86 PT38...any pitfalls?
04-18-2007, 08:08
Scott, when I bought our PT40, the major difference was that I could not
hear the different pitches of noise from the engine that I was so used to
hearing on our FC. And since I went to a year older bird, all the gauges that I
was
used to looking at were not included on my coach. Other then that, glad I
made the switch.
83PT40
Livingston, Mt
04-18-2007, 09:51
Pete Its easier to wash it off the toad than the rad. I took mine to the
curb & get it on my wrangler but my rad stays clean.
Don
89 SP 36'
Butler, PA
The series 60 only has one ... located in the dumbest possible
position, all things considered. When the engine cover is open,
sitting at idle (warmed up) you can see the vapor coming out of the
tube and being drawn by the fan under the street side of the coach
and back through the radiator. On my 'to do' list is to rig up some
pipe to route the tube out to the curb side (opposite from the fan).
I don't want to route it out the back as that would end up all over
my toad.
04-18-2007, 10:38
Are there are common problems on PT's I should look out for? I have an
FC and know a lot about them, but have zero hands-on experience with a
PT. Anything I should pay special attention to outside of the "normal"
things would be helpful.
Thanks
Scott Forman
82 FC35RB (Might be for sale soon)
Memphis
04-18-2007, 11:34
PTs have a tendency for the radiator to become clogged with dirt.
It's difficult to examine as shrouds and other appliances get in the
way. The area swept by the fan usually is clear, but the surrounding
area can be clogged with oily-dirt. (The "slobber tubes" feed hot oil
vapor that mixes with dirt kicked up by the fan to clog the
radiator.) This is a maintenance item (wash out with sudsy, warm
water from time to time) but can become a serious issue if it causes
the engine to overheat.
Most of the rest is standard 'bird stuff... Of course the engine can
have some considerable differences -- cat 3208 vs DD 6v92 or 8v92
(depending on year).
You won't need a 'swing away' radiator!
Pete Masterson
aeonix1@...
On the road at Johnson City Texas
> have an
> "normal"
04-18-2007, 11:47
Pete:
Do your slobber tubes hang down and touch the road? Just wondering.
Leroy Eckert
1990WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Wednesday, April 18, 2007 6:34 PM
Subject: Re: [WanderlodgeForum] 86 PT38...any pitfalls?
Pete Masterson
aeonix1@...
> have an
> "normal"
04-18-2007, 12:01
What is a "slobber tube"? Never heard that one....
Scott
surrounding
oil
causes
can
> Pete Masterson
> aeonix1@...
> > have an
with a
> > "normal"
04-18-2007, 13:37
my toad.
Pete Masterson
aeonix1@...
El Sobrante, CA
On Apr 18, 2007, at 6:47 PM, Leroy Eckert wrote:
> Pete:
> Leroy Eckert
> Niceville, FL
> From: Pete Masterson
> oil
> Pete Masterson
> aeonix1@...
>> have an
>> with a
>> "normal"
> Yahoo! Groups Links
04-18-2007, 13:39
A part of the crankcase ventilation system. I my case one each tube attached to
the left and right cylinder heads near the valve covers which drop to road level
and one large crankcase breather tube which hangs well below the engine pan. In
my set up any oil slobber hits the road. Hence, the buzz word "slobber tubes"
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Wednesday, April 18, 2007 7:01 PM
Subject: [WanderlodgeForum] Re: 86 PT38...any pitfalls?
Scott
surrounding
oil
causes
can
> Pete Masterson
> aeonix1@...
> > have an
with a
> > "normal"
04-18-2007, 13:41
Slobber tube also known as "breather tube(s)". This is a crank case
breather to allow air pressure to escape from the engine as it heats
up. DD 6v92 and 8v92 engines have two of them (one for each bank of
cylinders) and they are notorious for dribbling oil. The DD Series 60
engine (an inline-6, four cycle engine) is not as serious an oil-
dribbler as some 8v92s ... but the location in relation to the
radiator is not well thought out.
Pete Masterson
aeonix1@...
On the road at Johnson CIty, Texas
> Scott
> the
> surrounding
> oil
> causes
> can
>> Pete Masterson
>> aeonix1@...
>>> have an
> with a
>>> "normal"
> Yahoo! Groups Links
04-18-2007, 13:43
Thanks, I forgot you have a Series 60. Getting it to road level will certainly
help.
Leroy Eckert
Niceville, FL
Sent: Wednesday, April 18, 2007 8:37 PM
my toad.
Pete Masterson
aeonix1@...
El Sobrante, CA
> Pete:
> Leroy Eckert
> Niceville, FL
> oil
> Pete Masterson
> aeonix1@...
>> have an
>> with a
>> "normal"
> Yahoo! Groups Links
