Lights
02-15-2007, 01:20
Lights
It has been cold here. Our bird is under car (rv) port. Have been checking
from time to time. Yesterday found that when connected to power that lights in
bath room were very dim. The shower light was bright. The outlet in bath also
worked with lamp when it was plugged in. All other outlets worked in coach
worked.
Would anyone have suggestions as to what is causing problem and fix?
Maury 31' 80 fc
02-15-2007, 02:35
Lights
Hi Maury, If they are fluorscent lights, they may be dim in cold
weather until they have had a chance to warm themselves up - several
minutes at least.
Rich D. '99LXi43' CT
--- In WanderlodgeForum@yahoogroups.com, "M.L. Perkinson"
checking from time to time. Yesterday found that when connected to
power that lights in bath room were very dim. The shower light was
bright. The outlet in bath also worked with lamp when it was plugged
in. All other outlets worked in coach worked.
fix?
> Maury 31' 80 fc
02-15-2007, 03:11
Lights
Rich, Thanks for the quick and accurate response! I went back out and left
lights on long enough to verify your advice. Thanks again. Maury 80 31' fc.
Sent: Thursday, February 15, 2007 9:35 AM
Subject: [WanderlodgeForum] Re: Lights
minutes at least.
fix?
> Maury 31' 80 fc
Checked by AVG Free Edition.
Version: 7.5.441 / Virus Database: 268.17.39/686 - Release Date: 2/14/2007
7:54 AM
