headlamp assemblies
03-28-2007, 11:58
headlamp assemblies
I usually use a very special compund to polish lens
Crest toothpaste the old green stuff and a buffer works great Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > I failed to mention that I used the headlight refinishing product and they were definately better and was pleased completely but after a summer in the desert the last finishing chemical that was applied turned into little flakes and made the lamps have a crackle finish. I tried sanding and polishing them again with a little success,but the pits from the sand and rock chips made it impossible to refinish to satisfaction.That is the reason for replacement.Desert living does that to these front ends.When I get them changed, I will use the 3M film to protect them,maybe. > The lamps are 88-91 F150 and Bronco. > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > > [Non-text portions of this message have been removed] > |
03-28-2007, 11:58
headlamp assemblies
