Thinking caps on?
02-22-2007, 02:44
Thinking caps on?
Hi Ralph,
Sometimes my thinking cap is too small won't fit!
I would start at the source since you can't find
any apparent leaks, cap or shut off the pump with
a valve, then if it don't "burp" you have a starting
point.
Still burping, problem at the pump.
No burping, isolate connections, go from there.
bob janes, greenville, sc
> Morning George:
> Perhaps on the set point, but they come preset and have not looked
to see
> if there is a set screw to change that. Since you had problems with
> check valve (anti leak down valve) then I won't introduce one into
this system.
> Thank you
> Safe travels,
> Ralph and Charolette Fullenwider
> 84FC35
> Ralph's RV Solutions, Duncan, Oklahoma
> At 07:42 AM 2/22/2007 -0500, you wrote:
> >Hello Ralph, just guessing here, but my house system cuts off at
50 psi. I
> >don,t know anything about rv systems, but could your cut out
pressure be
> >set a little high,(65 psi), causing expansion/contraction within
> >system. Another possibility, I put a new pump in several yrs.ago,
(house),
> >and the mfg.recommended installing a anti leak down valve with
their pump,
> >(didn't have one previously). Long story short, had problems until
a
> >plumber friend told me to take that valve out, that it wasn't
needed.
> >Immediately solved the problem, which was like yours, pump
recycling. Hope
> >one of these suggestions help, George Burke 77FC31SB Charlotte
> > ----- Original Message -----
> > From: Tom Meservey
> > To: WanderlodgeForum@yahoogroups.com
> > Sent: Thursday, February 22, 2007 7:04 AM
> > Subject: [WanderlodgeForum] Re:Thinking caps on?
> > Hi Ralph,
> > I think you are right either the Sporlan valve or some air in
the line
> > that keeps tripping it; but my bet would be the Sporlan valve.
> > Regards.
> > Tom Meservey, USN (Ret)
> > Ladson, SC '81FC33' for sale
02-22-2007, 03:44
Thinking caps on?
Ralph, I think I am with Bob, "Backflow at the pump" if you can hook
a hose to the outlet of the pump , fill it with water and close it
off. cycling on and off would reveal a pump problem.
The constant Burping in my Bus has little to do with hydrodynamics.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot"
> Hi Ralph,
> point.
> > Morning George:
looked
> to see
with
> the
into
> this system.
> > Thank you
> > Safe travels,
> > 84FC35
> 50 psi. I
> pressure be
> the
> (house),
> their pump,
until
> a
> needed.
> recycling. Hope
> > > From: Tom Meservey
> > > Hi Ralph,
> the line
> > > Regards.
02-22-2007, 04:14
Thinking caps on?
Ralph, how about the check valve at the city water bypass?
Bruce
02-22-2007, 04:29
Thinking caps on?
Ralph,
Could be air trapped in the HWT, ????
Bill 88 FC
> Hi Ralph,
> point.
> > Morning George:
looked
> to see
with
> the
into
> this system.
> > Thank you
> > Safe travels,
> > 84FC35
> 50 psi. I
> pressure be
> the
> (house),
> their pump,
until
> a
> needed.
> recycling. Hope
> > > From: Tom Meservey
> > > Hi Ralph,
> the line
> > > Regards.
02-22-2007, 04:33
Thinking caps on?
I installed a Shurflo extreme in my previous SOB, and it did just that - leaked
back through the pump diaphragms. Shurflo promptly shipped me a replacement
which did not do that. I still have the original one - they said they would send
a pickup tag, but never did!
>GregoryO'Connor
>94ptRomolandCa
>> Hi Ralph,
>> point.
>> wrote:
>> > Morning George:
>looked
>> to see
>with
>> the
>into
>> this system.
>> > Thank you
>> > Safe travels,
>> > 84FC35
>> 50 psi. I
>> pressure be
>> the
>> (house),
>> their pump,
>until
>> a
>> needed.
>> recycling. Hope
>> > > From: Tom Meservey
>> > > Hi Ralph,
>> the line
>> > > Regards.
>Yahoo! Groups - Join or create groups, clubs, forums & communities.
>Links
Don Bradner
http://www.arcatapet.net
02-22-2007, 05:24
Thinking caps on?
Sounds like the Sporlan valve Ralph. If no leaks anywhere else, the
pump is cycling on to bring the pressure back up to it's set point for
the system. Just a thought, but did you check the relief valve on the
water heater? It may be weak?
Is there a pressure switch on the pump head? Can the output pressure be
adjusted at all? Is this one of those new pumps that doesn't have or
need an accumulator? If so, let us know how you like it. I am thinking
about one for my coach.
Now that Todd Jones found Tweetys.com for us, I saw that they carried
that new pump too. Maybe a good deal from them on one?
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
Ralph L. Fullenwider wrote:
> Hi everyone:
> Here is a fun one perhaps.
> Water pump new, 5.7 gpm 65 psi
> Pump cycles after initial pressure up. The cycle is a slight burp about
> every 10 to 15 seconds. This normally indicates a water leak.
> Kicker, I have been from one end of the pressure side of the piping
> and no
> water leak. Only think I can think of at this point is perhaps crud in
> the
> Sporlan valve allowing a seepage back into the system causing a slight
> drop
> in pressure at the pump. The anti back flow valve seal is good, pulled it
> and checked it out.
> Ideas?
> Safe travels,
> 84FC35
02-22-2007, 06:48
Thinking caps on?
Ralph,
I just did the same modification ... took out the original pumps (2)
and the expansion tank and replaced with the ShurFlow variable speed
pump.
I have _no_ "burps" as you describe. The only time the pump switches
on is whenever a valve is opened somewhere, causing a pressure drop
in the system. Perhaps you have a leak that drips under the coach or
into a basement bay...?
Depending on the type of plumbing you have (I have polybutylene, but
that came along well after 84), you may have specific potential leak
sites where a leak of long standing may occur. In my case, the higher
pressure caused the water system emptying valve, that had a hairline
crack of long standing, to fail. No other leaks appeared.
The Sporlan valve on my system controls the flow when you flip the
'fill tank' switch. In that situation, the ShurFlow runs continuously
(that is, until I turned off the water pump switch). So, I presume
that if my Sporlan were letting a small quantity of water seep past,
that it might trigger the Shurflow from time to time.
If you have thoroughly checked all other sources of possible leaks
without finding any, then I'd say you have a Sporlan rebuild in your
future....
Pete Masterson
aeonix1@...
El Sobrante, CA
On Feb 21, 2007, at 8:34 PM, Ralph L. Fullenwider wrote:
> Hi everyone:
> about
> and no
> in the
> slight drop
> pulled it
> and checked it out.
> Ideas?
> 84FC35
02-24-2007, 06:45
Thinking caps on?
Ralph, You might want to check that long handled HWT drain valve that has a
pull cable on it. I chased that problem on our FC and finally discovered it was
that valve. That was after I had rebuilt the Sporlan fill valve.
Sent: Wednesday, February 21, 2007 8:34 PM
Subject: [WanderlodgeForum] Thinking caps on?
Hi everyone:
Kicker, I have been from one end of the pressure side of the piping and no
water leak. Only think I can think of at this point is perhaps crud in the
Sporlan valve allowing a seepage back into the system causing a slight drop
and checked it out.
Ideas?
Safe travels,
84FC35
02-24-2007, 07:02
Thinking caps on?
Thanks Dick:
And another good point to add to the list of troubleshooting for future
problems for all of us.
Trouble shooting points collective (add any that I missed and we will put
the list in the files section)
1. Leak back through pump
2. Anti back flow valve
3. Sporlan valve
4. fresh water drain valve
5. Burst piping/lose fittings and so forth.
6. City water input valve
7. Water heater pressure relief valve.
I have modified that valve to an air cylinder open/close now rather then
the cable pull system. Problem was the Sporlan valve
Safe travels,
84FC35
>a pull cable on it. I chased that problem on our FC and finally
>discovered it was that valve. That was after I had rebuilt the Sporlan
>fill valve.
> From: Ralph L. Fullenwider
> To:
> Hi everyone:
> drop
> and checked it out.
> Ideas?
> Safe travels,
> 84FC35
