Fan Shaft Seal Leaking
02-21-2007, 10:50
Has anyone replaced the engine fan shaft seal? Do you know where to get
the seal? Mine is leaking. I want to take care of that before remounting
the fan.
Curt Sprenger
Anaheim Hills, Calif.
02-21-2007, 11:29
Curt- Ralph, Bim and myself did a seal replacement on my coach. If you have the
radiator removed have at it. We did it with the radiator in place. If I have to
do that again- the coach is up for sale~
83PT40
Livingston,Montana
To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com
Sent: Wednesday, February 21, 2007 3:50 PM
Subject: [WanderlodgeForum] Fan Shaft Seal Leaking
the fan.
Curt Sprenger
02-21-2007, 11:42
Ernie,
Does the 6V and 8V have the same fan set up? If so, I'd like to see you
guys tackling that project with the radiator in place. Must have been a
two box wine job, per person. How many hours went into that job?
Curt Sprenger
> have the radiator removed have at it. We did it with the radiator in
> place. If I have to do that again- the coach is up for sale~
> Ernie Ekberg
> 83PT40
> Livingston,Montana
> From: Curt Sprenger
> the fan.
> Curt Sprenger
02-21-2007, 12:03
Curt, as I recall on my PT, I took that seal down to the local
bearing/seal shop (US Bearings) and they matched it up in a few
minutes. You can also try a shop that builds hydraulic hoses. They
might carry the hydraulic fans & parts. Spencer Power here in MT
carries that stuff.
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
> the fan.
> Curt Sprenger
02-21-2007, 12:14
Curt- I believe it took 2 days. You can get the fan motor off, and leave the fan
resting on a support bracket. You get real messy, and the weather was perfect.
The only other job that was worse, was R/R an airbag on Ralphs coach. 3 days on
that one.
83PT40
Livingston,Montana
Sent: Wednesday, February 21, 2007 4:42 PM
Subject: Re: [WanderlodgeForum] Fan Shaft Seal Leaking
Ernie,
Curt Sprenger
> Ernie Ekberg
> 83PT40
> Livingston,Montana
> From: Curt Sprenger
> the fan.
> Curt Sprenger
02-21-2007, 12:34
Thanks Terry. There is a bearing and seal shop about 5 miles from me.
Curt Sprenger
> carries that stuff.
> Terry Neal
> Bozeman, MT
> 82PT40 6V92TA
> 74FC34 6V53T
> > the fan.
> > Curt Sprenger
02-21-2007, 16:12
Curt, Off Maple in Corona is King bearing now called Applied
Industrial Technologies
361 S Maple St
Corona, CA 92880
(951) 371-2550
Or In Fontan "O rings and things" across from the speedway.
94ptRomolandCa
get
remounting
> the fan.
> Curt Sprenger
02-21-2007, 16:48
Thanks Greg.
I was trying to come up with the name. Where the H%$L did Applied
Industrial Technologies get substituted for King Bearing? Just doesn't
seem like a good name change if they want to keep bearing & seal
customers coming in. Probable a buy out with no consideration. Thanks again.
Curt Sprenger
> 361 S Maple St
> Corona, CA 92880
> (951) 371-2550
> Gregory O'Connor
> 94ptRomolandCa
> , Curt Sprenger
> get
> remounting
> > the fan.
> > Curt Sprenger
