Air Step problem - will not completely extend without 'help'
03-11-2007, 10:52
My air step is hanging up during extension (opening) and is not fully
extending without 'help' from my foot, shaking the step a bit. No problem with retraction (closing). Lubricating all pivot points did not help. Air expels during the opening and closing process, as is normal. Once the step is locked into place, either open or closed, it stops. However, when the step hangs up (partially open) air continues to expel from what I believe to be the step solenoid valve. In particular the escaping air is coming from one of the two 'spark plug shaped' devices on the bottom of the valve. Advice appreciated ... and if someone could give me the proper name of the 'spark plug shaped' devices, that too, would be appreciated. Roger Webb 91 WL Cedar Rapids, IA |
03-11-2007, 12:07
Roger
I had a similar problem, except mine would not retract. I talked to Kenny Rodgers at Coach Craft, was arranging replacement of Primus, he said that the step valve is the lowest part of the air system and any water that accumulates will go there. His suggestions, and it worked for me, was to remove the inbound airline, purge, put some WD-40 in the line, reattach then operate the step many times to expel any water remaining. When it WARMS UP I am going to put a small separator on that line to prevent the problem. Steve Quandt Iron Mountain MI 1993-PT40 -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of rogerwwebb Sent: Sunday, March 11, 2007 4:53 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Air Step problem - will not completely extend without 'help' My air step is hanging up during extension (opening) and is not fully extending without 'help' from my foot, shaking the step a bit. No problem with retraction (closing). Lubricating all pivot points did not help. Air expels during the opening and closing process, as is normal. Once the step is locked into place, either open or closed, it stops. However, when the step hangs up (partially open) air continues to expel from what I believe to be the step solenoid valve. In particular the escaping air is coming from one of the two 'spark plug shaped' devices on the bottom of the valve. Advice appreciated ... and if someone could give me the proper name of the 'spark plug shaped' devices, that too, would be appreciated. Roger Webb 91 WL Cedar Rapids, IA [Non-text portions of this message have been removed] |
03-11-2007, 12:18
Roger,
Those are adjustable pressure valves to regulate the air flow in & out. You can take them out & clean them & reinstall. Sounds like you have some obstruction in one that is preventing the correct volume of air flow and shut off or it has moved out of position. Terry Neal Bozeman, MT 82PT40 74FC34 rogerwwebb wrote: > My air step is hanging up during extension (opening) and is not fully > extending without 'help' from my foot, shaking the step a bit. No > problem with retraction (closing). > > Lubricating all pivot points did not help. > > Air expels during the opening and closing process, as is normal. Once > the step is locked into place, either open or closed, it stops. > > However, when the step hangs up (partially open) air continues to expel > from what I believe to be the step solenoid valve. In particular the > escaping air is coming from one of the two 'spark plug shaped' devices > on the bottom of the valve. > > Advice appreciated ... and if someone could give me the proper name of > the 'spark plug shaped' devices, that too, would be appreciated. > > Roger Webb > 91 WL > Cedar Rapids, IA > > |
03-11-2007, 13:52
When i have been in freezing temps- seems like the last 2 months~ my step would
operate- but expel air in the retract position. Upon driving in warmer temps, the step does not expel air. Ernie Ekberg 83PT40 Livingston,Montana "POO-DOO-EXPRESS" ----- Original Message ----- From: smquandt To: WanderlodgeForum@yahoogroups.com Sent: Sunday, March 11, 2007 4:07 PM Subject: RE: [WanderlodgeForum] Air Step problem - will not completely extend without 'help' Roger I had a similar problem, except mine would not retract. I talked to Kenny Rodgers at Coach Craft, was arranging replacement of Primus, he said that the step valve is the lowest part of the air system and any water that accumulates will go there. His suggestions, and it worked for me, was to remove the inbound airline, purge, put some WD-40 in the line, reattach then operate the step many times to expel any water remaining. When it WARMS UP I am going to put a small separator on that line to prevent the problem. Steve Quandt Iron Mountain MI 1993-PT40 -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of rogerwwebb Sent: Sunday, March 11, 2007 4:53 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Air Step problem - will not completely extend without 'help' My air step is hanging up during extension (opening) and is not fully extending without 'help' from my foot, shaking the step a bit. No problem with retraction (closing). Lubricating all pivot points did not help. Air expels during the opening and closing process, as is normal. Once the step is locked into place, either open or closed, it stops. However, when the step hangs up (partially open) air continues to expel from what I believe to be the step solenoid valve. In particular the escaping air is coming from one of the two 'spark plug shaped' devices on the bottom of the valve. Advice appreciated ... and if someone could give me the proper name of the 'spark plug shaped' devices, that too, would be appreciated. Roger Webb 91 WL Cedar Rapids, IA [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
03-11-2007, 14:46
I had the same prob as a symtom to a bad seal in the ram. When
I would tug the step fully open the air hissing would stop. (My 94pt40 has a non spring ram with two air ports) If you remove the ram and blow air in, to push the stroke out , the air should stop blowing out the other port when the stroke bottoms out. if the air continues to blow out the other port the seal is bad in the ram. You may be able to remove both airlines to the ram and test it without removing the ram first. I tried to split the ram open to replace the seal but the Clippar ram used on my bus could not be serviced. The step cams open and does not require pressure to hold it open. The ram is duel acting (pushForce pullForce). To open; one valve pushes air into the ram thus pushing the stroke out. The other valve escapes the air as exhaust. The only exhaust on a new ram is the content of the unopen ram. what you hear is air passing the plundger seal in the bad ram and adding to the exhaust. The movement of the step hindge just before the step cams to an open rest require the most ram force. Your ram may have been wearing out over time and now it has too much blowby to pass the cam and lock the step out. Clippard.com has an online store and I think the exact replacement for my bus was around $200.????? The last two numbers on the Bad ram were SP or somthing like that which turned out to be special order and not important. I upgraded the seal within the ram for $35.00??? to a "V" which stands for the name of the rubber compound used to make the seal. The fix is easy but take care not to lose a finger in a surprise step movement. I think moisture in the ram freezeup and cut the plundger seal and or dirt gets in through the wiper seal at the strope end????? GregoryO'Connor 94PTRomolandCa Gregory O'Connor 94PT40 Romoland California --- In WanderlodgeForum@yahoogroups.com, "rogerwwebb" > > My air step is hanging up during extension (opening) and is not fully > extending without 'help' from my foot, shaking the step a bit. No > problem with retraction (closing). > > Lubricating all pivot points did not help. > > Air expels during the opening and closing process, as is normal. Once > the step is locked into place, either open or closed, it stops. > > However, when the step hangs up (partially open) air continues to expel > from what I believe to be the step solenoid valve. In particular the > escaping air is coming from one of the two 'spark plug shaped' devices > on the bottom of the valve. > > Advice appreciated ... and if someone could give me the proper name of > the 'spark plug shaped' devices, that too, would be appreciated. > > Roger Webb > 91 WL > Cedar Rapids, IA > |
03-11-2007, 14:51
Are all Wanderlodge steps supposed to lock in the 'out' position. Mine comes
out when aired up, but if parked, once the air pressure drops, step becomes limp and flops around. Where would I find the mechanism which holds it out? I took a quick look under there once and couldn't see any obvious locking mechanism. Kerry 82 Fc 35 Denver |
03-11-2007, 15:05
> > Are all Wanderlodge steps supposed to lock in the 'out' position. Mine comes out when aired > up, but if parked, once the air pressure drops, step becomes limp and flops around. Where > would I find the mechanism which holds it out? I took a quick look under there once and > couldn't see any obvious locking mechanism. > > Kerry > 82 Fc 35 > Denver > My step locks when open and once the air pressure drops it will open automatically and lock in the open position. Roger Webb 91WL Cedar Rapids, IA |
03-11-2007, 15:13
When the air pressure drops off, the step comes out and locks in the
extended position. There's a switch on the dash (at least in my coach) that will also set the step to be extended so long as the engine is off. If the engine is running, and the door is closed, the step will retract once air pressure is about about 85 lbs (no matter where the dash-switch is set). Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Mar 11, 2007, at 6:51 PM, davidkerryedwards wrote: > Are all Wanderlodge steps supposed to lock in the 'out' position. > Mine comes out when aired > up, but if parked, once the air pressure drops, step becomes limp > and flops around. Where > would I find the mechanism which holds it out? I took a quick look > under there once and > couldn't see any obvious locking mechanism. > > Kerry > 82 Fc 35 > Denver [Non-text portions of this message have been removed] |
03-11-2007, 15:18
Look right under the step where the ram connects. It is a simple mechanism,
latches with a spring and unlatches when the ram pulls on it to retract. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards Sent: Sunday, March 11, 2007 7:52 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Air Step problem - will not completely extend without 'help' Are all Wanderlodge steps supposed to lock in the 'out' position. Mine comes out when aired up, but if parked, once the air pressure drops, step becomes limp and flops around. Where would I find the mechanism which holds it out? I took a quick look under there once and couldn't see any obvious locking mechanism. Kerry 82 Fc 35 Denver [Non-text portions of this message have been removed] |
03-11-2007, 17:01
Kerry:
On an 83, I noticed that it is a mechanical linkage that locks the step in the open position. It is a spring activated mechanism, and when the cylinder retracts the step, it unlocks the mechanism first. On my 84, I have two air cylinders, one that locks the step in place when extended, and one for extending/retracting Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: davidkerryedwards To: WanderlodgeForum@yahoogroups.com Sent: Sunday, March 11, 2007 6:51:59 PM Subject: [WanderlodgeForum] Re: Air Step problem - will not completely extend without 'help' Are all Wanderlodge steps supposed to lock in the 'out' position. Mine comes out when aired up, but if parked, once the air pressure drops, step becomes limp and flops around. Where would I find the mechanism which holds it out? I took a quick look under there once and couldn't see any obvious locking mechanism. Kerry 82 Fc 35 Denver <!-- #ygrp-mlmsg {font-size:13px;font-family:arial,helvetica,clean,sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial,helvetica,clean,sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0; } #ygrp-tpmsgs{ font-family:Arial; clear:both; } #ygrp-vitnav{ padding-top:10px; font-family:Verdana; font-size:77%; margin:0; } #ygrp-vitnav a{ padding:0 1px; } #ygrp-actbar{ clear:both; margin:25px 0; white-space:nowrap; color:#666; text-align:right; } #ygrp-actbar .left{ float:left; white-space:nowrap; } .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana; font-size:77%; padding:15px 0; } #ygrp-ft{ font-family:verdana; font-size:77%; border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px; } #ygrp-vital{ background-color:#e0ecee; margin-bottom:20px; padding:2px 0 8px 8px; } #ygrp-vital #vithd{ font-size:77%; font-family:Verdana; font-weight:bold; color:#333; text-transform:uppercase; } #ygrp-vital ul{ padding:0; margin:2px 0; } #ygrp-vital ul li{ list-style-type:none; clear:both; border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold; color:#ff7900; float:right; width:2em; text-align:right; padding-right:.5em; } #ygrp-vital ul li .cat{ font-weight:bold; } #ygrp-vital a { text-decoration:none; } #ygrp-vital a:hover{ text-decoration:underline; } #ygrp-sponsor #hd{ color:#999; font-size:77%; } #ygrp-sponsor #ov{ padding:6px 13px; background-color:#e0ecee; margin-bottom:20px; } #ygrp-sponsor #ov ul{ padding:0 0 0 8px; margin:0; } #ygrp-sponsor #ov li{ list-style-type:square; padding:6px 0; font-size:77%; } #ygrp-sponsor #ov li a{ text-decoration:none; font-size:130%; } #ygrp-sponsor #nc { background-color:#eee; margin-bottom:20px; padding:0 8px; } #ygrp-sponsor .ad{ padding:8px 0; } #ygrp-sponsor .ad #hd1{ font-family:Arial; font-weight:bold; color:#628c2a; font-size:100%; line-height:122%; } #ygrp-sponsor .ad a{ text-decoration:none; } #ygrp-sponsor .ad a:hover{ text-decoration:underline; } #ygrp-sponsor .ad p{ margin:0; } o {font-size:0;} .MsoNormal { margin:0 0 0 0; } #ygrp-text tt{ font-size:120%; } blockquote{margin:0 0 0 4px;} .replbq {margin:4;} --> __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
