coolant sensor
04-30-2005, 18:07
coolant sensor
My coolant sensor may be acting up as the DDEC is returning a code of
low coolant. However, when I check the coolant level it is okay. The only sensor I find is the one on the coolant reservoir. Is there another one on the radiator in a PT40, 475 HP?? If so, where is it and how do I get to it?? Gene Marshall, Dickinson, Texas 1988 PT40 WB |
05-01-2005, 03:21
coolant sensor
Gene:
Are you sure that is the only code you are receiving? I had that problem last year. Nothing wrong with the coolant, but I had a leak right above my oil pressure sending unit that had a hole in the plastic cap from a loose compressor belt rubbing on it. I couldn't see that code, but when we hooked up the code reader, there it was. Take it by a dealer and check with the reader. R.E. (Ron) Marabito, Dallas, TX 92WB40 \--- In WanderlodgeForum@yahoogroups.com, "poolredalligator" > My coolant sensor may be acting up as the DDEC is returning a code of > low coolant. However, when I check the coolant level it is okay. The > only sensor I find is the one on the coolant reservoir. Is there > another one on the radiator in a PT40, 475 HP?? If so, where is it and > how do I get to it?? > > Gene Marshall, Dickinson, Texas 1988 PT40 WB |
05-01-2005, 18:49
coolant sensor
Ron, I am not receiving any other codes-always the 1-3 that reads lo-coolant
sensor. I note that when I overfill the coolant reservoir the engine light does not come on as often but because the reservoir is so full, I lose the coolant and have to overfill it again if I want the keep the engine light from coming on so often. The oil pressure sending unit was replaced on June 7, 2004 so I don't think that it is the problem as everything looks fine there. Any other ideas you might have is certainly welcomed. Missed you at the Kerrville Rally. Gene Marshall, Dickinson, Texas 1988 PT40 WB |
05-02-2005, 01:14
coolant sensor
Gene: No other ideas other than take it to a shop that has a reader
and have it checked. Simply clearing all the codes past and present might just solve your problem. R.E. (Ron) Marabito, dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, vmarshall@h... wrote: > Ron, I am not receiving any other codes-always the 1-3 that reads lo- coolant sensor. I > note that when I overfill the coolant reservoir the engine light does not come on as often > but because the reservoir is so full, I lose the coolant and have to overfill it again if I > want the keep the engine light from coming on so often. The oil pressure sending unit > was replaced on June 7, 2004 so I don't think that it is the problem as everything looks > fine there. Any other ideas you might have is certainly welcomed. Missed you at the > Kerrville Rally. > > Gene Marshall, Dickinson, Texas 1988 PT40 WB |
05-02-2005, 07:12
coolant sensor
Ron , is there a way to clear the codes myself. Stewart & Stevenson is the
only place I know of that has the means to read the original DDEC and they charge an arm and a leg here in Houston. Thanks, Gene Marshall, 1988 PT40 WB |
05-02-2005, 07:32
coolant sensor
Gene I dont know much about the Detroit Diesels except I like them. Maybe
this will help you. http://tinyurl.com/blgyv http://tinyurl.com/9nlp2 Tom 1982 FC35 Vernon Center,NY In the beautiful Mohawk Valley t 02:12 PM 5/2/2005 -0500, you wrote: >X-Virus-Scanned: by amavisd-new at ispc.xtelegent.net > >Ron , is there a way to clear the codes myself. Stewart & Stevenson is the >only place I know of that has the means to read the original DDEC and they >charge >an arm and a leg here in Houston. Thanks, > >Gene Marshall, 1988 PT40 WB > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. |
05-02-2005, 09:39
coolant sensor
Gene: I had about the same problem a few years back on my 93pt. I
would get the low coolant flash code and also about the same time I would get the check transmission light flashing when I would go from bright to dim on the head lights. I bought tuner spray cleaner and took the cannon plugs lose and cleaned them well. I then went completely over every ground strap on the coach. also added a extra one next to the one on top of the transmission. After doing all that I have not had one problem with false code's or lights. It also corrected my speedometer from running about 15mph standing still. Bob 93pt40 500hp DDII..Illinois |
05-02-2005, 14:22
coolant sensor
Hi Gene,
I am having the same problem with the low coolant code as yourself. I have to overfill the tank to stop it from happening. I usually get the check engine light flash when going up a long slope. I have not been able to put my finger on the problem as of yet. If I find the cause I will let you know. I do not think that clearing the code will solve your problem. I have already tried that. Andy 88 WB40 |
05-02-2005, 19:02
coolant sensor
Great information. I had the DDEC Codes but not the other documentation.
Thanks!!!! Gene Marshall, Dickinson, Texas 1988 PT40 WB |
05-02-2005, 19:02
coolant sensor
Andy, thanks for the reply. I forgot to mention in my post that my engine light
also comes on more often when I am climbing a long hill. Must be something that is common with the 88 PT 40's. Hopefully between the two of us we can find a solution to this problem and will not have to keep over filling the coolant reservoir. Gene Marshall, Dickinson, Texas 1988 PT40 WB |
