Frozen pipes
02-18-2007, 02:42
Frozen pipes
I have found the weakest link to the frozen pipes saga. The water pipe
run through the nightstand on the street side have been repaired many
times due to the fact that there is no warm air circulating there.
So, this is the area that needs most of the attention. I will repair
all these runs with pex and add some heat tape.
Ernie-83PT40
Livingston, Mt
02-18-2007, 05:53
Frozen pipes
Same place mine froze too Ernie. Heat tape & PEX should fix it. I'm
going to add the circulating pump to my system too. If it's moving, it
won't freeze.
Terry Neal
Bozeman, MT
82PT40
74FC34
> Ernie-83PT40
> Livingston, Mt
02-18-2007, 05:59
Frozen pipes
Will you have to make any modifications to allow the water to recirculate?
83PT40
Livingston,Montana
Sent: Sunday, February 18, 2007 10:53 AM
Subject: Re: [WanderlodgeForum] Frozen pipes
won't freeze.
Terry Neal
Bozeman, MT
82PT40
74FC34
> Ernie-83PT40
> Livingston, Mt
02-18-2007, 06:10
Frozen pipes
Just install the pump and then add a "crossover" from the hot to the
cold lines, probably put it under the galley sink since there is "some"
access there.
Terry Neal
Bozeman, MT
82PT40
74FC34
> Ernie Ekberg
> 83PT40
> Livingston,Montana
> From: Terry Neal
> won't freeze.
> Terry Neal
> Bozeman, MT
> 82PT40
> 74FC34
> > Ernie-83PT40
> > Livingston, Mt
02-18-2007, 06:20
Frozen pipes
Terry:
What kind of crossover are you thinking about? Have you heard of the
"chillipepper"?
Terrace, B.C. Canada
Sent: Sunday, February 18, 2007 10:10:36 AM
access there.
Terry Neal
Bozeman, MT
82PT40
74FC34
> Ernie Ekberg
> 83PT40
> Livingston,Montana
> From: Terry Neal
> To: WanderlodgeForum@ yahoogroups. com
> won't freeze.
> Terry Neal
> Bozeman, MT
> 82PT40
> 74FC34
> > Ernie-83PT40
> > Livingston, Mt
Do You Yahoo!?
http://mail.yahoo.com
02-18-2007, 06:21
Frozen pipes
Would you have to have a bypass valve on this project?
83PT40
Livingston,Montana
Sent: Sunday, February 18, 2007 11:10 AM
access there.
Terry Neal
Bozeman, MT
82PT40
74FC34
> Ernie Ekberg
> 83PT40
> Livingston,Montana
> From: Terry Neal
> won't freeze.
> Terry Neal
> Bozeman, MT
> 82PT40
> 74FC34
> > Ernie-83PT40
> > Livingston, Mt
02-18-2007, 06:34
Frozen pipes
Yes Bill. Probably will use that or something similar. I found a
couple a while back that should work. One that opens at set temp is
what I had in mind. Then it won't cause issues in the warmer months, or
just close it off in summer.
Stay warm up there & thanks for all your help & expertise on the surge
protector.
Terry Neal
Bozeman, MT
82PT40
74FC34
Wilhelmus Schreurs wrote:
> Terry:
> "chillipepper"?
> From: Terry Neal > >
> access there.
> Terry Neal
> Bozeman, MT
> 82PT40
> 74FC34
> recirculate?
> > Ernie Ekberg
> > 83PT40
> > Livingston,Montana
> > From: Terry Neal
> > won't freeze.
> > Terry Neal
> > Bozeman, MT
> > 82PT40
> > 74FC34
> > > Ernie-83PT40
> > > Livingston, Mt
> Do You Yahoo!?
> http://mail.yahoo.com <http://mail.yahoo.com>
02-18-2007, 06:36
Frozen pipes
Maybe. Might not need one. Want to keep it as simple as possible & not
cause problems with regular system flows.
Terry Neal
Bozeman, MT
82PT40
74FC34
> Ernie Ekberg
> 83PT40
> Livingston,Montana
> From: Terry Neal
> access there.
> Terry Neal
> Bozeman, MT
> 82PT40
> 74FC34
> recirculate?
> > Ernie Ekberg
> > 83PT40
> > Livingston,Montana
> > From: Terry Neal
> > won't freeze.
> > Terry Neal
> > Bozeman, MT
> > 82PT40
> > 74FC34
> > > Ernie-83PT40
> > > Livingston, Mt
02-18-2007, 15:26
Frozen pipes
MAYBE-
i AM not following but you need 2 valves in the rear that I just
replaced on mine with ball valves to run the chassis heaters and the
hot water heater
constant on to recirc the water thru the hot water heater in the
summer and the other to turn on the other valve for the kick heaters
with the winter setting in mine at 20degrees it was a little cool in
the back untill i turned on the aux water pump then all was good
on the fc it has another valve up ft under the coach for its driver
heat and also factory it has 2 sets of 2 manual screw in valves like
at your house if you blow a line or its real hot to block off the flow
woody
81 fc rb--for sale
90 sp
little rock ark active duty army
not
> Terry Neal
> Bozeman, MT
> 82PT40
> 74FC34
> > Ernie Ekberg
> > 83PT40
> > Livingston,Montana
> > From: Terry Neal
"some"
> > access there.
> > Terry Neal
> > Bozeman, MT
> > 82PT40
> > 74FC34
> > recirculate?
> > > Ernie Ekberg
> > > 83PT40
> > > Livingston,Montana
> > > From: Terry Neal
moving, it
> > > won't freeze.
> > > Terry Neal
> > > Bozeman, MT
> > > 82PT40
> > > 74FC34
water pipe
repaired many
repair
> > > > Ernie-83PT40
> > > > Livingston, Mt
02-18-2007, 17:17
Frozen pipes
Woody,
I am talking about adding a constant circulating pump for the fresh
water/hot water system. Not the engine coolant. You do need 2 sporlan
(or other type) valves for the heaters & coolant. The link I sent Ernie
is: http://www.rewci.com/whhohotwaci.html
Terry Neal
Bozeman, MT
82PT40
74FC34
rwoodysurplus wrote:
> MAYBE-
> hot water heater
> woody
> 81 fc rb--for sale
> 90 sp
> not
> > Terry Neal
> > Bozeman, MT
> > 82PT40
> > 74FC34
> > > Ernie Ekberg
> > > 83PT40
> > > Livingston,Montana
> > > From: Terry Neal
> "some"
> > > access there.
> > > Terry Neal
> > > Bozeman, MT
> > > 82PT40
> > > 74FC34
> > > recirculate?
> > > > Ernie Ekberg
> > > > 83PT40
> > > > Livingston,Montana
> > > > From: Terry Neal
> moving, it
> > > > won't freeze.
> > > > Terry Neal
> > > > Bozeman, MT
> > > > 82PT40
> > > > 74FC34
> water pipe
> repaired many
> repair
> > > > > Ernie-83PT40
> > > > > Livingston, Mt
