Combination Safe
03-14-2007, 15:58
Combination Safe
Where is the safe in a 1990 Bluebird? Thank you.
03-14-2007, 16:50
Combination Safe
Since the interior of models varies greatly, the location would also have to
vary. In mine, with an L-Shaped dinette, it is under the seat cushion nearest the refrigerator. On 3/15/2007 at 2:58 AM abcdemolay wrote: >Where is the safe in a 1990 Bluebird? Thank you. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA |
03-14-2007, 17:22
Combination Safe
Same place in the '92 with L-Shaped dinette. Just lift up the cushion
and remove the small filler panel. --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > Since the interior of models varies greatly, the location would also have to vary. In mine, with an L-Shaped dinette, it is under the seat cushion nearest the refrigerator. > > On 3/15/2007 at 2:58 AM abcdemolay wrote: > > >Where is the safe in a 1990 Bluebird? Thank you. > > Don Bradner > 90 PT40 "Blue Thunder" > Eureka, CA > |
03-14-2007, 18:10
Combination Safe
Thank you. Mine must have been removed, however, there is no sign
of any bolts or other tie down. Is your safe just fee-standing? --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@...> wrote: > > Same place in the '92 with L-Shaped dinette. Just lift up the cushion > and remove the small filler panel. > > --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > > > > Since the interior of models varies greatly, the location would also > have to vary. In mine, with an L-Shaped dinette, it is under the seat > cushion nearest the refrigerator. > > > > On 3/15/2007 at 2:58 AM abcdemolay wrote: > > > > >Where is the safe in a 1990 Bluebird? Thank you. > > > > Don Bradner > > 90 PT40 "Blue Thunder" > > Eureka, CA > > > |
03-15-2007, 00:28
Combination Safe
I believe that the safes have always been an option (although most BB's have
them). There is a chance that you don't even have one, but it's always fun to explore. Typically, like most have posted, the safe is located underneath a dinette cushion, underneath a removable wooden panel with a finger hole in it. I have a safe, it's neat to show to people, but I've never been able to get it open in the 6yrs I've owned it (and I have tried the usual "factory set combo's" to no avail). Could have some big bucks in it, or that elusive Hope Diamond in it...maybe I'll raise the price when I sell, just in case!! Have fun hunting.... Kevin McKeown Yorba Linda, CA 1986 38' PT ************************************** AOL now offers free email to everyone. Find out more about what's free from AOL at http://www.aol.com. [Non-text portions of this message have been removed] |
03-15-2007, 02:16
Combination Safe
Mine is under the sofa in the J section. Pull the cushion, wood panel and its
there. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Nivecille, FL ----- Original Message ----- From: mbrund To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, March 14, 2007 10:22 PM Subject: [WanderlodgeForum] Re: Combination Safe Same place in the '92 with L-Shaped dinette. Just lift up the cushion and remove the small filler panel. --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > Since the interior of models varies greatly, the location would also have to vary. In mine, with an L-Shaped dinette, it is under the seat cushion nearest the refrigerator. > > On 3/15/2007 at 2:58 AM abcdemolay wrote: > > >Where is the safe in a 1990 Bluebird? Thank you. > > Don Bradner > 90 PT40 "Blue Thunder" > Eureka, CA > [Non-text portions of this message have been removed] |
03-15-2007, 06:32
Combination Safe
Note that not all BBs have a safe (mine doesn't).
If the safe is "freestanding" then is was probably removed.... Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Mar 14, 2007, at 10:10 PM, abcdemolay wrote: > Thank you. Mine must have been removed, however, there is no sign > of any bolts or other tie down. Is your safe just fee-standing? > [Non-text portions of this message have been removed] |
03-15-2007, 08:13
Combination Safe
Is the hatch and hole for the safe there? Mine is bolted down using bolts that
need to have the safe open to easily remove. If the hatch and hole are there, but no sign that bolts went into the floor I would guess that there never was one. On 3/15/2007 at 5:10 AM abcdemolay wrote: >Thank you. Mine must have been removed, however, there is no sign >of any bolts or other tie down. Is your safe just fee-standing? Don Bradner 90 PT40 "Blue Thunder" Eureka, CA |
