Alternators Rebuilt
04-01-2007, 09:56
Alternators Rebuilt
My 94Pt has the same symptoms. center position reads but either side
has no reading. I have no idea if my alts put out other then I have
full 13+v on the 11 batteries when I stop. It would be a nice option
to have working proper.
Inverter camping this weekend in the desert, I noticed the leg one
and two volts and amp gauges have no reading at all????. Is it normal
for a 94'ishPt to have the inverter power not show up on the gauges?
GregoryO'Connor
94PT RomolandCa
> Well: I checked out the (6) relays and all of them function
> correctly, so the problem has to be before the relays, like a
circuit
> breaker or could be at the switch. I'll keep looking.
> I can send you the schematic later today, when I have a minute
to
> scan it.
> R.E. (Ron) Marabito, Dallas, TX 92WB40
> --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert"
> > Mine does the same thing. It is one of two squawk items I have
> has been on the list for three years. I have chased the ghost
before
> but without a schematic. I finally unplugged my fault light.
> Everthing has been fine but I need to check the alternators with a
> multi-meter periodically.
> > A while back someone, I think Don Bradner, had a similar problem
> with alternators and the crazy switch readings. As I recall,
someone
> else, perhaps the prior owner of his coach stated that the switch
did
> not work properly because the alternators were not perfectly matched
> up or something like that, and BB installed some kind of delay
> wiring. I do not recall seeing a post as to the final results.
> Perhaps he can let us know.
> > Could I get a copy of your schematic?
> > Leroy Eckert
> > 1990 WB-40"Smoke N Mirrors"
> > Niceville, FL
> > ----- Original Message -----
> > From: ronmarabito2002
> > To: WanderlodgeForum@yahoogroups.com
> > Sent: Saturday, March 31, 2007 10:47 PM
> > Subject: [WanderlodgeForum] Re: Alternators Rebuilt
> > I have the wiring diagram showing these 6 relays. Sure seems
> > over-engineered to me.
> > --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@>
> > > I have the same issue, they would fine when in the center
position,
> > > but when I try 1 or 2 I get no reading. I do not think there
is
> > > anything wrong, but it is on my list of things to look into
some
> day.
> > > Michael Brundridge
> > > 1992 WB40 - newbie
> > > Georgetown, TX
> > > wrote:
> > > > Just had my alternators rebuilt and I installed them today.
> > > The
> > > > last unit went out after 1400 miles and we suspected all
kinds of
> > > > things could have caused it, but it turned out to be very
simple,
> > > but
> > > > probably a one in a million possibility.
> > > > After I removed the unit, I found a short between a diode
> > > the
> > > > case, which was caused by some unknown object flying up
onto the
> > > back
> > > > of the alternator and selding them together. Unfortunately,
I
> > > could
> > > > not determine what it was, since it was melted. At first I
> thought
> > > the
> > > > battery cable might have touched the case, but it did not.
Had it
> > > > done so, it would have been welded in place and insulation
around
> > > the
> > > > terminal would have melted.
> > > > I get amp readings with the switch in the neutral position
> > > only.
> > > > When I switch to 1 or 2, I don't get an amp reading. I plan
to
> > > remove
> > > > the six relays tomorrow that control the ammeter readings
and the
> > > > fault light. I might also pull the switch and see if I have
good
> > > > connections and contacts.
> > > > I'll let you all know what I find.
> > [Non-text portions of this message have been removed]
04-01-2007, 10:07
Alternators Rebuilt
Don:
I cannot see the fault light on the schematic. Is it on there? If not, do you
have any further details on this fault light, where it is located etc.
Thanks
Terrace, B.C. Canada
Sent: Sunday, April 1, 2007 9:24:35 AM
Subject: Re: [WanderlodgeForum] Re: Alternators Rebuilt
The delay is on the fault light. The switch worked, but one
alternator had no output, and that was apparently real. After replacing both
alternators with a pair that are identical models I have output in all three
switch positions, and the center position is roughly double what each is showing
separately.
I would not expect to get the fault light, but I haven't driven it long enough
since the alternators were installed to tell. The delay is roughly 30 minutes.
I have uploaded my schematic here: http://www.arcatape t.net/travel/ bluebirds/
Do You Yahoo!?
http://mail.yahoo.com
04-01-2007, 10:16
Alternators Rebuilt
It is labeled "DS3" and is powered from relays K7 and/or K8. On my alternators
there are wires on each to one each of the 3 stator connections - those are
typically thought of as tach outputs, but I don't think the coach gets its tach
readings there, and they are apparently used to keep power to those relays (note
the diode on each). If either loses power, that side of the LED drops to ground
and it lights up.
On 4/1/2007 at 3:07 PM Wilhelmus Schreurs wrote:
>Don:
>you have any further details on this fault light, where it is located etc.
>Thanks
Don Bradner
90 PT40 "Blue Thunder"
Eureka, CA
04-01-2007, 10:23
Alternators Rebuilt
In my bus the leg voltage and the amp usage gauges work when the genset is
running or plugged to shore power. When dry camping on the inverter, the LED
bar graph (Trace Inverter) control panel shows amp usage. Over a period of time
I see the pilot dash battery volt gauge drop, at which time I start the genset
to recharge. Depending on equipment usage I can go 16-36 hours without starting
the genset. I have six 12v house batteries. When the shore power or genset
power is terminated the inverter automatically goes to inverter mode, unless I
shut it off. That is good because the reefer keeps cooling in case of a power
failure, assuming gas is available. My inverter does not supply 110v to the bay
outlets, so the outside entertainment system will only work with shore power or
the genset. Hope this helps. Yours may be different because it is a later
model.
Leroy Eckert
Niceville, FL
Royale Conversion
Sent: Sunday, April 01, 2007 4:56 PM
GregoryO'Connor
94PT RomolandCa
circuit
to
> scan it.
before
someone
did
> > Leroy Eckert
> > Niceville, FL
position,
is
some
> day.
> > > Michael Brundridge
> > > 1992 WB40 - newbie
> > > Georgetown, TX
> > > The
kinds of
simple,
> > > but
> > > the
onto the
> > > back
I
> > > could
> thought
> > > the
Had it
around
> > > the
> > > only.
to
> > > remove
and the
good
04-01-2007, 10:36
Alternators Rebuilt
Thanks Don
Sent: Sunday, April 1, 2007 3:16:46 PM
alternators there are wires on each to one each of the 3 stator connections -
those are typically thought of as tach outputs, but I don't think the coach gets
its tach readings there, and they are apparently used to keep power to those
relays (note the diode on each). If either loses power, that side of the LED
drops to ground and it lights up.
>Don:
>Thanks
Don Bradner
Eureka, CA
#ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;}
#ygrp-mlmsg table {font-size:inherit;font:100%;}
#ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean,
sans-serif;}
#ygrp-mlmsg pre, code {font:115% monospace;}
#ygrp-mlmsg * {line-height:1.22em;}
#ygrp-text{
font-family:Georgia;
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
padding-top:10px;font-family:Verdana;font-size:77%;margin:0;}
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;}
#ygrp-actbar .left{
float:left;white-space:nowrap;}
.bld{font-weight:bold;}
#ygrp-grft{
font-family:Verdana;font-size:77%;padding:15px 0;}
#ygrp-ft{
font-family:verdana;font-size:77%;border-top:1px solid #666;
padding:5px 0;
#ygrp-mlmsg #logo{
padding-bottom:10px;}
#ygrp-vital{
background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;}
#ygrp-vital #vithd{
font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\
ercase;}
#ygrp-vital ul{
padding:0;margin:2px 0;}
#ygrp-vital ul li{
list-style-type:none;clear:both;border:1px solid #e0ecee;
#ygrp-vital ul li .ct{
font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\
ght:.5em;}
#ygrp-vital ul li .cat{
font-weight:bold;}
#ygrp-vital a {
text-decoration:none;}
#ygrp-vital a:hover{
text-decoration:underline;}
#ygrp-sponsor #hd{
color:#999;font-size:77%;}
#ygrp-sponsor #ov{
padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;}
#ygrp-sponsor #ov ul{
padding:0 0 0 8px;margin:0;}
#ygrp-sponsor #ov li{
list-style-type:square;padding:6px 0;font-size:77%;}
#ygrp-sponsor #ov li a{
text-decoration:none;font-size:130%;}
#ygrp-sponsor #nc {
background-color:#eee;margin-bottom:20px;padding:0 8px;}
#ygrp-sponsor .ad{
padding:8px 0;}
#ygrp-sponsor .ad #hd1{
font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\
#ygrp-sponsor .ad a{
#ygrp-sponsor .ad a:hover{
#ygrp-sponsor .ad p{
margin:0;}
o {font-size:0;}
.MsoNormal {
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
blockquote{margin:0 0 0 4px;}
.replbq {margin:4;}
Do You Yahoo!?
04-01-2007, 12:03
Alternators Rebuilt
You won't see anything on the leg-1 or leg-2 gauge ,unless your
running the gen set or plugged in. You should have a excellent idea
of weather or not your alternators are working by just looking at the
engine battery and coach battery gauge's they should be reading about
14 volts. If you don't have a alternator on line they'll go down
quick. Bob 93pt
side
option
normal
gauges?
> GregoryO'Connor
> 94PT RomolandCa
> circuit
minute
> to
> > scan it.
> and
> before
> someone
> did
matched
> > > Leroy Eckert
> > > Niceville, FL
> position,
there
> is
> some
> > day.
> > > > Michael Brundridge
> > > > 1992 WB40 - newbie
> > > > Georgetown, TX
today.
> > > > The
> kinds of
> simple,
> > > > but
> and
> > > > the
> onto the
> > > > back
Unfortunately,
> I
> > > > could
> > thought
> > > > the
not.
> Had it
insulation
> around
> > > > the
position
> > > > only.
plan
> to
> > > > remove
> and the
have
> good
04-02-2007, 08:00
Alternators Rebuilt
Bob,
How do you know what alternator is being used. Or do
they both come on together.
Thanks
Nelson SLinkman 1994 40'
--- Bob & Carol Howald`
> gauge ,unless your
> excellent idea
> just looking at the
> be reading about
> they'll go down
> quick. Bob 93pt
> reads but either
> side
> other then I have
> would be a nice
> option
> noticed the leg one
> all????. Is it
> normal
> up on the
> gauges?
> > GregoryO'Connor
> > 94PT RomolandCa
> "ronmarabito2002"
> them function
> relays, like a
> > circuit
> looking.
> when I have a
> minute
> > to
> > > scan it.
> Eckert"
> squawk items I have
> > and
> chased the ghost
> > before
> fault light.
> alternators with a
> a similar problem
> As I recall,
> > someone
> > did
> not perfectly
> matched
> some kind of delay
> final results.
> > > > Leroy Eckert
> > > > Niceville, FL
> Rebuilt
> relays. Sure seems
> "mbrund" <mbrund@>
> when in the center
> > position,
> do not think
> there
> > is
> things to look into
> > some
> > > day.
> > > > > Michael Brundridge
> > > > > 1992 WB40 - newbie
> > > > > Georgetown, TX
> "ronmarabito2002"
> installed them
> today.
> > > > > The
> we suspected all
> > kinds of
> > simple,
> > > > > but
> > and
> > > > > the
> object flying up
> > onto the
> > > > > back
> together.
> Unfortunately,
> > I
> > > > > could
> melted. At first I
> > > thought
> > > > > the
> case, but it did
> not.
> > Had it
> place and
> insulation
> > around
> > > > > the
> the neutral
> position
> > > > > only.
> amp reading. I
> plan
> > to
> > > > > remove
> ammeter readings
> > and the
> switch and see if I
> have
> > good
=== message truncated ===
____
Never miss an email again!
Yahoo! Toolbar alerts you the instant new Mail arrives.
http://tools.search.yahoo.com/toolbar/features/mail/
04-02-2007, 13:37
Alternators Rebuilt
Nelson: I guess the only way to tell which alternator is actually
generating the most is to check the alternator 1---2 guage. It's my
own personal opinion that this is a worthless instrument. It's not
very reliable, causes lot's of confusion and just is not necessary.As
long as your getting good readings on your house and engine battery
voltage instrument your in good shape. I have always said that if you
want to know which alternator is putting out and how much, go to the
electrical bus on the rear firewall and check it out with a voltage
meter. Do we really drive down the road checking the #1 verses # 2
alternator meter(guage) no, I don't think so. We just look and see if
the batteries are being charged. It work's for me, No need to make
things too complicated. Good to see your post, wondering where you've
been......Bob 93pt, Illinois.....
> Thanks
> > gauge ,unless your
> > excellent idea
> > just looking at the
> > be reading about
> > they'll go down
> > quick. Bob 93pt
> > reads but either
> > side
> > other then I have
> > would be a nice
> > option
> > noticed the leg one
> > all????. Is it
> > normal
> > up on the
> > gauges?
> > > GregoryO'Connor
> > > 94PT RomolandCa
> > "ronmarabito2002"
> > them function
> > relays, like a
> > > circuit
> > looking.
> > when I have a
> > minute
> > > to
> > > > scan it.
> > Eckert"
> > squawk items I have
> > > and
> > chased the ghost
> > > before
> > fault light.
> > alternators with a
> > a similar problem
> > As I recall,
> > > someone
> > > did
> > not perfectly
> > matched
> > some kind of delay
> > final results.
> > > > > Leroy Eckert
> > > > > Niceville, FL
> > Rebuilt
> > relays. Sure seems
> > "mbrund" <mbrund@>
> > when in the center
> > > position,
> > do not think
> > there
> > > is
> > things to look into
> > > some
> > > > day.
> > > > > > Michael Brundridge
> > > > > > 1992 WB40 - newbie
> > > > > > Georgetown, TX
> > "ronmarabito2002"
> > installed them
> > today.
> > > > > > The
> > we suspected all
> > > kinds of
> > > simple,
> > > > > > but
> > > and
> > > > > > the
> > object flying up
> > > onto the
> > > > > > back
> > together.
> > Unfortunately,
> > > I
> > > > > > could
> > melted. At first I
> > > > thought
> > > > > > the
> > case, but it did
> > not.
> > > Had it
> > place and
> > insulation
> > > around
> > > > > > the
> > the neutral
> > position
> > > > > > only.
> > amp reading. I
> > plan
> > > to
> > > > > > remove
> > ammeter readings
> > > and the
> > switch and see if I
> > have
> > > good
______________
