power problem
02-10-2007, 02:29
power problem
Joe and Kay Losh have the coach that was right after mine on the assembly line.
As others have said- the differences are amazing.
83PT40
Livingston,Montana
Sent: Friday, February 09, 2007 10:07 PM
Subject: Re: [WanderlodgeForum] power problem
Not only the differences in these coach between years. At the Quartzsite
rally several of us found it interesting the differences between coaches
of the same model and year. We came to the conclusion that Bluebird did
not build any two coaches the same.
Curt Sprenger
Anaheim Hills, Calif.
Leroy Eckert wrote:
> And, it is amazing the differences in these coaches between years.
> That is what makes it tough sometimes.
> Leroy Eckert
> 1990 WB-40"Smoke N Mirrors"
> Niceville,FL
> From: Curt Sprenger
> Sent: Friday, February 09, 2007 10:50 PM
> Paul,
> Interesting...I've never heard of a partical kill switch. I do have to
> admit that every day that I spend working on our 'Bird it is
> enlightening...always something new to discover.
> Curt Sprenger
> PRWillms@... wrote:
> > Hi I have an 88 XXV. Did you happen to put glasses or dishes in the
> > cabnet over the sink to the right? I have a partical kill switch in
> > there. It turns off the front side of the coach, 110v only. Do both
> > volt guages in the overhead front right panel show 110?
> > Paul Williams 88XXV 8V92
> > In South Lake Tahoe
> > -----Original Message-----
> > From: chaunceyboyblu@...
> > Sent: Fri, 9 Feb 2007 8:31 PM
> > Subject: [WanderlodgeForum] power problem
> > I am checking the breaker at the wire going to it, or from it. it is a
> > bryant breaker, doesnt the power come into the breaker behind it where
> > it clamps onto the box? and the big wire connecting to the breaker is
> > going out from the breaker? Anyway, I checked all the breakers and they
> > all had 110 volts. Wher could the problem be after that?
> > Robert Rahn
> > 88 pt 40
> > Kalispell, Mt.
> > __________________________________________________________
> > Check out the new AOL. Most comprehensive set of free safety and
> > security tools, free access to millions of high-quality videos from
> > across the web, free AOL Mail and more.
> > [Non-text portions of this message have been removed]
02-10-2007, 13:35
power problem
Starting the generator with shore power plugged in might not work
right -- the "safe line" switch may continue to receive power from
the shore connection. Don't know, for sure, 'cause of the different
electrical setup from year to year.
Before you go nuts taking things apart on your coach, unplug the line
from shore power, and use your tester in the shore power socket. It
looks some thing like this:
0
I I
I
The semi-round at top is Ground, the center, bottom is neutral. Left
and right are red or black. Use your tester to check from left to
bottom (=110?), right to bottom (=110?), left to right (=220?), and
top to bottom (=0?). (Left or right to top should also = 110).
If the shore power is anything other than this, then it's wired wrong.
Do you have a polarity light in your coach? It should indicate
"normal" polarity, otherwise, the shore power is wired wrong and
there's a risk of serious or fatal shock when you step off the coach
to the ground.
Pete Masterson
aeonix1@...
El Sobrante, CA
On Feb 9, 2007, at 9:31 PM, Robert & Teri Rahn wrote:
> when i started the gen and switched the selector to gen from 50 amp, i
> did not turn off or disconnect the shore power. Does that matter?
> Robert
