8V92 Low Fuel Pressure
03-11-2007, 04:31
I changed seven fuel lines...4 at the heads, Racor to fuel pump, fuel
pump to filter inlet, return manifold to hard return line.
After priming/starting the 8V92...Fuel Pressure readings were 8 at idle,
45 at 2150 rpms. Ran the engine for a few minutes. Fuel pressure now 2
at idle, 30 at 2150 rpms. The manual says 20 to 30 at idle, 50 to 70 at
2150 rpms.
A new fuel pump was installed. Same low pressures as above.
Removed the pressure relief plug, gasket, pin, spring, relief valve,
from the *old* pump. All looks good, nothing stuck.
My error, I did not take fuel pressure readings before the hose change,
problem could have been there before.
Thoughts?
Curt Sprenger
Anaheim Hills, Calif.
03-11-2007, 06:43
I know Mercedes diesels can get dirty screens in the fuel tank. Don't know if
this could
happen in your case. Have you checked the flow out of the tank?
Kerry
82 FC 35
Denver
> 2150 rpms.
> Thoughts?
> Curt Sprenger
03-11-2007, 07:07
Curt,
Reply off line, at tjholtermann@.... I need to ask you some
questions, I think I help you with your problem.
Tony Holtermann
88wb38 San Marcos, Tx.
fuel
idle,
now 2
70 at
> 2150 rpms.
valve,
change,
> Thoughts?
> Curt Sprenger
03-11-2007, 07:59
I should have added that you can test the tank by simply taking a gallon
container of diesel
and putting your suction and return lines into it and try running the engine off
the container.
It would exclude any problems upstream of your attachment point to the tank.
Kerry
82 FC 35
Denver
this could
> Kerry
> 82 FC 35
> Denver
03-12-2007, 06:57
Have you verified the gauge is reading correctly?
Troy
To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com
Sent: Sunday, March 11, 2007 10:31 AM
Subject: [WanderlodgeForum] 8V92 Low Fuel Pressure
2150 rpms.
Thoughts?
Curt Sprenger
03-12-2007, 12:19
Yes.
Curt Sprenger
> Troy
> From: Curt Sprenger
> 2150 rpms.
> Thoughts?
> Curt Sprenger
03-12-2007, 14:22
See if there is a check valvein the line if so it may need to be cleaned
re brake 1983 fc-35
> From: "tjholtermann"
> Date: 2007/03/11 Sun PM 01:07:45 EST
> Subject: [WanderlodgeForum] Re: 8V92 Low Fuel Pressure
> Curt,
> Tony Holtermann
> fuel
> idle,
> now 2
> 70 at
> > 2150 rpms.
> valve,
> change,
> > Thoughts?
> > Curt Sprenger
