text portions of this message have been removed] |
01-19-2007, 16:52
Thanks, Leroy,
That might be possible...thanks again. Bob --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > This may be a long shot. > Is it possible to disconnect the hot wire at the light fixture, attach .032 safety wire to it and pull it back to the light switch. Attach a second wire to the .032 safety wire and pull both wires back to the light fixture.( Tape the end before pulling) Connect the fan wire to the constant hot side of the light switch. Reconnect the light fixture wire. Find a place in the fixture or the fan housing to fuse the fan line per manufactures spec's. Then you need the ground. > I have used this procedure to pull wires with excellent results. > Your post indicates the light is 12v, I hope. I have ignored the possible need for a relay. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors > Niceville, FL > > > ----- Original Message ----- > From: Bob Lawrence > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, January 19, 2007 7:24 PM > Subject: [WanderlodgeForum] Putting in a Fantastic Fan in the kitchen > > > Hi group, > I have a roof vent in the kitchen that isn't motorized and I want to > change it to a Fantastic fan. > Problem is there is no 12v close by. I have a ceiling light by the > sink, but since it is controlled by a switch at the sink, it doesn't > seem to me right to tap into the wires at the light. I would have to > leave the light on all the time. > The only other think I can think of is to take a plumbers tape and go > across to the back of the fridge and poke a hole in the ceiling panel > and get power that way. > Anybody do this mod and get power some other way? > > Bob Lawrence > 84 PT 36 > Tacoma, Wa. (with 8 months left before we fulltime outta here) > > > > > > [Non-text portions of this message have been removed] > |
01-19-2007, 18:13
Bob,
When you take the old vent out probe around a little. There is a lot of wiring that crosses over next to the ceiling ribs. Some of it is AC and some DC but in my coach the AC is in ROMAX. If you find DC check to which circuit it is, you may find you have power right there. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Bob Lawrence Sent: Friday, January 19, 2007 10:52 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Putting in a Fantastic Fan in the kitchen Thanks, Leroy, That might be possible...thanks again. Bob --- In WanderlodgeForum@ yahoogroups.com, "Leroy Eckert" > > This may be a long shot. > Is it possible to disconnect the hot wire at the light fixture, attach .032 safety wire to it and pull it back to the light switch. Attach a second wire to the .032 safety wire and pull both wires back to the light fixture.( Tape the end before pulling) Connect the fan wire to the constant hot side of the light switch. Reconnect the light fixture wire. Find a place in the fixture or the fan housing to fuse the fan line per manufactures spec's. Then you need the ground. > I have used this procedure to pull wires with excellent results. > Your post indicates the light is 12v, I hope. I have ignored the possible need for a relay. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors > Niceville, FL > > > ----- Original Message ----- > From: Bob Lawrence > To: WanderlodgeForum@ yahoogroups.com > Sent: Friday, January 19, 2007 7:24 PM > Subject: [WanderlodgeForum] Putting in a Fantastic Fan in the kitchen > > > Hi group, > I have a roof vent in the kitchen that isn't motorized and I want to > change it to a Fantastic fan. > Problem is there is no 12v close by. I have a ceiling light by the > sink, but since it is controlled by a switch at the sink, it doesn't > seem to me right to tap into the wires at the light. I would have to > leave the light on all the time. > The only other think I can think of is to take a plumbers tape and go > across to the back of the fridge and poke a hole in the ceiling panel > and get power that way. > Anybody do this mod and get power some other way? > > Bob Lawrence > 84 PT 36 > Tacoma, Wa. (with 8 months left before we fulltime outta here) > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
01-19-2007, 18:53
Right Check. I believe BB originally wired the area with 12V. Maybe
someone modified that area, but the 12V should still be there. Pull down the vent and check. I'd be surprised if you do not find 12V wiring in that area. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Chuck Wheeler wrote: > Bob, > > When you take the old vent out probe around a little. There is a lot of > wiring that crosses over next to the ceiling ribs. Some of it is AC > and some > DC but in my coach the AC is in ROMAX. If you find DC check to which > circuit it is, you may find you have power right there. > > - Chuck Wheeler - > 82 FC 31 SB > Fort Worth, TX > > > _____ > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com > > Sent: Friday, January 19, 2007 10:52 PM > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Re: Putting in a Fantastic Fan in the kitchen > > Thanks, Leroy, > That might be possible...thanks again. > Bob > --- In WanderlodgeForum@ > yahoogroups.com, "Leroy Eckert" > > > > > This may be a long shot. > > Is it possible to disconnect the hot wire at the light fixture, > attach .032 safety wire to it and pull it back to the light switch. > Attach a second wire to the .032 safety wire and pull both wires back > to the light fixture.( Tape the end before pulling) Connect the fan > wire to the constant hot side of the light switch. Reconnect the > light fixture wire. Find a place in the fixture or the fan housing > to fuse the fan line per manufactures spec's. Then you need the > ground. > > I have used this procedure to pull wires with excellent results. > > Your post indicates the light is 12v, I hope. I have ignored the > possible need for a relay. > > > > Leroy Eckert > > 1990 WB-40"Smoke N Mirrors > > Niceville, FL > > > > > > ----- Original Message ----- > > From: Bob Lawrence > > To: WanderlodgeForum@ > yahoogroups.com > > Sent: Friday, January 19, 2007 7:24 PM > > Subject: [WanderlodgeForum] Putting in a Fantastic Fan in the > kitchen > > > > > > Hi group, > > I have a roof vent in the kitchen that isn't motorized and I want > to > > change it to a Fantastic fan. > > Problem is there is no 12v close by. I have a ceiling light by > the > > sink, but since it is controlled by a switch at the sink, it > doesn't > > seem to me right to tap into the wires at the light. I would have > to > > leave the light on all the time. > > The only other think I can think of is to take a plumbers tape > and go > > across to the back of the fridge and poke a hole in the ceiling > panel > > and get power that way. > > Anybody do this mod and get power some other way? > > > > Bob Lawrence > > 84 PT 36 > > Tacoma, Wa. (with 8 months left before we fulltime outta here) > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > [Non-text portions of this message have been removed] > > |
01-19-2007, 23:32
Hey Bob , You could check to see if the switch switches the positive or the
ground. It could be that the 12 V is at the light full time and the light switch completes the circuit to ground. Steve In a message dated 1/19/2007 5:28:25 PM Pacific Standard Time, bobandarlene@... writes: Hi group, I have a roof vent in the kitchen that isn't motorized and I want to change it to a Fantastic fan. Problem is there is no 12v close by. I have a ceiling light by the sink, but since it is controlled by a switch at the sink, it doesn't seem to me right to tap into the wires at the light. I would have to leave the light on all the time. The only other think I can think of is to take a plumbers tape and go across to the back of the fridge and poke a hole in the ceiling panel and get power that way. Anybody do this mod and get power some other way? Bob Lawrence 84 PT 36 Tacoma, Wa. (with 8 months left before we fulltime outta here) [Non-text portions of this message have been removed] |
01-20-2007, 06:07
Thanks Curt,
I'll check this first. Bob > > Right Check. I believe BB originally wired the area with 12V. Maybe > someone modified that area, but the 12V should still be there. Pull down > the vent and check. I'd be surprised if you do not find 12V wiring in > that area. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Chuck Wheeler wrote: > > > Bob, > > > > When you take the old vent out probe around a little. There is a lot of > > wiring that crosses over next to the ceiling ribs. Some of it is AC > > and some > > DC but in my coach the AC is in ROMAX. If you find DC check to which > > circuit it is, you may find you have power right there. > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > > > |
01-20-2007, 06:09
Thanks Steve,
I'll put a meter on the wires and see. Bob --- In WanderlodgeForum@yahoogroups.com, ebirder2000@... wrote: > > > Hey Bob , You could check to see if the switch switches the positive or the > ground. It could be that the 12 V is at the light full time and the light > switch completes the circuit to ground. > > Steve |
01-20-2007, 08:35
Hi Bob - I recently pulled a bunch of cable and air hose all over the
ceiling of our rig (Solar battery system and new air horns). I can help you if you aren't done by the next time we get together. Once you get to the raceways behind the overheads there is always a way to get power, including establishing a new branch circuit if needed. Piece of cake! Bob Griesel '84 FC31 WLII WA > > Hi group, > I have a roof vent in the kitchen that isn't motorized and I want to > change it to a Fantastic fan. > Problem is there is no 12v close by. I have a ceiling light by the > sink, but since it is controlled by a switch at the sink, it doesn't > seem to me right to tap into the wires at the light. I would have to > leave the light on all the time. > The only other think I can think of is to take a plumbers tape and go > across to the back of the fridge and poke a hole in the ceiling panel > and get power that way. > Anybody do this mod and get power some other way? > > Bob Lawrence > 84 PT 36 > Tacoma, Wa. (with 8 months left before we fulltime outta here) > |
01-20-2007, 13:59
Curt,
Found 12 volts stuffed up behind the vent. Looks like this was done at the factory. Tied off and not used. Had 12v there. Will be a simple job to add the fan now....thanks again...saved me $ and time. Bob Lawrence 84 PT36 Tacky Tacoma Wa. (actually Lakewood, where that 9 yr old kid stole a car and got on 2 planes to fly to Texas because he didn't want to live next door to a molester..lot of them here) --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Thanks Curt, > I'll check this first. > Bob > > > > Right Check. I believe BB originally wired the area with 12V. Maybe > > someone modified that area, but the 12V should still be there. Pull > down > > the vent and check. I'd be surprised if you do not find 12V wiring > in > > that area. > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > > > > > Chuck Wheeler wrote: > > > > > Bob, > > > > > > When you take the old vent out probe around a little. There is a > lot of > > > wiring that crosses over next to the ceiling ribs. Some of it is > AC > > > and some > > > DC but in my coach the AC is in ROMAX. If you find DC check to > which > > > circuit it is, you may find you have power right there. > > > > > > - Chuck Wheeler - > > > 82 FC 31 SB > > > Fort Worth, TX > > > > > > |
