Rear End
03-14-2007, 16:40
Rear End
I know there has been some discussion before about changing rear end ratios.
I would like to hear from any one who has changed out the rear end of a BB with a 210NA to something other than the 5:29. (4:88, 4:65, 4:63, or?) I'm not as interested in high speeds as being able to cruise 60-65 with out running the CAT so fast. We do go the San Diego across I8 and to Prescott up I17. I just don't want to get into a situation where we stall or overheat the Allison. Any experiences would be appreciated. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX [Non-text portions of this message have been removed] |
03-15-2007, 09:39
Rear End
Hi Chuck,
I previously had a 1978 with a 210NA. I had the rear changed to 4:88. If I remember correctly the top end increased about 8 mph. But more importantly, I liked to cruise around 60 to 62 mph and the reduction in rpm (don't remember exactly how much)and the noise level was significantly reduced. I was very happy with the change and think that a change to 4:63 might have even been better, but I don't know. The coach is owned by Gardner now, maybe he'll chime in? Tom Sorrentino 1987 PT38 Bedford Hills, NY --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > I know there has been some discussion before about changing rear end ratios. > I would like to hear from any one who has changed out the rear end of a BB > with a 210NA to something other than the 5:29. (4:88, 4:65, 4:63, or?) I'm > not as interested in high speeds as being able to cruise 60-65 with out > running the CAT so fast. We do go the San Diego across I8 and to Prescott > up I17. I just don't want to get into a situation where we stall or > overheat the Allison. Any experiences would be appreciated. > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > > > > > > [Non-text portions of this message have been removed] > |
03-15-2007, 12:01
Rear End
I can see one possible drawback in changing the rear end ratio. Coming out of
Palo Duro Canyon with my 82 FC (10% grade as I recall), was quite a pull. 1st gear the whole way and down to about 1850rpms. With a higher gear ratio (I think I have the 5.29) that pull might have become touch and go. Kerry 82 Fc 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > Thanks Tom! Gardner do you have any thoughts since you now own this coach? > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > |
03-15-2007, 12:03
Rear End
- Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of thomas_sorrentino Sent: Thursday, March 15, 2007 2:40 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Rear End Hi Chuck, I previously had a 1978 with a 210NA. I had the rear changed to 4:88. If I remember correctly the top end increased about 8 mph. But more importantly, I liked to cruise around 60 to 62 mph and the reduction in rpm (don't remember exactly how much)and the noise level was significantly reduced. I was very happy with the change and think that a change to 4:63 might have even been better, but I don't know. The coach is owned by Gardner now, maybe he'll chime in? Tom Sorrentino 1987 PT38 Bedford Hills, NY --- In WanderlodgeForum@ yahoogroups.com, "Chuck Wheeler" > > I know there has been some discussion before about changing rear end ratios. > I would like to hear from any one who has changed out the rear end of a BB > with a 210NA to something other than the 5:29. (4:88, 4:65, 4:63, or?) I'm > not as interested in high speeds as being able to cruise 60-65 with out > running the CAT so fast. We do go the San Diego across I8 and to Prescott > up I17. I just don't want to get into a situation where we stall or > overheat the Allison. Any experiences would be appreciated. > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
03-15-2007, 12:23
Rear End
i run a 4.44 in my old 81 na fc rb
it made it a lot more user friendly IMO and i like to run 70 so it worked in my case. i like to flow with traffic not be a stoppping point. woody 81 fcrb for sale little rock arkansas 90 sp --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > Hi Chuck, > > I previously had a 1978 with a 210NA. I had the rear changed to 4:88. > If I remember correctly the top end increased about 8 mph. But more > importantly, I liked to cruise around 60 to 62 mph and the reduction > in rpm (don't remember exactly how much)and the noise level was > significantly reduced. I was very happy with the change and think > that a change to 4:63 might have even been better, but I don't know. > The coach is owned by Gardner now, maybe he'll chime in? > > Tom Sorrentino > 1987 PT38 > Bedford Hills, NY > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > > > > I know there has been some discussion before about changing rear > end ratios. > > I would like to hear from any one who has changed out the rear end > of a BB > > with a 210NA to something other than the 5:29. (4:88, 4:65, 4:63, > or?) I'm > > not as interested in high speeds as being able to cruise 60-65 with > out > > running the CAT so fast. We do go the San Diego across I8 and to > Prescott > > up I17. I just don't want to get into a situation where we stall or > > overheat the Allison. Any experiences would be appreciated. > > > > > > > > - Chuck Wheeler - > > > > 82 FC 31 SB > > > > Fort Worth, TX > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
03-15-2007, 15:08
Rear End
Chuck;
Since I have never experienced anything other than the 4.88, I don't have a real opinion. But from other posts and my experience I think I wouldn't want to go any lower in the ratio. I get a sufficient top speed around 65 or so, and often drop into the 40s climbing normal long grades towing a 1995 Jeep Cherokee sport. Let's face it, a 210 NA ain't no rocket. But as I said, I have no other experience so I could be way off base here. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > Thanks Tom! Gardner do you have any thoughts since you now own this coach? > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of thomas_sorrentino > Sent: Thursday, March 15, 2007 2:40 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Rear End > > > > Hi Chuck, > > I previously had a 1978 with a 210NA. I had the rear changed to 4:88. > If I remember correctly the top end increased about 8 mph. But more > importantly, I liked to cruise around 60 to 62 mph and the reduction > in rpm (don't remember exactly how much)and the noise level was > significantly reduced. I was very happy with the change and think > that a change to 4:63 might have even been better, but I don't know. > The coach is owned by Gardner now, maybe he'll chime in? > > Tom Sorrentino > 1987 PT38 > Bedford Hills, NY > > --- In WanderlodgeForum@ > yahoogroups.com, "Chuck Wheeler" > > > > > I know there has been some discussion before about changing rear > end ratios. > > I would like to hear from any one who has changed out the rear end > of a BB > > with a 210NA to something other than the 5:29. (4:88, 4:65, 4:63, > or?) I'm > > not as interested in high speeds as being able to cruise 60-65 with > out > > running the CAT so fast. We do go the San Diego across I8 and to > Prescott > > up I17. I just don't want to get into a situation where we stall or > > overheat the Allison. Any experiences would be appreciated. > > > > > > > > - Chuck Wheeler - > > > > 82 FC 31 SB > > > > Fort Worth, TX > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > |
03-15-2007, 16:02
Rear End
That's why I went with an auxiliary OD trans.
MH ----- Original Message ----- From: davidkerryedwards To: WanderlodgeForum@yahoogroups.com Sent: Thursday, March 15, 2007 5:01 PM Subject: [WanderlodgeForum] Re: Rear End I can see one possible drawback in changing the rear end ratio. Coming out of Palo Duro Canyon with my 82 FC (10% grade as I recall), was quite a pull. 1st gear the whole way and down to about 1850rpms. With a higher gear ratio (I think I have the 5.29) that pull might have become touch and go. Kerry 82 Fc 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > Thanks Tom! Gardner do you have any thoughts since you now own this coach? > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > [Non-text portions of this message have been removed] |
03-15-2007, 17:27
Rear End
I have a factory 4.89 in my 83' FC 35SB and it runs 67mph per GPS at
about 2600rpm. For me that is pretty good, I can avoid being a major bottle neck for traffic and still have pulling power on the hills. We took some steep passes in Mexico above 6000ft and were pleased with the climbing performance. Thomas Eastham Houston, TX 83' FC35SB 84' FC33SB (parts unit) [Non-text portions of this message have been removed] |
03-15-2007, 19:23
Rear End
Hello Tom, Would you send your email address to gnburke@... . I have a
few questions about your rear gear change in your former 1978 BB. Thanks George Burke 1977 FC31 Charlotte ----- Original Message ----- From: thomas_sorrentino To: WanderlodgeForum@yahoogroups.com Sent: Thursday, March 15, 2007 4:39 PM Subject: [WanderlodgeForum] Re: Rear End Hi Chuck, I previously had a 1978 with a 210NA. I had the rear changed to 4:88. If I remember correctly the top end increased about 8 mph. But more importantly, I liked to cruise around 60 to 62 mph and the reduction in rpm (don't remember exactly how much)and the noise level was significantly reduced. I was very happy with the change and think that a change to 4:63 might have even been better, but I don't know. The coach is owned by Gardner now, maybe he'll chime in? Tom Sorrentino 1987 PT38 Bedford Hills, NY --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > I know there has been some discussion before about changing rear end ratios. > I would like to hear from any one who has changed out the rear end of a BB > with a 210NA to something other than the 5:29. (4:88, 4:65, 4:63, or?) I'm > not as interested in high speeds as being able to cruise 60-65 with out > running the CAT so fast. We do go the San Diego across I8 and to Prescott > up I17. I just don't want to get into a situation where we stall or > overheat the Allison. Any experiences would be appreciated. > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
03-16-2007, 02:40
Rear End
How does the price compare between changing out the gears and a auxilliary OD
trans? Kerry 82 Fc 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > That's why I went with an auxiliary OD trans. > MH > ----- Original Message ----- > From: davidkerryedwards > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, March 15, 2007 5:01 PM > Subject: [WanderlodgeForum] Re: Rear End > > > I can see one possible drawback in changing the rear end ratio. Coming out of Palo Duro > Canyon with my 82 FC (10% grade as I recall), was quite a pull. 1st gear the whole way and > down to about 1850rpms. With a higher gear ratio (I think I have the 5.29) that pull might > have become touch and go. > > Kerry > 82 Fc 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > > > Thanks Tom! Gardner do you have any thoughts since you now own this coach? > > > > > > > > - Chuck Wheeler - > > > > 82 FC 31 SB > > > > Fort Worth, TX > > > > > > > > [Non-text portions of this message have been removed] > |
