Leaking air when braking
04-02-2007, 07:02
Leroy,
Thanks for the offer of your drawings...I have one here with my blue box,
but thought I'd find someone who once experienced the same, and I hoped to
shortcut the troubleshooting. I'll take a gander at my drawings...thanks
again.
Kevin Mc
YL CA
86 38PT
04-02-2007, 07:14
Coming home from the weekend in my BB last night, I was in some heavy
stop and go traffic, and I kept hearing some hissing of air whenever I
applied the brakes, and watched my air pressure begin to go down
noticibly when the brakes were activated. When I let off the brakes,
the hissing stopped, and the air began to build up normally. The air
sounded like it was somewhere street side, toward the middle or front
part of the bus. It was like an air line to a wheel came off, but the
brakes worked fine. The air got down to around 70 PSI, and after about
5 minutes of this 0-10mph using the brakes only when necessary (big gap
to the car ahead of me) everything return to normal...no more hissing
on braking, pressure built up to around 125-130 PSI and purged from the
dryer, etc, and the rest of the 60 or so miles home were uneventful.
Don't we love these intermittent problems....
Something stuck, and now OK? Something to look for/replace? Since it
is OK now, where should I begin to look? I was afraid of getting stuck
on the So Cal Fwy's when the air got down to 30 PSI and my brake button
popped...ideas??
Kevin McKeown
Yorba Linda, CA
1986 38' PT
04-02-2007, 08:24
--- In WanderlodgeForum@yahoogroups.com, "Kevin McKeown"
> popped...ideas??
> Kevin McKeown
> Yorba Linda, CA
> 1986 38' PT
Probably a blown diaphragm on a brake chamber.
04-02-2007, 09:09
I'm just guessing and telling you what I would do, and I am not totally familiar
with the system.
Based on the symptoms, logically it does not appear anything let go downstream
of an air control valve because it is now normal.
My guess is that some foreign material may have gotten into an air control valve
and was subsequently expelled overboard when the brakes were released. My air
drawings are at the bus or I could look to see how the air flows and exits the
system. To my thinking, and sometimes that is radical, the symptoms indicate an
air control valve or beyond.
I would not do anything now, and that is easy to say because it is not my bus.
You could go on a wild goose chase trying to find out what happened.
Just my logical guess. If you have an air system drawing you should be able to
see how the air gets around. If not, I have one for my 1990 and can supply it
to you later in the week.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Monday, April 02, 2007 2:14 PM
Subject: [WanderlodgeForum] Leaking air when braking
popped...ideas??
Kevin McKeown
Yorba Linda, CA
1986 38' PT
04-02-2007, 11:11
I understand. Please let us know what you find.
Leroy Eckert
Niceville,FL
Sent: Monday, April 02, 2007 6:02 PM
Subject: Re: [WanderlodgeForum] Leaking air when braking
Leroy,
again.
Kevin Mc
YL CA
86 38PT
04-02-2007, 13:33
I believe you have a dual system, that is two air tanks, one for
the front and one for the rear. There should be valves to prevent a
leak in one system from effecting the other. Did both systems loose
presure or just one?
Gardner
78FC33
> Leroy Eckert
> Niceville,FL
> From: krminyl@...
> Leroy,
blue box,
I hoped to
drawings...thanks again.
> Kevin Mc
> YL CA
> 86 38PT
http://www.aol.com.
04-02-2007, 14:26
both
04-03-2007, 00:21
thanks...I'll take a look at my air line to the left front wheel....
Kevin
04-03-2007, 01:20
Kevin
I had the same symptoms . The hose to the lt front wheel was cracked. New
hose, less than $10, problem solved. My pressure would drop until the step
came out.
LT 90 SP Eclectic, AL
To:
Sent: Monday, April 02, 2007 8:33 PM
Subject: [WanderlodgeForum] Re: Leaking air when braking
> Gardner
> 78FC33
>> Leroy Eckert
>> Niceville,FL
>> From: krminyl@...
>> Leroy,
> blue box,
> I hoped to
>> Kevin Mc
>> YL CA
>> 86 38PT
> http://www.aol.com.
> Yahoo! Groups Links
