Electrical relay under sink 84FCSB
04-16-2007, 03:26
There are four 110v outlets in my 84FC that don't work. Three of the
outlets are under the sink on the outside wall. I traced the problem
to what appears to be a relay under the kitchen sink. The relay looks
like a junction box with a brown bakelite cover. When I close the
relay manually I get power to 3 of the outlets. Two under the sink and
one next to the toaster compartment. The fourth, also under the sink,
shows nothing.
Is the relay an old school form of GFI protection? How do I correct
this problem?
Thanks, Keith
84FC35SB
San Diego
04-16-2007, 03:46
Nope don't think so Keith.
That relay could very well be the one from the rediline generator.
Sounds like that relay is not working, as it pulls in when there is 120 volt
available from the load center.
In the normal state, it is deenergized, contacts closed from the rediline.
You do not need that type of relay either, purchase one that is rated for 120
volts on the coil and contacts are rated for 30 amps . It also appears to be a
DPDT.
Terrace, B.C. Canada
----- Original Message ----
Sent: Monday, April 16, 2007 8:26:50 AM
Subject: [WanderlodgeForum] Electrical relay under sink 84FCSB
shows nothing.
this problem?
Thanks, Keith
84FC35SB
San Diego
Get a sneak peak at messages with a handy reading pane with All new Yahoo!
Mail: http://mrd.mail.yahoo.com/try_beta?.intl=ca
04-16-2007, 03:54
Keith:
That relay is from the rediline days. The relay should be electrically held
closed when on shore power or gen set. The open when no shore or gen set.
This allows all to be hot when on shore or gen set, or when open it has the
potential to be hot from the rediliine for the ice maker and small wattage
items. One other plug may be on that same circuit and that is in the bath.
So the relay should have power on the coil when on shore or gen set. Start
troubleshooting the reason why the coil of the relay is not pulled in and
go from there. Or at least that is what I would do.
Safe travels,
84FC35
>shows nothing.
>this problem?
>Thanks, Keith
>84FC35SB
>San Diego
04-16-2007, 03:56
Hey Bill, thanks. That is all Greek to me? Check your e-mail...
Keith
84FC35
--- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs
120 volt available from the load center.
rediline.
rated for 120 volts on the coil and contacts are rated for 30 amps .
It also appears to be a DPDT.
> From: Keith Strehle
problem
looks
sink,
> shows nothing.
> this problem?
> Thanks, Keith
> 84FC35SB
> San Diego
All new Yahoo! Mail: http://mrd.mail.yahoo.com/try_beta?.intl=ca
04-16-2007, 04:14
Thanks Ralph. I'm not familiar with rediline but the outlet in the
bath is hot. Of the three outlets under the sink. Two go hot when I
close the relay. These outlets feed the Konstant Hot, the piezo
igniter for the stove, the ice maker, and a small space heater under
the sink.
I have no idea how to troubleshoot this relay?
Keith
84FC35
> Keith:
electrically held
gen set.
has the
wattage
the bath.
set. Start
in and
> Safe travels,
> 84FC35
problem
looks
sink and
sink,
> >shows nothing.
correct
> >this problem?
> >Thanks, Keith
> >84FC35SB
> >San Diego
04-16-2007, 05:06
Keith- look in the forward curb side outside compartment. Behind a black
metal louvered panel is where the rediline is supposed to be. i believe that
panel is held up by 2 screws. Tell us what you find.
83PT40
Livingston, Mt
04-16-2007, 05:39
The rediline works when the engine is running and the generator is off and
you are not plugged into shore power. I don't think I had a switch on my 84
35FC
83PT40
Livingston, Mt
04-16-2007, 07:28
Hi Keith:
With shore power off, remove the brown cover on the relay junction box
under the sink. Remove the extender ring on top of the 4 inch box. Apply
shore power, and with your meter set to volts AC check the black and white
wires for 120 vac at the bottom of the relay, these wires cascade up to the
relay coil. If you have power, then it is safe to say the relay coil is bad
and needs to be replaced. I know that your going to find 120 vac there
because you manually push it and you have power to the plugs, but best to
check incoming power anyway so it becomes a "known" rather than a "think."
Now you know the relay needs replacing.
Ralph
Safe travels,
84FC35
>the sink.
>Keith
>84FC35
> > Keith:
>electrically held
>gen set.
>has the
>wattage
>the bath.
>set. Start
>in and
> > Safe travels,
> > 84FC35
>the
>problem
>looks
>sink and
>sink,
> > >shows nothing.
>correct
> > >this problem?
> > >Thanks, Keith
> > >84FC35SB
> > >San Diego
04-16-2007, 08:36
Thanks Ralph, I don't believe I have a rediline generator? I can't
seem to find any switches that refer to rediline. I called Bluebird
and the guy told me it was an option. So maybe it's not there. But
why the relay then? And it doesn't explain why the outlets don't
work.
Keith
84FC35
> Hi Keith:
box
Apply
and white
up to the
coil is bad
there
best to
a "think."
> Ralph
> Safe travels,
> 84FC35
when I
under
> >the sink.
> >Keith
> >84FC35
> > wrote:
> > > Keith:
> >electrically held
> >gen set.
open it
> >has the
small
> >wattage
> >the bath.
> >set. Start
pulled
> >in and
> > > Safe travels,
> > > 84FC35
of
> >the
> >problem
relay
> >looks
> >sink and
> >sink,
> > > >shows nothing.
> >correct
> > > >this problem?
> > > >Thanks, Keith
> > > >84FC35SB
> > > >San Diego
04-16-2007, 08:57
Keith,
With or with a RediLine, Sounds like the relay is defective.
The AC power closes this relay to power up the missing circuits.
You can replace the relay or wire past it.
Just remember you or someone may want to install an inverter
in the future.
It is usually best to repair or replace as designed by BB,
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, "Keith Strehle"
Bluebird
But
> work.
> Keith
> 84FC35
> > Hi Keith:
junction
> box
box.
> Apply
> and white
> up to the
> coil is bad
> there
> best to
> a "think."
> > Ralph
> > Safe travels,
> > 84FC35
> when I
> under
> > >the sink.
> > >Keith
> > >84FC35
> > > wrote:
> > > > Keith:
> > >electrically held
or
> > >gen set.
> open it
> > >has the
> small
> > >wattage
in
> > >the bath.
gen
> > >set. Start
> pulled
> > >in and
> > > > Safe travels,
> > > > 84FC35
Three
> of
> > >the
> > >problem
> relay
> > >looks
close
> the
> > >sink and
> the
> > >sink,
> > > > >shows nothing.
> > >correct
> > > > >this problem?
> > > > >Thanks, Keith
> > > > >84FC35SB
> > > > >San Diego
