City water regulator
02-05-2007, 02:56
Has anyone replaced a city water regulator on a 89 36SP?
How to you gain access to the back of the regulator? |
02-05-2007, 04:23
If the regulator has 2 small holes on each side of the water hose
connector, you get a new one from BB, then simply unscrew the center part out of the existing housing with either needle nose pliers or if large enough a set of snap ring pliers, se the old parts aside. Remove the new regulator parts form the new one and install in the original housing. About a 10 minute job. If not this style then you in for a cramped job getting to the back of that one via a small space in the same area as the water heater or just toward the front from there. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 02:56 PM 2/5/2007 +0000, you wrote: >Has anyone replaced a city water regulator on a 89 36SP? >How to you gain access to the back of the regulator? > > |
