Backup Camera Cables
04-28-2005, 03:05
I hafta pull some wires the length of our bus behind the overheads and
would like to pull in what I need for a camera at the same time. (This
bus didn't have a factory camera installed.)
What kind of cabling do I need? I'm sitting on a bunch of coaxial RG62
cable with BNC connectors. Is that impedance close enough for a 35'
run? Also, does the camera need a 12v power cable also?
Thanks in advance.
Bob Griesel '84 FC31 WLII WA
04-28-2005, 03:20
The RG-62 with a standard BNC's should work, I would test it before
installing it by doing a temporary connection with about 50-foot of it
directly to the TV.
You will also need an ignition-switched 12-volt signal wire.
Good luck,
Tim Hannink
Winter Park, FL
1981 FC-33SB
--- In WanderlodgeForum@yahoogroups.com, "freewill2008"
(This
RG62
> Thanks in advance.
04-28-2005, 03:44
Tim I would not use RG62 since it is a 93 ohm cable. You should use RG6
which is 75 ohms. Also make sure that the cable you buy has a good inner
braided shield to eliminate interference from getting on the cable.
Tom
1982 FC35
Vernon Center,NY
In the beautiful Mohawk Valley
>directly to the TV.
>Good luck,
>Tim Hannink
>Winter Park, FL
>1981 FC-33SB
>and
>(This
>RG62
> > Thanks in advance.
>Yahoo! Groups Links
anderlodgeForum/
Wanderl\
04-28-2005, 04:22
If I were going out and buying cable for this, I would recommend an
RG-6 also, but since he has the RG-62 already, the run is under 50-
feet and he can pre-test it before installing it, I don't see any
problem with trying it. Worst case, it doesn't work and he has to go
buy some RG-59/6.
I have some extra RG-6 at home, I just ran two runs to the roof for
a satellite dish connection. Let me know if you need any.
Good luck,
Tim Hannink
Winter Park, FL
1981 FC-33SB
use RG6
inner
> Tom
> 1982 FC35
> Vernon Center,NY
before
of it
> >directly to the TV.
> >Good luck,
> >Tim Hannink
> >Winter Park, FL
> >1981 FC-33SB
overheads
> >and
time.
> >(This
coaxial
> >RG62
a 35'
> > > Thanks in advance.
> >Yahoo! Groups Links
> > subject=Unsubscribe>WanderlodgeForum-unsubscribe@yahoogroups.com
05-18-2005, 07:52
Depends on the camera, and you need 12 volt power...use a relay and tap
into the bus
in the back ceiling.....also, use a 4' length of electric fence post to run
the wires.
quarter inch diameter and non conductive fiberglass, make's it much easier..
>Thanks in advance.
>Yahoo! Groups Links
anderlodgeForum/
Wanderl\
