Fuel gauge trouble
03-14-2007, 07:11
Fuel gauge trouble
Can anyone explain the resistor on the back side of the fuel gauge?.
My fuel gauge was relaaced along with the sending unit in the tank. Since that
time the gauge
reads backwards and very inaccurate. I have triple checked the wires, ground,
ignition,and
sending unit, checked the ignition for power it was ok, the ground was good. I
even ran an
external wire to the tank with the sending unit pulled out and operated outside
of the tank
the guage shows full when float is full down. When lifted it goes to empty, I
noticed there was
continunity amongst all of the connectors, I removed the resistor and for some
reason the
guage now reads 1/2 which is close as measured off of a yard stick.
Any of your vast knowledge would be appreciated to help me fix this Pain,
Thanks
John
1984 RB 35'
03-14-2007, 07:34
Fuel gauge trouble
I don't know what the unit looks like but if it has a ground and one wire it
sounds like the float might be assembled upside down. Is it possible to
assemble that way? Sounds crazy but I have done that in a boat tank before.
Leroy Ekert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Wednesday, March 14, 2007 12:11 PM
Subject: [WanderlodgeForum] Fuel gauge trouble
time the gauge
ignition,and
even ran an
outside of the tank
noticed there was
reason the
Thanks
John
1984 RB 35'
03-14-2007, 08:01
Fuel gauge trouble
I did not see two wires going to the sending unit, just the one going to the
center of (and only) the connection of the unit. Any idea it works without
the resistor?
thanks
john
1984 RB 35'
>From: "Leroy Eckert"
>To:
>Subject: Re: [WanderlodgeForum] Fuel gauge trouble
>Date: Wed, 14 Mar 2007 12:34:59 -0600
>it sounds like the float might be assembled upside down. Is it possible to
>before.
>Leroy Ekert
>Niceville, FL
> From: jrm1486
>Since that time the gauge
>ground, ignition,and
>good. I even ran an
>outside of the tank
>empty, I noticed there was
>for some reason the
>Pain,
> Thanks
> John
> 1984 RB 35'
Get a FREE Web site, company branded e-mail and more from Microsoft Office
Live! http://clk.atdmt.com/MRT/go/mcrssaub0050...direct/01/
03-14-2007, 08:24
Fuel gauge trouble
Hi John:
The resistor is usually used to balance the gauge and sender and match the
ohms needed for the gauge.
It sounds like the ground and hot are reversed on one end or the other. It
should not hurt anything to replace the resistor, pull the sending unit and
reverse the ground and hot and see what your gauge does.
Safe travels,
'84 FC35 Duncan, Oklahoma
Ralph's RV Solutions
>that time the gauge
>good. I even ran an
>outside of the tank
>some reason the
>Thanks
>John
>1984 RB 35'
03-14-2007, 08:52
Fuel gauge trouble
If you have one wire in the center, sending wire to the gauge , the float must
ground to the tank.. Typically, 80% of the time, you can eliminate the gauge
circuit by removing the sender line from the float and the gauge should read
empty. If you ground the same wire it should read full. I'm not sure about that
resistor on the back of the gauge unless it is used to mate the gauge to the
sender.
If the gauge circuit is eliminated, that float has to be screwed up some how.
Leroy Eckert
Niceville, FL
Sent: Wednesday, March 14, 2007 1:01 PM
the resistor?
thanks
john
1984 RB 35'
>To:
>before.
>Leroy Ekert
>Niceville, FL
> From: jrm1486
>good. I even ran an
>outside of the tank
>for some reason the
>Pain,
> Thanks
> John
> 1984 RB 35'
03-14-2007, 09:10
Fuel gauge trouble
Leroy:
Sounds like you have hit the nail on the head, that would certainly explain it.
Safe travels,
>to assemble that way? Sounds crazy but I have done that in a boat tank before.
>Leroy Ekert
>Niceville, FL
> From: jrm1486
> good. I even ran an
> outside of the tank
> for some reason the
> Thanks
> John
> 1984 RB 35'
03-14-2007, 16:07
Fuel gauge trouble
Leroy. I'd leave it alone. Think about it, you're producing fuel, while you're
driving, maybe you can sell some off.(jk). If I were to take a guess, I'd say
the guage was wired backwards, sending the current, the wrong way.You'll have to
isolate the circut. You should be able to remove the wire, from the sender,(key
off), then turn the key on, and ground the wire. The guage should read full. If
it does, the guage is ok, the problem should be in the sending unit. If it
dosen't, I'd take another look at how that guage was wired. That's the way to
troubleshoot 99% of them, maybe Bluebird is different, so you may want to get a
second opinion. I tried to email you, but my message was returned, Good luck,
Jimmy
Leroy Eckert wrote: I don't know what the unit
looks like but if it has a ground and one wire it sounds like the float might be
assembled upside down. Is it possible to assemble that way? Sounds crazy but I
Leroy Ekert
Niceville, FL
time the gauge
ignition,and
even ran an
of the tank
noticed there was
reason the
Thanks
John
1984 RB 35'
TV dinner still cooling?
Check out "Tonight's Picks" on Yahoo! TV.
03-15-2007, 02:30
Fuel gauge trouble
Yeah really.. I sent a second response as you say, ground the wire and check
the guage circuit.
So now my e-mail is being returned. I is a crazy electronic world.
jwasnewski@...
Thanks
Leroy Eckert
Niceville, FL
03-15-2007, 04:23
Fuel gauge trouble
---My fuel gage is pegged to the right with the engine running...any
suggestions....
Regards & LOL
Hank Hannigan
90SP36
In WanderlodgeForum@yahoogroups.com, "Leroy Eckert"
wire and check the guage circuit.
world. jwasnewski@...
> Thanks
> Leroy Eckert
> Niceville, FL
03-15-2007, 04:52
Fuel gauge trouble
Yes, I believe your engine fuel system is bypassing more fuel than the engine
uses resulting in a full tank. It is like buying widgets for fifty cents each
and selling them for a quarter. You have the opportunity to pile them high,
sell them cheap and make up the difference in volume sales. Lol. I would not
believe anything about this post. lol.
I hope all is well in Vegas. How was the race? JJ did it again.
Leroy Eckert
Niceville, FL
Sent: Thursday, March 15, 2007 9:23 AM
Subject: [WanderlodgeForum] Re: Fuel gauge trouble
suggestions....
Regards & LOL
Hank Hannigan
90SP36
> Thanks
> Leroy Eckert
> Niceville, FL
