Coolant Pressure Control Cap
03-03-2007, 16:20
Coolant Pressure Control Cap...the 92 series manual recommends all
series 92 on-highway vehicle engines use a minimum 9 psi control cap. My radiator cap is a 7 psi. Is this a Bluebird change? What are others using? Should I be concerned? The engine temperature runs at about 185 to 195. -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. |
03-03-2007, 16:43
Curt:
My cap is 13psi, was on the coach when I purchased it and it's still there. I changed my fan control alarmstat to 190 degrees and my temperature range now in winter is 180-190. I expect 190 constant with the chassis a/c on in summer. We will see when it gets hot. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com Sent: Saturday, March 03, 2007 10:20 PM Subject: [WanderlodgeForum] Coolant Pressure Control Cap Coolant Pressure Control Cap...the 92 series manual recommends all series 92 on-highway vehicle engines use a minimum 9 psi control cap. My radiator cap is a 7 psi. Is this a Bluebird change? What are others using? Should I be concerned? The engine temperature runs at about 185 to 195. -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. [Non-text portions of this message have been removed] |
03-04-2007, 00:31
Curt,
The discrepancy between the manual and what BB does came up previously. Due to the application being a motorhome, BB engineers may (may) have determined the 7PSI is correct. Seems most folks have a 7PSI cap on a 92. We have 7PSI, and temps run 190 â 195, and is acceptable. I'd say your temps seem to be right on. Ron, No. California 85PT36 --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Coolant Pressure Control Cap...the 92 series manual recommends all > series 92 on-highway vehicle engines use a minimum 9 psi control > cap. My radiator cap is a 7 psi. > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. |
03-04-2007, 01:49
Leroy i also would like to change my fan switch to a 190,i changed
mine two years ago to a 195 its all i could find.If you have a part number or the source it would be good. Thanks Jack Jones 87 Pt 40 East Tn 27 and snowing |
03-04-2007, 05:44
My theory about the 7 lb. cap is the coach heating system is tied into the
cooling system and Blue Bird has used that pressure to protect the other systems in the coach,let alone miles of heater hose! Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge WLWB41 [Non-text portions of this message have been removed] |
03-04-2007, 14:09
Your theory may be totally correct.
My understand of cap pressure values, the higher the pressure, the higher the boiling point. Assuming BB used top quality hoses and I believe they did I have some trouble differentiating between the bus and my Cummins SLT 3/4 ton PU, when it comes to cap pressure. My diesel truck heating system is tied to the cooling system and it has a factory 15psi cap. My bus has a 13psi cap that I did not install and over the past 3 years all has been good. The DD service manual says 7-9 psi. I give up, maybe. Over the past few months I have been making small changes to the cooling system in my bus. I am taking chances, testing them on my bus, in an effort to reduce overall temperatures in the engine, transmission, retarder and engine oil. I have changed the Alarmstat, which operates the hydraulic fan to 190 degrees from 195 degrees. I will not know the full extent this change until summer, but so far it is working. Before I decided to make the change I consulted with DD approved shops and BB. I was not satisfied with the answers sooooo, I pressed on. The DD manual says to be careful not to have cooling system components operate out of sequence because the result will be overheating. At this point in my testing I have concluded the foregoing to mean, the cooling fan, the engine thermostats, and the alarmstat, primarily because I do not know of any other cooling affected components other than the cap. Before I embarked upon my mission, I was told that temperature cycling was the result of the engine thermostats cycling. Unfortunately, I cannot force that to happen and I have tried. I have driven the coach in temperatures of below 32 degrees with the fan override on and my water temperature gauge stabilizes at about 170 degrees, the engine thermostat value. In other words, it doesn't move once stabilized, so the engine thermostats are not cycling(possibly). If they are it is happening so quickly that it does not register on the temp guage or they partially close and shut down the water flow to hold the constant temperature. I cannot see them work. When I turn the fan override off the temperature begins to cycle off the Alarmstat between 180-190 degrees. All of this fits the DD published coolant Series 92 publication in my possession. Why BB dedided on a 195 degree Alarmstat, only BB knows and they aren't talking, because I have asked. I simply does not make sense to force the temperatures to the outer limit of DD specifications, ;and that is what happens in summer. Heat is our enemy and I have been able to reduce the heat. Most likely, I will change my cap to 9psi sometime in the summer and see if that makes any difference. My guess is it will not simply because keeping the engine cooling system within temperature specifications precludes any real need for the cap to blow off. I like my drive train component temps now. Engine Oil-215 Water Temp-Cycles between 180-190 Transmission Temp- 170 Retarder Temp- 220 All recorded in flat conditions at cruise speed of 68 mph, pulling a 20ft trailer w/car. I do not suggest you try anything unless you fully understand your system, I'm simply reporting what I did. The foregoing presumes that all system components are in proper working order. My next project is to install MH's water injection system so when I climb the mountains next summer I'll have a water flood just in case. Alright, fire away, I have Redneck engineering paperwork on this one. LOL lol, lol Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Fred Hulse To: WanderlodgeForum@yahoogroups.com Sent: Sunday, March 04, 2007 11:44 AM Subject: Re: [WanderlodgeForum] Coolant Pressure Control Cap My theory about the 7 lb. cap is the coach heating system is tied into the cooling system and Blue Bird has used that pressure to protect the other systems in the coach,let alone miles of heater hose! Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge WLWB41 [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
03-04-2007, 14:38
Leroy: If you want to increase the cooling of your 8V-92 you
could install a 4" air scoup behind the radiator opening to help catch the air and redirect it into the radiator. I did this on a 6V- 92. I had it made out of stainless steel it had nice curve to it to help capture the air. It worked well. Bob 93pt40--Bunker Hill, Illinois....Soon to be back in Jackson,Wy. > > Your theory may be totally correct. > > My understand of cap pressure values, the higher the pressure, the higher the boiling point. Assuming BB used top quality hoses and I believe they did I have some trouble differentiating between the bus and my Cummins SLT 3/4 ton PU, when it comes to cap pressure. My diesel truck heating system is tied to the cooling system and it has a factory 15psi cap. My bus has a 13psi cap that I did not install and over the past 3 years all has been good. The DD service manual says 7-9 psi. I give up, maybe. > > Over the past few months I have been making small changes to the cooling system in my bus. I am taking chances, testing them on my bus, in an effort to reduce overall temperatures in the engine, transmission, retarder and engine oil. I have changed the Alarmstat, which operates the hydraulic fan to 190 degrees from 195 degrees. > I will not know the full extent this change until summer, but so far it is working. > > Before I decided to make the change I consulted with DD approved shops and BB. I was not satisfied with the answers sooooo, I pressed on. > > The DD manual says to be careful not to have cooling system components operate out of sequence because the result will be overheating. At this point in my testing I have concluded the foregoing to mean, the cooling fan, the engine thermostats, and the alarmstat, primarily because I do not know of any other cooling affected components other than the cap. > > Before I embarked upon my mission, I was told that temperature cycling was the result of the engine thermostats cycling. Unfortunately, I cannot force that to happen and I have tried. I have driven the coach in temperatures of below 32 degrees with the fan override on and my water temperature gauge stabilizes at about 170 degrees, the engine thermostat value. In other words, it doesn't move once stabilized, so the engine thermostats are not cycling (possibly). If they are it is happening so quickly that it does not register on the temp guage or they partially close and shut down the water flow to hold the constant temperature. I cannot see them work. When I turn the fan override off the temperature begins to cycle off the Alarmstat between 180-190 degrees. > > All of this fits the DD published coolant Series 92 publication in my possession. Why BB dedided on a 195 degree Alarmstat, only BB knows and they aren't talking, because I have asked. I simply does not make sense to force the temperatures to the outer limit of DD specifications, ;and that is what happens in summer. Heat is our enemy and I have been able to reduce the heat. > > Most likely, I will change my cap to 9psi sometime in the summer and see if that makes any difference. My guess is it will not simply because keeping the engine cooling system within temperature specifications precludes any real need for the cap to blow off. > > I like my drive train component temps now. > > Engine Oil-215 > Water Temp-Cycles between 180-190 > Transmission Temp- 170 > Retarder Temp- 220 > All recorded in flat conditions at cruise speed of 68 mph, pulling a 20ft trailer w/car. > > I do not suggest you try anything unless you fully understand your system, I'm simply reporting what I did. > The foregoing presumes that all system components are in proper working order. > > My next project is to install MH's water injection system so when I climb the mountains next summer I'll have a water flood just in case. > > Alright, fire away, I have Redneck engineering paperwork on this one. LOL lol, lol > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > > > > ----- Original Message ----- > From: Fred Hulse > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, March 04, 2007 11:44 AM > Subject: Re: [WanderlodgeForum] Coolant Pressure Control Cap > > > My theory about the 7 lb. cap is the coach heating system is tied into the cooling system and Blue Bird has used that pressure to protect the other systems in the coach,let alone miles of heater hose! > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > |
03-04-2007, 15:02
Leroy: I also installed what was or is called a swamp cooler
on the radiator. It took water from the potable water tank and thru a pump and fittings it sprayed water on the radiator on demand. I had the control at the driver panel. It had about four or five different settings that sprayed water at timed rates. I would rate it about 5 on a scale of 1 to 10. I really never used it much. The best procedure was to turn the fan on before the climb and adjust speed and rpm with a lower gear and just sit and enjoy the ride up the pass. One draw back might be that if your using really hard water that you will get a mineral build up on the fin's of the radiator rather quickly.(hard to get off). worked for me..sort-of..??;;;;; Bob 93pt-40 ' > > > Leroy: If you want to increase the cooling of your 8V-92 you > could install a 4" air scoup behind the radiator opening to help > catch the air and redirect it into the radiator. I did this on a 6V- > 92. I had it made out of stainless steel it had nice curve to it to > help capture the air. It worked well. Bob > 93pt40--Bunker Hill, Illinois....Soon to be back in Jackson,Wy. > > > > > > > > Your theory may be totally correct. > > > > My understand of cap pressure values, the higher the pressure, the > higher the boiling point. Assuming BB used top quality hoses and I > believe they did I have some trouble differentiating between the bus > and my Cummins SLT 3/4 ton PU, when it comes to cap pressure. My > diesel truck heating system is tied to the cooling system and it has > a factory 15psi cap. My bus has a 13psi cap that I did not install > and over the past 3 years all has been good. The DD service manual > says 7-9 psi. I give up, maybe. > > > > Over the past few months I have been making small changes to the > cooling system in my bus. I am taking chances, testing them on my > bus, in an effort to reduce overall temperatures in the engine, > transmission, retarder and engine oil. I have changed the Alarmstat, > which operates the hydraulic fan to 190 degrees from 195 degrees. > > I will not know the full extent this change until summer, but so > far it is working. > > > > Before I decided to make the change I consulted with DD approved > shops and BB. I was not satisfied with the answers sooooo, I pressed > on. > > > > The DD manual says to be careful not to have cooling system > components operate out of sequence because the result will be > overheating. At this point in my testing I have concluded the > foregoing to mean, the cooling fan, the engine thermostats, and the > alarmstat, primarily because I do not know of any other cooling > affected components other than the cap. > > > > Before I embarked upon my mission, I was told that temperature > cycling was the result of the engine thermostats cycling. > Unfortunately, I cannot force that to happen and I have tried. I > have driven the coach in temperatures of below 32 degrees with the > fan override on and my water temperature gauge stabilizes at about > 170 degrees, the engine thermostat value. In other words, it doesn't > move once stabilized, so the engine thermostats are not cycling > (possibly). If they are it is happening so quickly that it does not > register on the temp guage or they partially close and shut down the > water flow to hold the constant temperature. I cannot see them > work. When I turn the fan override off the temperature begins to > cycle off the Alarmstat between 180-190 degrees. > > > > All of this fits the DD published coolant Series 92 publication in > my possession. Why BB dedided on a 195 degree Alarmstat, only BB > knows and they aren't talking, because I have asked. I simply does > not make sense to force the temperatures to the outer limit of DD > specifications, ;and that is what happens in summer. Heat is our > enemy and I have been able to reduce the heat. > > > > Most likely, I will change my cap to 9psi sometime in the summer > and see if that makes any difference. My guess is it will not simply > because keeping the engine cooling system within temperature > specifications precludes any real need for the cap to blow off. > > > > I like my drive train component temps now. > > > > Engine Oil-215 > > Water Temp-Cycles between 180-190 > > Transmission Temp- 170 > > Retarder Temp- 220 > > All recorded in flat conditions at cruise speed of 68 mph, pulling > a 20ft trailer w/car. > > > > I do not suggest you try anything unless you fully understand your > system, I'm simply reporting what I did. > > The foregoing presumes that all system components are in proper > working order. > > > > My next project is to install MH's water injection system so when I > climb the mountains next summer I'll have a water flood just in case. > > > > Alright, fire away, I have Redneck engineering paperwork on this > one. LOL lol, lol > > > > Leroy Eckert > > 1990 WB-40"Smoke N Mirrors" > > Niceville, FL > > > > > > > > ----- Original Message ----- > > From: Fred Hulse > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, March 04, 2007 11:44 AM > > Subject: Re: [WanderlodgeForum] Coolant Pressure Control Cap > > > > > > My theory about the 7 lb. cap is the coach heating system is tied > into the cooling system and Blue Bird has used that pressure to > protect the other systems in the coach,let alone miles of heater hose! > > Fred & Jeanne Hulse > > Morristown Arizona > > 1997 Wanderlodge WLWB41 > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
03-04-2007, 15:12
Thanks, I totally agree, that is an option. I have determined that air flow
and fan cycling design determines water temperature, and water temperature affects all the other drive train components. Of course, there are other factors such as chassis a/c condenser location. While I have never incurred overheating problems I simply do not understand why I need to run a very expensive engine in the top of the published temperature range. And I have not been able to obtain a definitive answer from BB or any approved DD shop I have contacted. So, I pressed on. It is not a dragster you know? I know, H/P rob , but that argument doesn't work in my case, because the fan is gonna cycle at 195 degrees or 190 degrees, except when you pull the mountain, at which time you need all the cooling you can get. That 5 degree variance means a bunch in cooling the other components. Mine is also different because it is a Royale conversion. That is why I am very careful when offering advise. Many components are not in the standard location, and wiring does not match BB schematics most of the time. However, I have very few problems. They did a fine job. Thanks again, and Jackson, WY is a beautiful place. Hope to get there in the bus in summer. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Bob & Carol Howald` To: WanderlodgeForum@yahoogroups.com Sent: Sunday, March 04, 2007 8:38 PM Subject: [WanderlodgeForum] Re: Coolant Pressure Control Cap Leroy: If you want to increase the cooling of your 8V-92 you could install a 4" air scoup behind the radiator opening to help catch the air and redirect it into the radiator. I did this on a 6V- 92. I had it made out of stainless steel it had nice curve to it to help capture the air. It worked well. Bob 93pt40--Bunker Hill, Illinois....Soon to be back in Jackson,Wy. > > Your theory may be totally correct. > > My understand of cap pressure values, the higher the pressure, the higher the boiling point. Assuming BB used top quality hoses and I believe they did I have some trouble differentiating between the bus and my Cummins SLT 3/4 ton PU, when it comes to cap pressure. My diesel truck heating system is tied to the cooling system and it has a factory 15psi cap. My bus has a 13psi cap that I did not install and over the past 3 years all has been good. The DD service manual says 7-9 psi. I give up, maybe. > > Over the past few months I have been making small changes to the cooling system in my bus. I am taking chances, testing them on my bus, in an effort to reduce overall temperatures in the engine, transmission, retarder and engine oil. I have changed the Alarmstat, which operates the hydraulic fan to 190 degrees from 195 degrees. > I will not know the full extent this change until summer, but so far it is working. > > Before I decided to make the change I consulted with DD approved shops and BB. I was not satisfied with the answers sooooo, I pressed on. > > The DD manual says to be careful not to have cooling system components operate out of sequence because the result will be overheating. At this point in my testing I have concluded the foregoing to mean, the cooling fan, the engine thermostats, and the alarmstat, primarily because I do not know of any other cooling affected components other than the cap. > > Before I embarked upon my mission, I was told that temperature cycling was the result of the engine thermostats cycling. Unfortunately, I cannot force that to happen and I have tried. I have driven the coach in temperatures of below 32 degrees with the fan override on and my water temperature gauge stabilizes at about 170 degrees, the engine thermostat value. In other words, it doesn't move once stabilized, so the engine thermostats are not cycling (possibly). If they are it is happening so quickly that it does not register on the temp guage or they partially close and shut down the water flow to hold the constant temperature. I cannot see them work. When I turn the fan override off the temperature begins to cycle off the Alarmstat between 180-190 degrees. > > All of this fits the DD published coolant Series 92 publication in my possession. Why BB dedided on a 195 degree Alarmstat, only BB knows and they aren't talking, because I have asked. I simply does not make sense to force the temperatures to the outer limit of DD specifications, ;and that is what happens in summer. Heat is our enemy and I have been able to reduce the heat. > > Most likely, I will change my cap to 9psi sometime in the summer and see if that makes any difference. My guess is it will not simply because keeping the engine cooling system within temperature specifications precludes any real need for the cap to blow off. > > I like my drive train component temps now. > > Engine Oil-215 > Water Temp-Cycles between 180-190 > Transmission Temp- 170 > Retarder Temp- 220 > All recorded in flat conditions at cruise speed of 68 mph, pulling a 20ft trailer w/car. > > I do not suggest you try anything unless you fully understand your system, I'm simply reporting what I did. > The foregoing presumes that all system components are in proper working order. > > My next project is to install MH's water injection system so when I climb the mountains next summer I'll have a water flood just in case. > > Alright, fire away, I have Redneck engineering paperwork on this one. LOL lol, lol > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > > > > ----- Original Message ----- > From: Fred Hulse > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, March 04, 2007 11:44 AM > Subject: Re: [WanderlodgeForum] Coolant Pressure Control Cap > > > My theory about the 7 lb. cap is the coach heating system is tied into the cooling system and Blue Bird has used that pressure to protect the other systems in the coach,let alone miles of heater hose! > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
03-04-2007, 15:16
Good idea. I have plenty of room to install a back up distilled water tank for that purpose just in case. You never know when you might need some help. I would be easy to do. Thanks, Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Bob & Carol Howald` To: WanderlodgeForum@yahoogroups.com Sent: Sunday, March 04, 2007 9:02 PM Subject: [WanderlodgeForum] Re: Coolant Pressure Control Cap Leroy: I also installed what was or is called a swamp cooler on the radiator. It took water from the potable water tank and thru a pump and fittings it sprayed water on the radiator on demand. I had the control at the driver panel. It had about four or five different settings that sprayed water at timed rates. I would rate it about 5 on a scale of 1 to 10. I really never used it much. The best procedure was to turn the fan on before the climb and adjust speed and rpm with a lower gear and just sit and enjoy the ride up the pass. One draw back might be that if your using really hard water that you will get a mineral build up on the fin's of the radiator rather quickly.(hard to get off). worked for me..sort-of..??;;;;; Bob 93pt-40 ' > > > Leroy: If you want to increase the cooling of your 8V-92 you > could install a 4" air scoup behind the radiator opening to help > catch the air and redirect it into the radiator. I did this on a 6V- > 92. I had it made out of stainless steel it had nice curve to it to > help capture the air. It worked well. Bob > 93pt40--Bunker Hill, Illinois....Soon to be back in Jackson,Wy. > > > > > > > > Your theory may be totally correct. > > > > My understand of cap pressure values, the higher the pressure, the > higher the boiling point. Assuming BB used top quality hoses and I > believe they did I have some trouble differentiating between the bus > and my Cummins SLT 3/4 ton PU, when it comes to cap pressure. My > diesel truck heating system is tied to the cooling system and it has > a factory 15psi cap. My bus has a 13psi cap that I did not install > and over the past 3 years all has been good. The DD service manual > says 7-9 psi. I give up, maybe. > > > > Over the past few months I have been making small changes to the > cooling system in my bus. I am taking chances, testing them on my > bus, in an effort to reduce overall temperatures in the engine, > transmission, retarder and engine oil. I have changed the Alarmstat, > which operates the hydraulic fan to 190 degrees from 195 degrees. > > I will not know the full extent this change until summer, but so > far it is working. > > > > Before I decided to make the change I consulted with DD approved > shops and BB. I was not satisfied with the answers sooooo, I pressed > on. > > > > The DD manual says to be careful not to have cooling system > components operate out of sequence because the result will be > overheating. At this point in my testing I have concluded the > foregoing to mean, the cooling fan, the engine thermostats, and the > alarmstat, primarily because I do not know of any other cooling > affected components other than the cap. > > > > Before I embarked upon my mission, I was told that temperature > cycling was the result of the engine thermostats cycling. > Unfortunately, I cannot force that to happen and I have tried. I > have driven the coach in temperatures of below 32 degrees with the > fan override on and my water temperature gauge stabilizes at about > 170 degrees, the engine thermostat value. In other words, it doesn't > move once stabilized, so the engine thermostats are not cycling > (possibly). If they are it is happening so quickly that it does not > register on the temp guage or they partially close and shut down the > water flow to hold the constant temperature. I cannot see them > work. When I turn the fan override off the temperature begins to > cycle off the Alarmstat between 180-190 degrees. > > > > All of this fits the DD published coolant Series 92 publication in > my possession. Why BB dedided on a 195 degree Alarmstat, only BB > knows and they aren't talking, because I have asked. I simply does > not make sense to force the temperatures to the outer limit of DD > specifications, ;and that is what happens in summer. Heat is our > enemy and I have been able to reduce the heat. > > > > Most likely, I will change my cap to 9psi sometime in the summer > and see if that makes any difference. My guess is it will not simply > because keeping the engine cooling system within temperature > specifications precludes any real need for the cap to blow off. > > > > I like my drive train component temps now. > > > > Engine Oil-215 > > Water Temp-Cycles between 180-190 > > Transmission Temp- 170 > > Retarder Temp- 220 > > All recorded in flat conditions at cruise speed of 68 mph, pulling > a 20ft trailer w/car. > > > > I do not suggest you try anything unless you fully understand your > system, I'm simply reporting what I did. > > The foregoing presumes that all system components are in proper > working order. > > > > My next project is to install MH's water injection system so when I > climb the mountains next summer I'll have a water flood just in case. > > > > Alright, fire away, I have Redneck engineering paperwork on this > one. LOL lol, lol > > > > Leroy Eckert > > 1990 WB-40"Smoke N Mirrors" > > Niceville, FL > > > > > > > > ----- Original Message ----- > > From: Fred Hulse > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sunday, March 04, 2007 11:44 AM > > Subject: Re: [WanderlodgeForum] Coolant Pressure Control Cap > > > > > > My theory about the 7 lb. cap is the coach heating system is tied > into the cooling system and Blue Bird has used that pressure to > protect the other systems in the coach,let alone miles of heater hose! > > Fred & Jeanne Hulse > > Morristown Arizona > > 1997 Wanderlodge WLWB41 > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed] |
